Forum sponsored by Allendale July 23rd
Where to get a running bearing for Ajax AJ8 mill
Mark Davison 118/04/2018 07:34:43
39 forum posts
11 photos
Having now repaired the casting for my new (old) Ajax horizontal mill I am in need of a new running bearing/sleeve for the arbor. Being a small machine it seems to have an unusual OD (1" I'D x 1.5" OD x 2" long). Any ideas where I could source one? EBay comes up with very little regardless of dimensions.
As the outside surface is ground i assume it will be prohibitively expensive to get one custom made.
The old one is completely shot, as was the bronze Bush. I've managed to source a suitable Bush (1.5" I'D x 1-7/8" OD)
Edited By Mark Davison 1 on 18/04/2018 07:35:44
Edited By Mark Davison 1 on 18/04/2018 07:36:19
Edited By Mark Davison 1 on 18/04/2018 07:36:57
Hopper18/04/2018 08:26:50
3651 forum posts
72 photos
Do you mean the sleeve on the far end of the arbor? You should be able to turn one up on a lathe and emery cloth it to a good enough finish for the kind of low-rpm duty it does. Not as fancy as the original ground surface but good enough for home hobby use.
Edited By Hopper on 18/04/2018 08:37:54
Mark Davison 118/04/2018 08:31:02
39 forum posts
11 photos
It is a plain steel sleeve, like a spacer but with a ground surface. It runs in a bronze bushing that is pressed into the arbor support arm. Oil is drip fed.
Mark Davison 118/04/2018 08:32:58
39 forum posts
11 photos
I've just polished up the old one and it isn't quite as bad as I first thought but would still replace it if I could find a new one.
HOWARDT18/04/2018 08:33:44
426 forum posts
14 photos
Give Boneham & Turner a ring, they sell Euco arbor spacers and bearing sleeves. Can't find the Euco website. Used both companies in my working life and allways found them helpful. Assuming of course you are Uk based.
mgnbuk18/04/2018 09:01:57
507 forum posts
10 photos
What about using needle roller bearing inner ring(s) ?
May need to use more than one is series, but I don't think that would cause problems.
Nigel B
not done it yet18/04/2018 10:27:37
3139 forum posts
11 photos
As per hopper, but dimensions are not that important (apart from the arbor close slip fit, which will not rotate) - just minimun clearance and concentricity. Bore out your current bush to get good bearing surface and make the arbor sleeve to whatever tolerance is required.
Hopper18/04/2018 12:27:10
3651 forum posts
72 photos
Another possibility might be like we do with worn-out motorcycle fork tubes: get them hard chromed and reground. A small job like your bearing sleeve should not cost too much. Just make sure they know that concentricity with the ID is critical, possibly making them an arbor to mount the sleeve on for grinding.
Not sure if you will find many hardened roller bearing races etc in inch sizes these days. They seemed become a thing of the past some years ago. You might have to make a bronze bushing with metric ID to suit a metric bearing race to use that option.
mgnbuk18/04/2018 12:41:13
507 forum posts
10 photos
1 1/2" Od x 1 1/4" Id x just over an inch long hardened & ground inner bearing ring.
Press or glue 2 onto a 1" bore x 1 1/4" Od sleeve & away you go.
Quite a range of Imperial bearing inner rings readily available - precision ground hardend parts at reasonable prices
Nigel B
geoff adams18/04/2018 14:28:04
121 forum posts
125 photos
Hi Mark
had the same problem with my aj8 mill the bronze bush was ok (clocked for concentricity )
it was oversize for the arbour bearing I machined a new one out of mild steel
the previous owner has put an oiling cup on the yoke so the bush and bearing get a good supply of oil
Geoff
Advertise With Us
TRANSWAVE Converters
Meridienne Sept 2019
