Chester Champion V 16 Z axis mod
David George 112/08/2018 20:28:34
1304 forum posts
447 photos
Just started to change the Z axis handle to 90 deg. hand wheel and to fit a ball screw and motor to top of column for power feed.
David
Edited By David George 1 on 12/08/2018 20:29:25
David George 131/08/2018 11:03:59
1304 forum posts
447 photos
Done a bit more work on top housing for bevel gears.
side shaft and bush to make next.
David
David George 101/09/2018 20:36:50
1304 forum posts
447 photos
Shaft and bush turned now I just need to cut keyways in gears and screw bush into place to get basic hand wheel moved.
Need more information on a 24 volt DC motor to drive the axis. How much power would I need? would it need to be a geared motor for slow feed with enough power to drive axis fast traverse.
David
Ian Parkin01/09/2018 21:34:44
834 forum posts
202 photos
dsc00854 (large).jpgOn my mill and a few other machines I,ve used parvelux motors from a seller on eBay
These are 24 v and draw about 2 amps and run about 40 rpm
He sells these motors new and unused for about £25
Edited By Ian Parkin on 01/09/2018 21:35:10
David George 104/09/2018 16:11:58
1304 forum posts
447 photos
Done the side drive shaft and phos. bronze bush but ordered the wrong keyway broach from Arc so I will have to wait for new delivery. Made the keys and fitted them to shaft ready for when the broach arrives.
David
David George 118/09/2018 11:32:06
1304 forum posts
447 photos
Just had a few days on holiday nr Bristol so only just got back to workshop this week. Broached the bevel gears and fitted to shafts ok finished milling the main block so assemble and try in machine! Found that I had cut two of the cap screw holes out of position slightly so have to dissemble and slot holes to suit wrong dimension on drawing must have had a brain storm.
David
geoff walker 118/09/2018 17:31:52
418 forum posts
160 photos
Nice work David, is it your own design?
Looking forward to seeing it completed.
A you tube video of it in use would be a good idea.
Geoff
David George 122/09/2018 16:58:51
1304 forum posts
447 photos
The handwheel stage is complete and working. It is so much better to use I can look at the cutter and wind the handwheel without standing on small stool. Next to fit the motor for powered drive as well.
Ian thanks for the information on the motor perfect for the job just needs a bit of thought so I can disconnect motor drive to use handwheel.
Geoff yes its all my own work but it is the sort of thing I would have to do occasionally before I retired.
David
Neil Wyatt22/09/2018 18:19:42
18139 forum posts
713 photos
77 articles
You should be writing that up David!
David George 104/10/2018 13:54:29
1304 forum posts
447 photos
Just been making the coupling for the motor and trying to decide how to disconnect it. I have bought some springs to support the motor and help disconnect the coupling I have made.
Next to get the motor mounted on top plate and spring load the plates on top.
David
geoff walker 105/10/2018 07:46:00
418 forum posts
160 photos
Sounds good to me I'll second that.
M.E. or M.E.W., I would imagine both editors would be very interested
Geoff
David George 110/11/2018 21:06:59
1304 forum posts
447 photos
I had a break from motorising the Z axis when I found that the DC motor was to fast and no power and jumpy when slowed down. Thought about putting a toothed belt and pully on but decided to fit a stepper motor on instead. Baught a new motor and driver.
David
Martin Connelly11/11/2018 07:20:55
1420 forum posts
165 photos
If you have problems of too little torque from the stepper for raising the head you can get axial planetary gearboxes with suitable gear ratios to slow the head movement and increase the torque. They can be added with minimal further engineering as they are made to suit standard stepper motors.
If you think about the maximum rpm you need for your leadscrew and the maximum available from a stepper motor a suitable ratio should be an easy calculation.
Martin C
David George 117/02/2019 17:12:17
1304 forum posts
447 photos
Hi had a bit of progress with the power to stepper motor look at vid on https://www.youtube.com/channel/UC40QHbhXPF7MyiUT_hacScQ
David
David George 117/02/2019 23:08:49
1304 forum posts
447 photos
A few pictures of nearly finished job.
David
David George 117/02/2019 23:12:06
1304 forum posts
447 photos
Need to install limit switches to prevent overrun etc. The power supply is under the bench 24 volt and 5 volt signal.
David
David George 103/03/2019 09:30:54
1304 forum posts
447 photos
At last fitted the limit switch and it is finished. Satisfied with the outcome it does what I hoped for and no backlash with th ball screw.
David
petro1head23/07/2019 21:49:12
742 forum posts
143 photos
Just found this, looks great.
For the elctrical parts is it just the stepper motor, driver and power supply?
EngineDIY
