What type of glue to use...
What type of glue to use sticking paper paters to metal
Samantha Loughlin23/07/2018 13:52:38
3 forum posts
Hello,
I am very new to the forum and making and I have a questions I am hoping someone can help me with.
I would like to glue a paper pattern that I have printed to copper and brass so that I can use it to cut the correct shape and drill holes in the right place. My question is what glue should I use as obviously after I would need to remove it completely... and also what I use to remove it would be great too
Thank you in advance for any advice.
Sam
jason udall23/07/2018 18:21:37
2023 forum posts
41 photos
I would go for "Pritt" or any similar paper glue...
Soak in water to remove..paper and glue
Derek Lane23/07/2018 18:26:56
318 forum posts
73 photos
At the moment I work mainly in wood and am looking to start in metal work. What i use to stick patterns down is the spray photographic type adhesive.
Jon Lawes23/07/2018 18:29:14
370 forum posts
Second vote for Prittstick, I've used it for holding a guitar pickguard pattern to a sheet of stainless before marking out and it held remarkably well and removed cleanly.
Samantha Loughlin23/07/2018 18:35:33
3 forum posts
That's great .. thank you all!
Jeff Dayman23/07/2018 18:41:15
1796 forum posts
45 photos
I like spray glue for sticking paper patterns to metal for cutting - 3M's Super 77 is great. Not sure if it's available where you are but artist suppliers in North America usually stock it, and industrial supply firms. Sold in a large can, it lasts ages when doing model work. It is oil resistant, and usually stays stuck over several days if working on a complex part.
It cleans up completely with acetone or laquer thinner. Isopropyl (rubbing) alcohol will remove it usually, if you can get the stuff with 20% alcohol or more (much of the stuff in drug stores here is diluted with lots of water to make it look like a great deal ie big bottle low price).
Edited By Jeff Dayman on 23/07/2018 18:46:58
Neil Wyatt23/07/2018 19:13:46
17742 forum posts
698 photos
77 articles
+3 for pritt. Put it on the metal not the paper and let it dry a bit, otherwise it can make the paper wrinkle.
N.
XD 35123/07/2018 19:15:50
1419 forum posts
Pva wood glue works well and you can just soak it to get the template off without having to scub it to death .
Gary Wooding24/07/2018 08:01:31
671 forum posts
169 photos
I do a lot of pierce sawing on precious metal and use Pritt Power.
Martin Kyte24/07/2018 08:09:30
1810 forum posts
33 photos
Spray Mount from you local art shop.
Martin
Michael Cox 124/07/2018 08:39:02
529 forum posts
27 photos
I have printed patterns onto A4 self adhesive label stock. These stick readily to clean metal. They are easily removed by wetting the label with white spirit and then peeling off.
Samantha Loughlin24/07/2018 09:30:13
3 forum posts
Wow thank you all this is all really helpful .. I have some pritt sticks so going to start there then explore the others so I can find what works best for me. Thank you all again so much!!
Tim Rowe24/07/2018 09:47:39
27 forum posts
4 photos
+ for Pritt. When the time comes to take the paper patterns off, brush on some clean water and the paper will soak it up readily. It will also start to wrinkle and lift. If you keep going sparingly with the water the paper will more of less fall off taking most of the glue with it. If you try to peel the paper too early you will find more of the glue remaining on the job.
I do this all the time for balsa and plywood ribs and formers on model aircraft.
Just a light wipe with a damp (not wet) sponge or cloth and that removes any residue.
No nasty solvents!
roy entwistle24/07/2018 09:56:19
1154 forum posts
Note that there are two types of spray mount. One is instant sticking, the other allows you to reposition the pattern on the job. Spray mounting can also be a bit nasty if used in an enclosed space.
Personally I would go with Pritt
Roy
SillyOldDuffer24/07/2018 10:31:24
5651 forum posts
1159 photos
I don't know of anything better than Pritt, but two things to check before cutting:
  • That the pattern hasn't shrunk as the glue dries, (yes it does happen), or
  • Slid out of position due to being handled before the glue has set
The first problem caused serious cussing, the second misplaced hole I pretended was deliberately offset for artistic reasons...
richardandtracy24/07/2018 10:51:38
938 forum posts
10 photos
Posted by Martin Kyte on 24/07/2018 08:09:30:
Martin
That's what I'd suggest too. can be completely removed.
Self adhesive crack-back sheets work quite well too.
Richard.
martin10726/07/2018 06:34:05
62 forum posts
20180726_061123.jpg use double sided carpet tape such as https://www.ebay.co.uk/itm/Rolson-Heavy-Duty-50mm-x-25M-Double-Sided-Carpet-Adhesive-Floor-Rug-Stick-Tape/262842864715?epid=16011027141&hash=item3d32a7d44b:g:iCMAAOSwJtdaAxDX like this and it works well when I cut out oval shapes in Ali it goes through cutting on a bandsaw, 12 tapped holes, 2 countersunk holes and finishing off on an sander and its still suck, so that works for me and it peels off nice and easy when your done as long as you wait for it to cool down.
Martin
