Pressure as a unit of time
Stewart Hart25/04/2018 13:17:47
673 forum posts
357 photos
Take one old beat up pressure gauge
One cheap electric clock movement
Cut the guts out of the gauge
Replace it with the movement and hey presto you have a pressure gauge clock.
Its amazing what you get up to when your bored
smiley
Stew
Michael Gilligan25/04/2018 13:31:21
20289 forum posts
1064 photos
I trust you found something interesting to do with the Bourdon tube and mechanism, Stew
Jeff Dayman25/04/2018 13:33:20
2234 forum posts
47 photos
Maybe when I visit the UK we can go for a pint at about 25 psi.
Stewart Hart25/04/2018 13:37:38
673 forum posts
357 photos
Posted by Jeff Dayman on 25/04/2018 13:33:20:
I don't drink pints only feet and inches crook but yes any time your over we'll make it a date.
Stew
Neil Wyatt25/04/2018 14:12:21
19076 forum posts
736 photos
80 articles
I've got a bourdon movement that would probably fit that clock case...
Nigel Bennett25/04/2018 14:22:38
460 forum posts
20 photos
If it was a metric pressure gauge it'd be time to go to the bar...
Speedy Builder525/04/2018 15:41:46
2642 forum posts
217 photos
When I was working, TIME = PRESSURE. in pressure terms, 0 Psi = breakfast at home, 70 Psi after the morning meeting, Mild panic at midday, no time for lunch. Most pressure came towards the end of the day at 300Psi so the clock was about right.
BobH
Philip Rowe25/04/2018 16:13:02
230 forum posts
31 photos
I can see that in some arty farty antique shop selling for around £300! So I suggest that we all have a rummage under the bench and start producing antiques for the future.
Phil
Stewart Hart25/04/2018 16:23:24
673 forum posts
357 photos
Posted by Speedy Builder5 on 25/04/2018 15:41:46:
BobH
Never thought of it in them terms:- working under time pressure, or pressured by time, lack of time pressure etc etc.
Stew
Roger Williams 225/04/2018 17:32:21
350 forum posts
4 photos
What about time in nautical miles perhaps !.
Carl Wilson 425/04/2018 18:37:43
670 forum posts
53 photos
Not you as well. It's bad enough with Doubleboost doing it.
I'm going to get an old clock and make it into a pressure gauge.
John Haine25/04/2018 18:59:49
4712 forum posts
273 photos
Calibrated in lbf per square nano-light-second?
Sam Stones25/04/2018 20:14:55
880 forum posts
326 photos
Stewart,
Instead of batteries (or winding), you could have used the air spring.
Sam
richardandtracy26/04/2018 12:59:39
943 forum posts
10 photos
Was reading 'Echoes of the Oil Country 4' last night & Bill Osborne talked of using a modified pressure gauge as a dial gauge. This was 1901/1902. Seems redundant pressure gauges have been used for other purposes for well over a century.
Richard.
Michael Cottle26/04/2018 14:32:26
13 forum posts
The nautical miles option should do well in Germany! They have a system of 'Engineering minutes' for timesheets etc with 100 minutes in the hour!
Michael
oldvelo26/04/2018 15:41:42
295 forum posts
56 photos
Posted by Stewart Hart on 25/04/2018 16:23:24:
BobH
Stew
Hi I made this to compensate for this by adding an unloader valve
Happy being retired this device is working perfectly for me.
Eric
Edited By oldvelo on 26/04/2018 15:50:12
Edited By oldvelo on 26/04/2018 15:52:49
Edited By oldvelo on 26/04/2018 16:00:29
Carl Wilson 429/04/2018 19:03:36
670 forum posts
53 photos
Re the idea that people have been converting pressure gauges to other things for decades...people have been committing murder for millenia, it doesn't make it any less wrong!
I'd not make a clock to gauge conversion using pounds per square light second. That would be mixing units.
I've had enough now, I'm off to the bar...
Mick B129/04/2018 19:54:17
2219 forum posts
125 photos
You're all wrong. What you're actually doing is measuring time as a unit of pressure.
laughdevil
Meunier29/04/2018 21:52:03
448 forum posts
8 photos
Posted by Carl Wilson 4 on 29/04/2018 19:03:36:
snip
I've had enough now, I'm off to the bar...snip
If we are mixing units, then that would be 14.7psig then, Carl
DaveD
Sam Stones29/04/2018 22:59:04
880 forum posts
326 photos
Would time run backwards if you applied a vacuum to the ‘air spring?cheeky
Rapid RC
Dreweatts
