Forum sponsored by Allendale Nov 29
Arc welder cooling oil.
Jonathan Milner22/05/2018 09:26:09
5 forum posts
Good morning all. I am looking out for about 20 litres of oil suitable for a small,oil cooled arc welder.I am in N.Yorkshire. Thanks.
mgnbuk22/05/2018 09:34:20
487 forum posts
10 photos
Is Brighouse, West Yorkshire near enough ? Millers Oils list transformer oil **LINK**
Nigel B
john fletcher 122/05/2018 10:36:40
481 forum posts
Is Pickhill Batam still on the go at Pickhill Nr thirsk ? If they are they would have oil for their welders. Its transformer oil and I'm sure some one up in Teeside will have it. Ever thought of contacting the supply companies men who change transformer oil, they might have 5 gallons going spare. John
larry phelan 122/05/2018 11:32:40
375 forum posts
11 photos
Yes,it,s just transformer oil,so any good oil distributor should have it. I had to replace mine last year and got a supply from a local firm who supply oils to local farms and plant operators ect. Not cheap,but you dont have to do it too often.
Martin Cargill22/05/2018 12:01:33
97 forum posts
ebay item 122919447525
Speedy Builder522/05/2018 12:03:13
1670 forum posts
113 photos
Is there an H&S problem with "Old transformer oil" ?
larry phelan 122/05/2018 12:36:33
375 forum posts
11 photos
Ian S C22/05/2018 12:39:45
7224 forum posts
227 photos
If the welder is older than 1979, and hasn't had an oil change, it may contain the old PCB containing transformer oil which was banned as toxic from that time.
Ian S C
larry phelan 122/05/2018 12:52:16
375 forum posts
11 photos
In my case,I had spilled most of the oil while transporting the welder [it tipped over,you should have seen my van ! ],so I had to replace it anyway.
But you ask is there a problem with old oil ? Well I worked for many years for a firm who made transformers,from 3KVA to 10MVA and when some of the smaller ones [5 to 15 KVA ]came back for repair,having been hit by lightning,the coils would be burned to pulp and the oil like tar,and the smell of it !!.
So I would say, yes, there may be a problem with old oil,although I doubt if your welder is likely to be hit by lightning.
Perhaps the other mans oil level was just low,or dirty.
J Hancock22/05/2018 16:12:44
265 forum posts
Is there a problem with 'old transformer oil' ?
Just a bit.
Like if you do not know what it is.
IF it is PCB ( how will you know ?) then truly you will not be doing mankind a favour by throwing it on the ground.
One day it will reach the water table and the results can be dire.
Equally, if you don't wear protective gear ,breathing it, or getting it on your skin is not good news.
Just look up Seveso for what it can do.
Muzzer22/05/2018 18:26:11
2904 forum posts
448 photos
Yes, Ian SC and J Hancock have put their finger on it. Polychlorinated biphenyls were another clever idea from back then. Seemed like a good idea at the time - being halogenated, they are non flammable, so ideal for electrical equipment - what could possibly go wrong? Seems there are quite a few PCB containing products still out there....
Murray
Surely Seveso involved dioxin which is quite different and much more immediately unpleasant?
larry phelan 122/05/2018 20:11:00
375 forum posts
11 photos
When I recall the amount of transformer oil I handled,I suppose I,m lucky I never picked up anything from it. We were never made aware of any danger.
Ed Dinning 122/05/2018 21:10:16
22 forum posts
Hi Gents, as far as I know, PCB containing oils were only used on larger distribution / HV transformers due to cost.
It also has a higher gelling point, so is quite viscous at low temperatures.
You could also be offered switch oil, a similar compound but with some detergent action to remove the arc products from switch operation. This should also be suitable for a welding transformer.
Ed
David Standing 122/05/2018 21:38:43
1176 forum posts
43 photos
Posted by J Hancock on 22/05/2018 16:12:44:
Just a bit.
Having had a lifetime working in commercial liability insurance, with a lot of US toxic waste dumps and 1,317 of the nastiest dumps on the Superfund list involved; whilst I am not condoning spilling the contents of a welder, it is small beer compared to all the other polluting issues that the 7.6 billion of us on the planet are collectively creating!
Jonathan Milner24/05/2018 08:53:11
5 forum posts
Thank you for the replies.Its proving to be a bit elusive and expensive to source ,but a local nut n bolt supplier can get me some reclaimed transformer oil,so will probably order from them. I will wait a week or so , just in case I find a better offer. Cheers.
pgk pgk24/05/2018 11:38:08
1229 forum posts
278 photos
No idea how it compares in price but curiosity caused me to check ebay and there's a seller doing 1/2 and 1L bottles **LINK**
pgk
Ian S C24/05/2018 12:56:09
7224 forum posts
227 photos
Jonathan, nothing wrong with reclaimed oil, it just needs to be free of water, and ruin through a filter to get rid of any gunk.
Ian S C
Ed Dinning 124/05/2018 20:54:09
22 forum posts
Hi Gents, I also have a "steel tank on wheels" arc welder. It is a good piece of equipment, but if "heaved about" will slop oil from under the top cover. It has a breather on the top, but no apparent gasket between the top and sides.
Should one be fitted here?
Thanks, Ed
Jonathan Milner25/05/2018 20:15:56
5 forum posts
Ed , mine has a cork gasket . I reckon any oil tank will need a gasket on metal mating surfaces. I will report back when I am sorted with the oil,probably in a couple of weeks.Prices seem to be anywhere between about £60 reclaimed, to £120 new.
Ed Dinning 125/05/2018 21:03:06
22 forum posts
Hi Jonathan, exactly my thoughts, but no sign of one on mine. I have some cork, so I'll add it to the jobs list.
Cheers,
Ed
TRANSWAVE Converters
