Ball bearings
Hacksaw16/04/2018 22:50:51
428 forum posts
173 photos
Well , it's knackered bearing time .Our Honda hrv needed a front wheel bearing last week . I could get one from 13 quid to 90 quid surprise I can imagine how long the £13 one would last..so I bought a SKF pattern part , £50 ish . Good name made me buy it over a cheaper one.
Now the 2 year old Hotpoint washing machine drum bearings have failed.. (it's designed to fail )and it's a sealed drum..well it was, but I,ve just sawn it in half to repair it myself !! laugh The bearings are marked Poland 6206Z PPL . Assume NSK , (edit no they're Japanese??) Do you think an SKF or Timken would be a better quaility ?
Edited By Hacksaw on 16/04/2018 23:05:04
Hopper17/04/2018 02:53:18
4770 forum posts
104 photos
Nothing wrong with Japanese bearings. I often use Naachi brand and Koyo brand Japanese bearings with no problems. SKF is my "go to" for critical applications though. Never had a problem with them. Likewise, Timken (now owned by and rebranded as Koyo) are my "go-to" for critical taper rollers and needle rollers used in Harley engines.
It's false economy to use cheap and nasty bearings as you end up doing the job twice and bearings are not that expensive -- although the new cartridge insert type wheel bearing packages are! But for the washing machine, buy SKF or similar and be done with it. Should not be too expensive.
not done it yet17/04/2018 09:38:57
4877 forum posts
18 photos
I had a hotpoint a long time ago. Bearings were undersized for the duty. The AEG replacement machine is still going (fairly) strong after nearly 25 years. Hotpoint are not my favourite by a long way.
J Hancock17/04/2018 10:22:30
437 forum posts
I think you will find that, in the case of washing machines, it will be the failure of the mechanical seal/seat that has allowed soapy water into the bearings .
A few hours of that on fast spin will do the damage.
Gordon W17/04/2018 10:59:02
2011 forum posts
Last time I put new bearings into a washing machine it worked very well. After a couple of days a loud noise started from the bearing area. Strip down again , the drum and mountings were broken, stress fractures allover. Bearings still good though. Seems this is common, bearing life = life of the rest of machine.
not done it yet17/04/2018 12:24:49
4877 forum posts
18 photos
Posted by J Hancock on 17/04/2018 10:22:30:
It should not. There should be a weep hole to allow any water, which might pass the seal, to drain away without affecting the bearings. If no weep hole it is a crass design. It is often the bearings failing, that does the seal in. Chicken and egg situation. 1800 spin speed with a horizontal drum and undersized bearing was what caused the hotpoint to fail.
Mark Rand17/04/2018 13:08:42
918 forum posts
6 photos
When things like this happen, should we not be taking the failed household appliances back to the shop and pointing out (loudly and lengthily, if needed) That the Sale of Goods and Services Act indicates that 6 years is a reasonable life for a consumer durable and it's the point of sale's responsibility to put things right?
duncan webster17/04/2018 13:43:51
2734 forum posts
40 photos
If you bought it from Curry's you will be wasting your time, they don't think that Sale of Goods Act applies to them. I will never buy anything from them again
Neil Wyatt17/04/2018 15:00:41
18133 forum posts
713 photos
77 articles
Posted by duncan webster on 17/04/2018 13:43:51:
It doesn't apply to anyone. It was superseded in 2015 by the sale of goods act.
Legislation.gov.uk:
"There are currently no known outstanding effects for the Supply of Goods and Services Act 1982."
richardandtracy17/04/2018 15:52:48
943 forum posts
10 photos
A few years back I had a hard drive recorder fail at age 4 months. I took it back to Curry's clutching a printed copy of the Sale of Goods Act, and after making such a fuss that the Manager came out, they honoured their legal obligations. In full.
Richard.
Hacksaw17/04/2018 16:05:27
428 forum posts
173 photos
Ahah , the inner bearing is NSK and Made in England ..and it's contaminated with horsehair and mud..The expander (or contractor spring ,I suppose ) spring ring bit on the back of the seal has disappeared ,so there would have been no sealing
This is what happens when partners and offspring wash horse rugs , horse boots and trainers covered in mud..in a domestic appliance ..angry (Could explain why my pants give me itchy bollocks after washing..!)
I did find £3.22 in the drum however , but they're the old round £ coins sad
New SFK bearings and seal are on their way £25
George Clarihew17/04/2018 22:13:09
80 forum posts
Posted by not done it yet on 17/04/2018 12:24:49:
During nearly 26 years on the job, virtually all the machines I repaired and saw a telltale trail from the weep hole by the drum bearing signalled that the bearings, although they sounded and felt servicable at the time, were not long for this world. I reckon the drum seal gave up first and the damp and soapy environment then went for the bearings.
The old fashioned spring wire bones from corsets wrapped round the shaft were instant seal wreckers even though the machine was stopped as soon as the noise made itself known.
Mike Poole17/04/2018 22:37:25
2699 forum posts
64 photos
I have had to recover the wire from a bra in a neighbours washing machine, was making a bit of a click as it went round but as I am only 61 corsets are out of my experience😉
john carruthers18/04/2018 08:47:40
606 forum posts
177 photos
We have purchased several sets of bearings from Arc, some for machine use, some for light duties in telescope mounts, no problems..
Ian Hewson18/04/2018 09:04:50
261 forum posts
24 photos
Regarding Curry’s, I can only say what happened to me.
My two year old Samsung fridge freezer started forming ice sheets at the bottom of the freezer.
Curry’s repair people came round the next day and fitted a new defrost element which unfortunately did not solve the problem.
They made a further three visits and fitted new parts to no avail and then have me a voucher for the cost of a new machine at today’s price, which was considerably more than I paid originally, plus refunded the remainder of the 5 year guarantee.
I was pleasantly surprised as I had read plenty of negative comments in the past, but the repair guys said that Curry’s had made big efforts to improve there service recently.
Hacksaw08/05/2018 23:52:44
428 forum posts
173 photos
Ah , just to say it IS possible to saw the outer drum in two , after drilling (20 odd ) 3mm holes across the flange , change the bearings and reseal it with 20 odd 3mm nuts and screws, and PU sealant (Tigerseal) .
30 washes and not a drip...but I did have concerns when i bolted that lump of concrete to the bit i glued on !! Happy to leave the machine on and go out ...
2 fingers to Hotpoint... £22 for bearings and seal , 6 quid for sealantsmiley
EngineDIY
