Forum sponsored by Allendale Nov 29
Thickening oil
vintagengineer16/06/2018 20:52:07
468 forum posts
6 photos
I need to thicken some gear oil to point of being just short of being grease. Any tips?
Wout Moerman16/06/2018 20:59:11
43 forum posts
Just thinking out loud, add a bit of grease to the oil? And you already have the thickest oil available?
pgk pgk16/06/2018 21:10:25
1215 forum posts
278 photos
That's an interesting question. Instinct suggests adding grease or dissolving a wax into it but looking up gear greases educated me a bit.. this quote from exol's data sheet suggests a complex process incorporating saponification
<<An aluminium complex soap thickened grease based on solvent refined hydrocarbon oil incorporating solid lubricants, polymers, extreme pressure additives, and a blend of antioxidants and corrosion inhibitors, combining to provide highly effective lubrication with excellent corrosion protection. This lubricant is bitumen free.Open Gear Grease 2.5 has been specially developed for the lubrication of all types and sizes of open gears,including spur, helical and bevel drive gears that are subjected to extreme loads, high working temperatures and water saturated conditions.>>
pgk
Ron Laden16/06/2018 21:35:18
790 forum posts
106 photos
I dont know how to to thicken gear oil but someone once showed me some Mobile 600W steam oil and you could just about pour it at room temperature, really thick oil.
Mike Poole16/06/2018 21:41:16
1618 forum posts
41 photos
A component called Paratac can be used to make oil sticky but that may not be what you want.
David George 116/06/2018 21:50:33
576 forum posts
193 photos
What is the thick oil used for?
David
vintagengineer16/06/2018 22:12:16
468 forum posts
6 photos
Vintage steering boxes
Chris Evans 616/06/2018 22:23:39
1319 forum posts
Don't mess about just buy some "Type O" semi fluid grease. Plenty available it is used in early motorcycle gearboxes and commercial vehicle chassis lubrication systems. I get mine from a local agricultural supplier as lots of farm equipment uses it.
Muzzer16/06/2018 22:25:10
2904 forum posts
448 photos
Grease is a soap mixed with an oil. If you want to make it more liquid, mix more oil with it.
Murray
not done it yet16/06/2018 23:14:48
2474 forum posts
11 photos
Corn Head grease?
clogs16/06/2018 23:28:18
429 forum posts
12 photos
we called it "black jack" for use on open gears........cranes etc......
put it on with a trowel........lovely job....the youngest got that job......hahaha....
John Reese17/06/2018 01:47:33
610 forum posts
Posted by clogs on 16/06/2018 23:28:18:
It sounds similar to Crater Compound we used on the open gears of a well drill. We heated it so we could pour it onto the gears.
peak417/06/2018 02:03:52
647 forum posts
60 photos
Have you considered Landrover swivel hub grease? Cheaper elsewhere, but I picked this vendor as they included the following description. Original lube would have been EP90.
A good alternative is to replace oil with swivel grease, This is the same type of grease that Land Rover actually use on newer vehicles to prevent leakage. This is a special grease that is semi-fluid so it lubricates but is less likely to leak.
Suitable for use on all Land Rovers, Defenders, Range Rovers and Discovery's with swivel balls. A quality replacement part, equivalent to Land Rover part number: STC3435
Bill
colin wilkinson17/06/2018 06:27:07
42 forum posts
Available from Hichcocks Motorcycles for Royal Enfield gearboxes
http://accessories.hitchcocksmotorcycles.com/accessory-shop/Silkolene-Oils/16612
Colin
Jens Eirik Skogstad17/06/2018 07:12:22
364 forum posts
22 photos
25-40% canola oil mixed in the mineral oil to preventing the oil was washed away from surfaces by steam/water.
Canola oil was thickened first: warm up oil and blow up with air pressure into the oil, let it bubble until the oil is thick. It's due the oil is oxidized (with other word: rancid). The canola oil must be without antioxidants additive who are impossible to thickening the canola oil.
Gordon W17/06/2018 09:44:35
2005 forum posts
Used to use grease in Velocette chain case to stop leakage, with some oil to make it a bit runny. Not very technical but recall this was an official Velo advice.
mechman4817/06/2018 20:20:37
2198 forum posts
370 photos
We used to call it 'Clagum' or 'black fat' ... yes! I was that apprentice that had to trowel it on to open gears on cranes etc. crook
George.
Jon Lawes17/06/2018 21:10:05
245 forum posts
Penrite do a genuine steering box grease for 6 quid, lithium based and EP rated. Is it worth risking hit and miss results making your own when the real deal is only the price of a couple of beers? Actually, beers beer...
not done it yet17/06/2018 21:21:33
2474 forum posts
11 photos
Hope you ere not referring to corn head grease as blackjack. Different stuff. The blackjack was, I believe, thickened with graphite but was not particularly thixotropic. John Deere use corn head grease in gearboxes on their combines.
Phil Whitley18/06/2018 17:41:29
721 forum posts
102 photos
the peerless gearbox/transmission on many different makes of garden ride on mowers uses a bentonite grease. these incorporate gears and clutches, available in bottles at £31.66 +vat http://www.westwoodtractorspares.co.uk/gearbox-and-clutch/various-peerless-models-gearbox-parts/peerless-gearbox-grease-788067c
méridienne Nov 18
TRANSWAVE Converters
