Electric motor reassembly
Maurice15/06/2018 16:52:45
469 forum posts
50 photos
I have just dismantled the motor from my lathe to clean it out, as I thought a piece of swarf may have entered the casing. There are enough slots and openings! As I removed the cover with the start switch on it, two wavy spring washers about 1 1/2" diameter fell out. There are none the other end. The housings look identical, as are the bearings. One at each end makes more sense to me. Has my motor been wrongly assembled for all these years please?
Maurice
Brian Sweeting15/06/2018 16:55:14
443 forum posts
Preloading the bearings perhaps?
David Jupp15/06/2018 16:55:22
751 forum posts
17 photos
It is probably correct. One bearing housing should be a tighter fit, whilst the other allows some axial movement to handle thermal expansion - the wavy washers will go in the 'floating' housing.
mgnbuk15/06/2018 17:02:45
800 forum posts
61 photos
The wave washers are to provide a small axial preload on the bearings to ensure that they roll & don't skid if the motor is run unloaded. I would put them back as they were, as they were most likely positioned as the maker intended.
Nigel B
Maurice15/06/2018 17:22:57
469 forum posts
50 photos
Fair enough. Thanks a lot for you help.
Maurice
EngineDIY
