Forum sponsored by Allendale Nov 29
Aerospece grade aluminium tubing
Jolyon de Fossard10/06/2018 20:40:58
15 forum posts
Hi everyone,
I have am looking for some aerospace grade aluminium tubing. The property I'm looking for is a good stiffness/resistance to bending to mass ratio. Don't care about weldability or machinability as I have to do relatively little to it in reality.
The grades that that I think are suitable are 6061 or 7075
I need a 10mm diameter tube with a 1mm wall thickness and I need about a metre of it.
Please can someone advise me of a place where I can buy more specialist grades of aluminium tubes such as these.
I am in the UK.
Yrs,
Jolly
Emgee10/06/2018 20:53:25
1042 forum posts
197 photos
Hi Jolly
Have you considered 6082 T6, following copied from the spec sheet.
"Alloy 6082 is a medium strength alloy with excellent corrosion resistance. Alloy 6082 has the highest strength of the 6000 series alloy. Due to the higher strength of Alloy 6082 it has replaced Alloy 6061 in many applications. Alloy 6082 is typically used in highly stressed applications, Trusses, Bridges, Cranes, Transport applications, Ore Skips, Beer Barrels, Milk churns."
Emgee
richardandtracy10/06/2018 21:19:03
938 forum posts
10 photos
You are unlikely to find much extruded section from 7075. 6082, instead, is available in quite a few sizes. Go for the T6 or T65xx temper.
Richard.
Old School10/06/2018 21:27:58
214 forum posts
Model yacht masts in aluminium might be suitable.
not done it yet10/06/2018 22:09:02
2643 forum posts
11 photos
I would suggest you search out aero kit suppliers if you require this material for anything that lifts a human off the ground and into flight. It will likely require all the certification that goes with aerospace usage.
Trevor Crossman 110/06/2018 22:21:28
125 forum posts
15 photos
Hi Jolyon, I would suggest go to your nearest Smith's Metals who may not have in stock of the high strength aerospace alloys such as 2024 & 7075 at the branch but do hold it at their main warehouse, so you may have to make a minimum purchase of a stock length. Another stockiest is Wilson's though you'd probably have to approach your local engineering business to get it for you on their account as I don't think that Wilson's do retail sales.
Trevor.
Bazyle10/06/2018 22:37:51
4391 forum posts
184 photos
Sounds like a model aircraft main spar stiffener for an old design. Probably now replaced by carbon fibre tube in a recent design.
As alluded to above aerospace grades aren't special magic stronger materials, they just wrapped in ten times their weight of paperwork so the people using them have to have special magic bottomless wallets.
Cabinet Enforcer10/06/2018 23:17:55
30 forum posts
Posted by Jolyon de Fossard on 10/06/2018 20:40:58:
There is no significant difference in youngs modulus between the various aluminium grades, so any old tat will do.
If it isn't stiff enough, change material, or change the dimensions, a diameter increase being the most effective.
SillyOldDuffer11/06/2018 11:04:49
3857 forum posts
775 photos
Posted by Cabinet Enforcer on 10/06/2018 23:17:55:
Que? Surely 'any old tat will do' can't be good advice when we don't know what the application is!
It might matter to Jolyon. '7075' is an expensive corrosion resistant alloy with a good strength to weight ratio. This combination makes it particularly suitable for use in aircraft. But there's more - looking at the detail reveals that 7075 comes in more than one grade, with important differences. For example:
  • 7075 has a yield strength of 140MPa
  • 7075-T6 has a yield strength of between 430MPa and 480MPa
  • 7075-T651 has a yield strength of 500MPa
Note that 7075-T651 is nearly 4 times stronger than ordinary 7075.
This is why documentation is important in safety critical applications. Work is done to specification and it's not possible to tell the difference between alloys by eye alone. In fact, an elaborate laboratory analysis is usually needed to identify an unknown alloy and its physical properties, which may have been altered by heat treatment or work hardening etc. Also, the high cost of aircraft components makes them a tempting target for counterfeiters and well organised records make fraud more difficult.
There's a world of difference between what goes in my rough amateur workshop and repairing the wing of an aircraft where strength, weight, fatigue and corrosion are all critical.
Vic11/06/2018 12:17:27
1968 forum posts
10 photos
I think you’re right SOD. Didn’t an airliner crash due to an engine falling off because of a counterfeit shear pin?
Neil Wyatt11/06/2018 13:09:40
15581 forum posts
652 photos
73 articles
If you want nicely anodised 6062T and don't mid paying through the nose, you can buy a metre from B&Q. Avoid the soft un-anodised tubing, beware the bet ones and be prepared to spend ages searching.because people take them out and put them back in the wrong slots (check the bar code numbers) ...
Neil (who spent fifteen minutes searching to find some rod to make a Yagi with last week)
Jolyon de Fossard11/06/2018 13:19:22
15 forum posts
Thank you everyone.
The application is not safety critical. I am rebuilding an old high quality tonearm from a 1960's hifi record player. The original tube was damaged. I don't know what it was but assumed it would be something more than the standard architectural grade. But, the tube I bought in B and Q will do. I was wondering if it wouldn't be too hard to find something better.
Yrs,
Jolyon
Nick Hulme12/06/2018 09:53:17
620 forum posts
35 photos
That application is begging for Carbon Fibre Tube, if it had been available in the 60s the original designer would have used it for a tonearm
not done it yet12/06/2018 10:02:53
2643 forum posts
11 photos
Ahhh, so not really an ‘aerospace quality’ thread at all. Nick’s reply above might have answered the right question at the first post.
Vic12/06/2018 10:23:56
1968 forum posts
10 photos
You can buy Arrow tube in high tensile Alloy, Carbon or Carbon Composite in a variety of diameters. I think the biggest you’d get though is about 5/16” in the alloy.
Jolyon de Fossard12/06/2018 11:57:13
15 forum posts
It is not for an Aerospace application but I am happy to pay for Aerospace grade material unless the feel is that the material isn't appreciably better in terms of the attributes I am looking for.
Hopper12/06/2018 12:14:07
3289 forum posts
58 photos
"Aerospace quality" is a bit of a misnomer really. You can buy the same grades of alloy that are used in aircraft but are a lot cheaper, eg 6061, 7075 and so forth. But if you buy it without the aircraft-use certification that authenticates its origin and exact nature etc the cost is reasonable. Once you start buying "Aerospace quality", ie certified, you start paying "aerospace prices".
For what you are doing, a bit of tubing cut from an old hiking tent pole might do the job.
David Standing 112/06/2018 12:38:09
1176 forum posts
43 photos
Posted by Nick Hulme on 12/06/2018 09:53:17:
Ah, but that might change the tonal quality of the cartridge, and the sound output, currently devised around aluminium, in a negative fashion!
SillyOldDuffer12/06/2018 13:05:41
3857 forum posts
775 photos
Posted by Jolyon de Fossard on 12/06/2018 11:57:13:
Listening to music is subjective. Many things influence what an individual considers to be 'good' because the experience is emotional rather than logical. It happens there's a substantial group who enjoy music more when they believe their sound system to be technically superior.
Hard-nosed engineers snigger about blinged up sound systems because they know there's no objective difference between fancy gear and much less expensive equipment. That doesn't matter. If you hear better sound from gold-plated wires and aerospace quality materials that's good reason for using them. It might be a placebo effect, but believing it works will get positive results from unnecessary technology. Something to do with the investment of time, care and money perhaps. An audiophile friend of mine had a cleaning ritual before playing an LP that reminded me of a church service and I wouldn't criticise anyone's faith.
Our brains react to both logical and emotional impulses. Our emotional side offers rich experiences but has to be treated with suspicion because it often gets us into deep poo. (Like marrying the wrong girl or voting without thinking about risks!) Spending a bit of dosh to make a sound system special doesn't feel unreasonable to me - go for it! I don't think the desire to better a sound system is any different to the equally illogical desire chaps restoring old lathes have to match the original factory colour scheme, even though colour makes no difference whatever to  functionality. That said, knowing full well the colour is immaterial, I would never paint a Myford pink!
Edited By SillyOldDuffer on 12/06/2018 13:09:21
Jolyon de Fossard12/06/2018 16:46:02
15 forum posts
Thank you all for your considered response.
The tonearm is quite rare and was an expensive item in its day. I would like to keep it looking original as much as I can so am not attracted to carbon fibre superior as it may well be in this application
The original was Nickel plated which is a strange choice really so I will be anodising the whole thing as later versions of this arm were.
So; I suppose I'll just use a nice looking tube from B and Q.
I enjoyed the comparison with a Myford restoration. As it happens I rebuilt my 1948 ML7 and used original paint but I ditched the motor and added a 3 phase machine with an inverter drive. So, it is a blend of old and new.
Yrs
Jolly
TRANSWAVE Converters
