Aldi bandsaw
Rik Shaw10/06/2018 20:57:44
1352 forum posts
368 photos
Bought one of these today because the box said it could cut non-ferrous (although the handbook does not mention this fact). The blade supplied and fitted has large teeth and is obviously meant for wood/plastic.
I have quite a large pile of .070" thick brass sheet. Will this machine cut it with the correct blade fitted? If so, what sort of blade should I be looking for. i.e Width -TPI - bi-metal etc. etc.
Never used a little bandsaw before, only experience was with one with a 1" wide blade in a die shop many years ago.
Rik
Mike Poole10/06/2018 21:25:19
2688 forum posts
64 photos
I think a scroll saw is better suited to thin material because it can use very fine blades, bandsaws tend to have blades that are too coarse for thin sheet materials. I think tooth pitch should be chosen to have a minimum of 2-3 teeth in contact with the material.
Old School10/06/2018 21:26:11
344 forum posts
29 photos
Not seen the Aldi saw but have an old black decker bandsaw with a fine pitch blade it cuts metal just have to go steady.
David George 110/06/2018 21:45:31
1297 forum posts
445 photos
Hi Rick I had a Clarke band saw to review and it also came with a course wood saw blade but when I fitted a smaller tooth metal cutting blade it cut brass and aluminium with no problem. To fast for steel.
David
Edited By David George 1 on 10/06/2018 21:48:05
Muzzer10/06/2018 22:31:56
2904 forum posts
448 photos
When you say "obviously meant for wood/plastic", are you claiming to know what the approved blade looks like? These modern "Rage" type blades don't look a lot different - they are carbide tipped blades, rather like, well, a wood cutting blade. I suggest you are overthinking this....
I expect the Aldi saw is similar to the Evolution Rage saw I have myself. Did you RTFM?
Murray
Edited By Muzzer on 10/06/2018 22:32:26
Marcus Bowman10/06/2018 22:57:48
166 forum posts
One possible factor you might need to consider is blade speed.
Marcus
David George 110/06/2018 22:58:43
1297 forum posts
445 photos
Murray isn't the rage saw a rotary disk saw not a band saw?
David
not done it yet11/06/2018 07:21:51
4865 forum posts
18 photos
350W motor.
900m/min cutting speed!surprise
IF the band has about 4tpi, it is most certainly not for metal!
richardandtracy11/06/2018 08:14:03
943 forum posts
10 photos
That little saw should be OK at up to 6mm aluminium & brass so long as you don't push it hard and realise the body of the saw will flex if you do. It may go thicker with care. The blade tpi should be such that you aim for a minimum of 3 teeth in the depth of the material. So, for 3mm (or 1/8" brass you're looking for a blade with 24 or more tpi. I doubt if you'll get much higher tpi, though I've not looked. So, this suggests that 3mm is probably the thinnest you should cut & expect full blade life. If you go thinner, the load per tooth will be higher & teeth will snap off more quickly. You will still cut the material, just reduce the blade life.
On my Clarke metal band saw I have cut sheet steel of .75mm with an 18 tpi blade. Had to be careful as occasionally the saw tooth in contact with the steel bent the sheet rather than cut it if I let the feed rate get too high, and the blade lost teeth fast, but it did the job quicker than any other tool I had available to me at the time.
Richard.
Clive Hartland11/06/2018 08:24:59
2591 forum posts
40 photos
Yes, use a fine blade more than 18 Tpi, perhaps a 24 Tpi. I found it helpful to draw a line of bees wax down the cutting line as it gets quite hot at the cutting edge. Be careful with round items as it tends to roll and draw the work into the blade, sheet will chatter and the rough edge will scratch the alu. table.
Clive Brown 111/06/2018 08:39:43
479 forum posts
18 photos
I have a home-made bandsaw to which I fit the common DIY 1/4" x ~59" blades. My "standard" blade is 14 tpi, with this recently I've cut loads of 1.6mm brass sheet for a 5" tender, plus thicker and thinner oddments including 12 mm steel and some round bar with no problems.
The blade speed is reasonably lowish though, about 250 ft/min at a guess, I'll have to check.
Rik Shaw11/06/2018 10:39:24
1352 forum posts
368 photos
"I suggest you are overthinking this...."
Your remarks puzzle me!
Rik
John Rudd11/06/2018 10:42:42
1373 forum posts
4 photos
So are we debating the merits of band saws or chop saws and their respective blade types?.....blush
Rik Shaw11/06/2018 10:44:38
1352 forum posts
368 photos
Thanks to most of you for blade advice. I'll order a couple of blades today to deal with my brass sheet.
Rik
Ray Lyons27/09/2018 19:24:16
168 forum posts
Have you seen the latest offering from ALDI, another bandsaw but only available on line at £150.If I didn't have a Kennedy, this would be on my want to have list.
Vic27/09/2018 19:36:29
2554 forum posts
14 photos
Posted by David George 1 on 10/06/2018 22:58:43:
David
Yes, Rage sell mitre (circular) saws.
Ian Skeldon 227/09/2018 20:06:42
487 forum posts
37 photos
A long time ago before I had better machinery, I cut some very thin plate, I think it was called 'litho' I used broad double sided tape and stuck it to a sheet of ply wood, did the job quiet well.
Ray Lyons28/09/2018 07:19:49
168 forum posts
Not to be confused with the usual woodworking bandsaw, this one is powered by a variable speed 1100 watt motor and has a cutting capacity of 127x127MM. It can be mounted on a stand or bench and hung up for storage. The only downside is that it is only available on line so no chance of examining before purchase.
Paul Ainsworth04/10/2018 11:49:59
97 forum posts
15 photos
Posted by Ray Lyons on 27/09/2018 19:24:16:
For not a lot more you can get a dedicated metal bandsaw from the usual suppliers, eg this one from Chester
https://shop.chesterhobbystore.com/collections/saws/products/h80-swivel-arm-bandsaw
mechman4804/10/2018 13:04:37
2721 forum posts
422 photos
Do you mean one of these... 'Scroll saw' … just bought one myself today, in the process of trying it out...
George.
EngineDIY
