shoe sole glue
mick7016/08/2018 11:18:46
524 forum posts
38 photos
what's best for sticking soles to shoes?
daughter as managed to have front of hers come loose on her favourite shoes.
Russell Eberhardt16/08/2018 11:22:11
2689 forum posts
86 photos
Hob nails? Seriously though ordinary contact adhesive works fine for me.
Russell
Gordon W16/08/2018 11:24:30
2011 forum posts
Depends very much on the material (usually unknown). The last ones I did I used a hot glue gun, still there after a year of hard use. Also have used gorilla glue, works well on leather. Hot glue gun useful for lots of bodge jobs.
Robbo16/08/2018 11:27:52
1504 forum posts
142 photos
Hot glue gun has worked for me for partial repairs (toes,edges etc)
Roderick Jenkins16/08/2018 11:34:02
2122 forum posts
582 photos
Shoe Goo is very good. It will even build up worn heels if you make a dam with some insulating tape.
HTH,
Rod
Richard Marks16/08/2018 11:40:39
206 forum posts
8 photos
Evo Stick Serious Glue, worked for me and the wifes shoes.
Alan Waddington 216/08/2018 12:14:52
523 forum posts
87 photos
Sikaflex or car windscreen bonder......the shoes will wear out before either of those....
Hopper16/08/2018 12:26:57
5505 forum posts
137 photos
It helps to run the sole and the bottom of the shoe over the belt sander prior to gluing if you can. Just enough to scuff them up so the glue can "key" into the surface.
Martin W16/08/2018 12:31:44
894 forum posts
29 photos
I have used Evo Stick and Bostik Clear Contact Adhesive for my good ladies and my shoes. Spread adhesive to both surfaces, leave for a few minutes to get tacky then clamp firmly, especially around the edges, and leave for 24hrs. Has always worked for me.
Cheers
Martin
Neil Wyatt16/08/2018 18:49:14
18721 forum posts
727 photos
80 articles
I've has Serious Glue and EvoStik both fail on trainers where the two layers of sole have split apart. I imagine too much dust/crud got in the split.
Why is it 'name' (Slazenger) trainers don't last any longer than cheapies?
martin perman16/08/2018 19:07:18
2005 forum posts
83 photos
I have specially made shoes for a condition I have and the manufacturers use a glue which seems allows the sole to become unstuck after a year wink, approximately, and I find Evostick works well with the repair.
Martin P
Russell Eberhardt17/08/2018 09:55:31
2689 forum posts
86 photos
Posted by Neil Wyatt on 16/08/2018 18:49:14:
They are probably made in the same factory. It's just that one type has the name put on it.
I once saw a factory in Malaysia where they were making T-shirts for Lacoste. They were also making unbranded ones on the same line which were sold for just a few pence in the local markets. The price difference isn't a matter of quality but the mark-up made by the brand owner to pay for, amongst other things, their advertising costs.
Russell
Howard Lewis19/08/2018 19:23:33
5224 forum posts
13 photos
And I thought that I was the only "careful" person on here. "Not tight y'ken, just careful"
Yes, contact adhesives seem to to do the job Found that acrylics were too stiff, and soon failed.
Robin Graham19/08/2018 20:32:28
865 forum posts
258 photos
I've not had too much luck with contact adhesives myself, but Gorilla glue (the polyurethane stuff which foams slightly as it cures) works very well provided you don't mind trimming off the excess which squidges out as it cures.
Robin
Mick B120/08/2018 13:20:27
1996 forum posts
114 photos
Same reason that Chinese lathes work as well as Myfords etc.... devillaugh
Martin Kyte20/08/2018 13:47:59
2525 forum posts
45 photos
Titebond PVA works well for clogs.
;o)
mechman4820/08/2018 16:18:20
2932 forum posts
460 photos
Posted by Martin Kyte on 20/08/2018 13:47:59:
;o)
Aye; 'appen them clogs did ah 'reet on t' cobbles when I wer a lad an me granda' used t' wear 'em, solid wood, wi' hob nails in t' soles, sum 'ad what we called 'oss shoes on 'em, when walkin' 'cross 'ot sheets in t' plate mill, eeh bah gum them's wer' days them wer devil face 20
George.
Tim Stevens20/08/2018 17:36:13
1447 forum posts
Them 'oss shoes was called Clog Irons by them in't know, sithee
Tim
Sherlock22/08/2018 21:54:51
52 forum posts
11 photos
I've tried many of the stuff listed here, for a sole of some work boots.. All did not hold up too well for a decent enough period of time, So I, Like you was searching for something better... In my research somebody (relative of an old cobbler) swears by a flexible Cyanoacrylate.... Not tried yet, but I intend to.
Gordon W23/08/2018 10:53:37
2011 forum posts
Just for those trying for the first time- Make sure you have all the clamps and packing etc. ready for use, some glues set very quickly. For best results you will need two or three clamps, packing /pressure pads on sole side, packing on the inside bottom, and packing on the shoe outside top. All depends on the shoe design and the clamps being used. check and test before using the glue. Sorry for egg sucking instructions.
walker midge
JD Metals
Dreweatts
rapid Direct
