Carbide PCB drills and router bit sources
Peter Harrison 207/07/2018 00:25:49
2 forum posts
It has been a couple of years since I was able to get to an engineering show. A regular supplier was someone selling solid carbide drill, milling and routing bits. All on 3.2mm shanks, many with indexing collars. I assume these can from PCB manufacturing and were swapped out after a certain number of hour running.
Now I need some more but I cannot find this, or any other supplier, through the magic of Google.
So - does anyone have a website address of this or another supplier of these really useful cutters?
Joseph Noci 107/07/2018 07:56:51
645 forum posts
877 photos
Peter, Maybe not local to you, although Banggood may have a dispatch warehouse in the UK I think - Anyhow, take a look here:
I use the 15deg 0.1mm engraving bits for isolation routing of the copper tracks on PCB's - buy them in packs of 10, and generally get 2 or 3 duds in the pack - not ground properly and raise horrid burrs, but the price for a 10 pack can't be beat..
The drill bits and routing bits I have also purchased quite a number of - found no duds there so far..
Shipping to/within UK should be good - to me in Namibia is mostly pot-luck...
Joe
John Rudd07/07/2018 11:39:37
1368 forum posts
66 photos
Try ESR electronics in Cullercoats....
https://www.esr.co.uk/electronics/products/frame_pcb.htm
(just up the road from me...)
Edited By John Rudd on 07/07/2018 11:40:32
John Haine07/07/2018 16:21:34
3013 forum posts
160 photos
Loads of suppliers on eBay.
richardandtracy07/07/2018 20:47:03
938 forum posts
10 photos
The 1.5mm router bits are useful for very tiny milling. Even did a pen decal logo into wax on my CNC router with a 0.3 mm cutter. Got all mine from various e-bay sellers at £5 to £7 for 10, so not pricy even if they take a month to arrive.
Richard.
Peter Harrison 207/07/2018 21:45:38
2 forum posts
Good links. Thank you.
ESR had slipped my mind. Not seen them for a while.
I have had cutters from Ebay and they have been fine - it can be a bit f a lucky dip for delivery and getting exactly what you want among the endless choices.
Finding the magic search term is often the key.
