Turning paxolin
Roger Hart19/04/2018 17:17:35
142 forum posts
31 photos
Been making a couple of disks from 1/4 inch paxolin. The tool traverses from right to left and as it leaves the left hand side a small amount of delamination takes place. Not serious for this application just not a tidy job. But how do I avoid this happening - turn from each end towards the middle perhaps. Or is there a better way?
norman valentine19/04/2018 17:22:21
280 forum posts
40 photos
You could place a sacrificial piece of wood or maybe metal behind it to support the edge.
Jon Gibbs19/04/2018 17:50:08
739 forum posts
I think those are the two ways - back up the piece with another piece of waste stock or cut from both sides to the middle.
Jon
MichaelR19/04/2018 20:00:27
453 forum posts
84 photos
I used a piece of chip board as a backing when turning sections for my traction engine brake blocks in Tufnol. Mike.Tufnol
Ian S C21/04/2018 10:45:55
7468 forum posts
230 photos
The first gear I cut, using a single point fly cutter was a Paxolin (or similar) one, I placed the Paxolin between two 3/16" thick steel discs, and as there was room on the finished job (a water pump), I left the steel parts in place, twenty years on and it's still working ok.
Ian S C
JD Metals
MIDLNDS GARDEN RAIL Jan 2022
rapid Direct
