Forum sponsored by Allendale Nov 29
Microscope Equipment, What is it please?
Martin King 213/06/2018 16:30:22
545 forum posts
176 photos
Hi All,
Todays delivery from my friendly local house clearance guy included this nice cased item.
Something to do with a Vickers microscope, I would appreciate any info on how to describe this thing please.
Cheers, Martin
Swarf, Mostly!13/06/2018 16:35:02
459 forum posts
41 photos
Hi there, Martin,
I wonder if I shall beat Michael to the draw?!?
Your kit is a hardness testing set. The cylindrical gizmo is a hydraulic (I think) indenter. The Vernier eyepiece is fitted to the (a? ) microscope and used to measure the diameter of the indentation. This is looked-up in Tables to translate to hardness.
I guess it has to be hardness on the Vickers scale.
Did you receive the microscope with it?
What else did you get?
Best regards,
Swarf, Mostly!
Edited By Swarf, Mostly! on 13/06/2018 16:37:52
Michael Gilligan13/06/2018 16:48:04
12286 forum posts
538 photos
You did indeed, Swarf sad
I have some information about Vickers' earlier version, but probably not this.
... If there's anything relevant, I will put it in my Albums.
John MC13/06/2018 17:05:51
115 forum posts
10 photos
I think its a micro hardness tester, for testing the hardness of specimens that will not take the higher indentation loads from the usual Vickers hardness tester. Thin strip and the like. From memory the loads were in grams for micro hardness and kilograms for macro tester.
Roderick Jenkins13/06/2018 17:19:07
1641 forum posts
412 photos
As John says it's is for micro-hardness. The diamond indenter is small enough to be able to select different phases in a metallographic specimen. The indenter is powered by air pressure via a press on plastic tube from the cylinder. I used to use one, bought new in the 1980s.
Rod
Martin King 213/06/2018 17:27:06
545 forum posts
176 photos
Many thanks guys, it had me beaten!
I remember doing hardness measurements in one of my Uni sandwich course sections, measuring a small pyramid dent in material that had had a load pressed on a small diamond shaped ram.
Would you say it is totally obsolete or perhaps of some use/value?
Swarf, it came with a bunch of other non related stuff, kit that is more in my usual line, some nice woodworking tools, panel beaters tools, set of ER32 collets and chucks, small ADEPT lathe etc
The clearance guys round here always put stuff aside for me and give me first dibs which is really useful as I never know what they are going to turn up with. Sometimes it is like Xmas every day!
Basically anything they do not have a clue about they save and drop round for me to have a look at. I turn away a lot of rubbish, but sometimes I buy some crap anyway just so they keep coming round. Would not want them to stop!
Cheers, Martin
Martin King 213/06/2018 17:28:55
545 forum posts
176 photos
Swarf, did not get the microscope, apparently they dropped it and it smashed to smithrereens....sad
Martin
Michael Gilligan13/06/2018 17:40:38
12286 forum posts
538 photos
Martin,
I suggest you have a browse through the images here: **LINK**
https://dlib.york.ac.uk/yodl/app/home/search?query=vickers+micro+hardness
Incidentally; I think the very boxy looking binocular head in your first image belongs to an M55
Correction: The binocular head probably belonged to 'your'  M41
https://dlib.york.ac.uk/yodl/app/home/search?page=3&query=m41
Edited By Michael Gilligan on 13/06/2018 18:08:27
Martin King 213/06/2018 18:14:49
545 forum posts
176 photos
MichaelG, many thanks for the link, all I have to do now is work out what on earth to do with it..?
Martin
Michael Gilligan13/06/2018 18:40:05
12286 forum posts
538 photos
Posted by Martin King 2 on 13/06/2018 18:14:49:
Martin
Assuming you mean what to do with the link, Martin
... each of them should take you to a gallery of relevant images from the Vickers Archive; amongst which you may find some helpful images.
Edit: if you mean 'what to do with the kit' ... accept a derisory offer ?
Edited By Michael Gilligan on 13/06/2018 18:44:05
méridienne Nov 18
Shapiro
TRANSWAVE Converters
