Rollers and benders
Derek Lane27/06/2018 11:53:21
317 forum posts
71 photos
Can anyone recommend a set of plans for either of the two machines as per the title. They would need to be made without any specialist equipment like a lathe or milling machine.
JasonB27/06/2018 12:28:31
17835 forum posts
1951 photos
An indication of the size and thickness of material would help as there is quite a difference between rolling a 10mm x 1mm strip and doing the same to a 1000mm wide 10mm thick one, same applies to bending.
not done it yet27/06/2018 12:40:12
4495 forum posts
16 photos
Look for yourself on your computer, is my suggestion. There are plenty of metal brake/bender demos on u-toob, along with construction details for more than a few.. Most use available metal sections so one only needs a hacksaw and drilling kit.
Rolls are a different matter, I would think. As above, sizes and precision might depend on whether it was for jewellery (for instance) or 12” to the foot scale models.
Derek Lane27/06/2018 13:05:22
317 forum posts
71 photos
Thank you for the replies I did forget to put thickness in my original post but as it was my first I could not edit it to add those.
The maximum thickness I am looking at is 1/8". I have just found a roller in an old Model engineers workshop magazine that I have.
Just out of interest I am a woodworker and these will be used for parts on some of my work. I did own a metalworking lathe but regret having sold it. And would really like to buy another as well as a milling machine but that is something for the future.
Michael Gilligan27/06/2018 13:16:07
15462 forum posts
668 photos
Posted by not done it yet on 27/06/2018 12:40:12:
That ^^^ is an interesting response to the opening question from a new forum member:
[quote] Can anyone recommend ... [/quote]
... Not sure quite how the process would work.
Meunier27/06/2018 20:05:19
307 forum posts
Derek, if you find yourself in the same position again (even when able to edit a post there is a limited time window to do so) - just make another post with the missing info, it happens quite often.
and welcome aboard !
DaveD
richardandtracy27/06/2018 20:36:11
938 forum posts
10 photos
For the bender, if you want it for thin metal, look up the David Gingery book on the Camden Miniature Steam Services book (my tablet won't paste links in this forum, sorry). I have a copy and can recommend the design as clear, concise and eminently practical. The only down side is that, as it's American, the sizes are imperial.
Richard.
Maurice27/06/2018 21:00:46
459 forum posts
50 photos
Hemingway Tools sell a kit for a set of bending rolls and will sell you just the plans. They seem to be based on the design by George Thomas serialised in M.E. years ago. The rolls were so arranged that the curve went right to the end of the work. I have a set and they work very well.
Maurice
Brian G27/06/2018 21:03:58
671 forum posts
26 photos
Are you after rolling and bending wide sheets or narrow strips? If the latter a pair of bars in the vice for bending and a set of scroll formers for curves might be easier.
