Cast Iron Weights -Aldi
Brian Sweeting01/08/2018 00:15:38
443 forum posts
Sorry if this is in the wrong place.
Just seen that Aldi have sale on and one item is 4 x 2.5kg weight lifting disc weights at £ 4.99.
Could be pullies or handles?
Ady101/08/2018 00:40:02
3862 forum posts
522 photos
Could be handy if the CI is ok
I turned one I found down and used it as a lashup hacksaw crank
The main thing is the thickness at the thinnest point, usually the mid section
The thicker the better for skimming down purposes
Messy too
Rik Shaw01/08/2018 10:16:26
1365 forum posts
373 photos
I collect these weights along with cast iron scales weights etc if cheap enough at the local boot. So far I have machined about 10 per cent of my total stock without a problem. In fact it machines very well indeed. The only stuff that is variable is CI sash weights. Some of mine are "untouchable".
Rik.
Clive Foster01/08/2018 10:22:52
2377 forum posts
76 photos
Do verify that they are actual cast iron first. Mulit-gym exercise machine weights are frequently plastic cases filled with sand. Be unsurprised if similar construction was used on inexpensive weight lifting disks.
Clive.
SillyOldDuffer01/08/2018 10:41:11
6330 forum posts
1389 photos
You take pot-luck with this stuff, a while back someone reported opening up a heavy lamp base to find it was made of compressed swarf and resin. One of my weights was a sort of rusty concrete. If you win, smile. If not try again.
Sash weights are notorious. I think it's because many foundries made them as a quick and dirty sideline. Any left-over molten metal from the main job would be carelessly poured into a handy mould. Because they're only rough window  weights, slag and waste could be thrown in, the type of cast-iron doesn't matter, sand would get mixed in, and no-one worried about chilling. So sometimes you get good quality metal, other times awful.
Edited By SillyOldDuffer on 01/08/2018 10:42:14
mechman4801/08/2018 10:49:27
2752 forum posts
423 photos
...a while back someone reported opening up a heavy lamp base to find it was made of compressed swarf and resin...
​I have found the same with an broken lamp, thinking 'this'll make a flywheel somewhere' but ... any how its now one of those items that may well be 'useful in the future', stuck on a shelf in the garage dont know .
​George.
Circlip01/08/2018 11:01:23
1197 forum posts
In the early days when Taiwanese machinery was the predecessor to "Chinese" machinery, the same question was put forward re the cheap weightlifting sets that appeared for use as flywheels. They seemed to be the same as the sash weights for material quality. Paint hides many sins.
Regards Ian.
Mark Rand01/08/2018 11:05:49
923 forum posts
6 photos
Haven't tried the 2.5kg weights, but I've machined three of the 10kg ones so far. One's now a Hardinge faceplate and the other two are bases for cup stands for SWMBO's pottery selling efforts. I found that the cast iron was more like cast steel. Fairly tough to machine to get a fine finish with carbide. It machined ok mostly, just had a 'gnarly' finish (it'd catch on your fingers or a bit of cloth if you rubbed it).
Because I'd come across some CBN inserts on EBay some years back for a give away price, I finally got to trying one on the weights. The result was a mirror finish with high speed very fine cuts.
So give them a try. They might work, but even if not, they can be used to hold things down!
larry phelan 102/08/2018 19:12:24
825 forum posts
17 photos
Tried to use sash weights once,never again ! they are CRAP,and I mean CRAP !! The only thing they are fit for is in balancing windows,which I suppose is what the were made for. Not much use for anything else.
Now Aldi,s offering,I cannot comment on that,but I would approach it with caution. Why would they use good cast iron in something like that ?
EngineDIY
