Minnie Traction Engine - Water Gauge
Malcolm Farrant11/06/2018 16:26:07
87 forum posts
A solution if anyone has one.
I made the bushes for my Minnie to the sizes shown, i.e with a 7/32 x 40 Tap holes.
I do not fance making this. I can purchase from Macc Models what appears to be a suitable alternative, but the smallest I can get has 1/4 x 40 thread.
I think I have enough metat remaining to re-drill and tap.
Is this the best altetnative or are there any other suggestions ?
As always any help and advice will be MUCH apreciated.
Best wishes to all
Malcolm
JasonB11/06/2018 17:20:36
17835 forum posts
1951 photos
Probably not long enough to clear the third shaft, you may be able to make up some sort of extensions to overcome this.
julian atkins11/06/2018 22:59:03
1232 forum posts
353 photos
Hi Malcolm,
Why not make your own water gauge? I am quite sure you will be able to make something far more satisfying than a standard commercial fitting, plus with your 7/32" x 40 TPI ME thread.
They are not difficult to make.
I have always made my own boiler fittings, and have never bought commercial products.
Cheers,
Julian
Thor12/06/2018 07:51:13
1210 forum posts
37 photos
Hi Malcolm,
You have a PM.
Thor
Bob Youldon12/06/2018 10:25:33
183 forum posts
20 photos
Hello Malcolm,
I'm with Julian on the subject of boiler fittings, they are very satisfying components to make, further most commercial boiler fittings seem to be made from brass, and generally where fitted below the water line will slowly dissolve before your very eyes! The water gauge for Minnie as pointed out is specifically designed for that engine, so I'd doubt if a suitable item is made commercially.
Bob
Malcolm Farrant12/06/2018 11:04:35
87 forum posts
As always thank you you.
Jason B. I am going to try the 1/4" item. But very grateful for your comment on the 3rd Shaft
Malcolm
