Forum sponsored by Allendale May 23
Locomotion in 7.25 inch scale by Reeves 2000
joe king 113/06/2018 08:04:12
23 forum posts
Looking at a part started one but cannot see any safety valves on the drawing.
Would appreciate knowing if would be able to use at a club as designed please as not familiar with current regulations.?
Thank you
Joe
JasonB13/06/2018 08:15:49
15175 forum posts
1548 photos
Well reeves sell the safety valve body so it must be on the drawings somewhere! It's the lever type which may be better replaced with something else for actual running and keep the correct looking one for display.
joe king 113/06/2018 08:40:19
23 forum posts
Thanks reply Jason
I think it looks as it may go in the centre at the top but just one safety valve.
Can a boiler with just one safety valve meet the current regulations please ?
Thank you
Joe
JasonB13/06/2018 10:01:30
15175 forum posts
1548 photos
As far as I know there is no requirement for two.
KWIL13/06/2018 10:46:11
3064 forum posts
56 photos
The drawing show a weight type Salter safety valve and is also part of the castings kit available from Reeves. There is no reason why you should not fix a "normal" safety valve in its place on the regulator "block" in between the cylinders.
TRANSWAVE Converters
