Forum sponsored by Allendale Dec 6th
Jones .605 Glow engine
KEITH BEAUMONT10/06/2018 16:25:42
64 forum posts
15 photos
dsc03499.jpgdsc03451.jpgdsc03446.jpgHave recently finished the Jones .605 glow engine.Pictures should be below. Castings and drawings from Hemingway kits.It is an 80s design,before the requirement for silencers, but I did a small mod to allow the fitting of a standard OS unit, which has taken that ear splitting crackle out of the engine sound. Pity, but I have to think of my neighbours It is a thirsty beast while being run in. A 6oz tank full gives a 5 minute run time. So far It has clocked up an hour of rich running with 5% fuel. An occasional 10 second burst flat out registered just over 15000RPM,so the Schnuerle porting, the setting out and drilling / filing of which, certainly strained the grey matter, must be in the right places, It is an easy starter,and was quite easy to get the needle valve and throttle settings about right. I am at present trying out different plugs.
Roderick Jenkins10/06/2018 16:41:38
1800 forum posts
461 photos
Very nice, Keith.
Rod
KEITH BEAUMONT10/06/2018 16:45:55
64 forum posts
15 photos
Thanks Rod.
Keith
geoff walker 110/06/2018 19:42:14
343 forum posts
145 photos
Well done Keith,
.That's an impressive test stand as well
geoff
Emgee10/06/2018 20:58:23
1319 forum posts
211 photos
Great looking engine Keith, also sound pretty powerful although you don't mention prop size used.
Emgee
KEITH BEAUMONT10/06/2018 21:12:24
64 forum posts
15 photos
Hi Geoff and Emgee.
The prop used at the moment is a 12" x8", which is the only one I have at this sort of size at the moment.
When flat out it nearly caused a crisis, pulling the workmate stand across the floor, hence the sack of rock salt laid across its base. It clearly has a lot of power.
Keith
Neil Wyatt10/06/2018 21:17:53
16927 forum posts
689 photos
76 articles
That's nice, I'm almost as impressed by the test stand as by the engine, I may copy that!
Clive B10/06/2018 21:30:10
25 forum posts
20 photos
Keith, The engine looks terrific; well done! Maybe you can post a video of it running?
P.S. Really like your Chenery Vee twin also. Might finish mine one day!
Roderick Jenkins10/06/2018 21:45:04
1800 forum posts
461 photos
I've got one of those test stands:
EIAAMXQGqJRF8nz
As usual, cheaper than buying the bits frown
Rod
Edited By Roderick Jenkins on 10/06/2018 21:45:25
ChrisH10/06/2018 22:06:37
834 forum posts
19 photos
Very nice engine, looks exceedingly well made - well done.
Chris
Marcus Bowman10/06/2018 23:00:15
162 forum posts
Lovely thing.
I particularly like the colour of the anodizing on the fins.
Marcus
KEITH BEAUMONT11/06/2018 11:12:28
64 forum posts
15 photos
Thank you all for your comments.
Neil, The test stand is as Rod mentioned. I found the cap head screws on the left side got in the way of the throttle arm in a lot of cases ,so I c/bored them flush on that side.
Clice B, Good luck with your Vee twin. If you have not already done so, I suggest you read my previous where I relate my problems with compression ratio and the need for long nuts to hold the heads down.
Keith
