Machine painting
Ian McVickers07/04/2018 19:20:59
174 forum posts
84 photos
Hi all,
I'm busy rebuilding my Clarkson MK1 grinder and have most parts repainted and refitted to the machine but I am looking for some ideas or pointers for painting the Clarkson name on the base casting. I have painted the name area white and would like to do the raised letters in red and keep it neat and tidy without overpainting the white background. I can't see any other way of doing this without trying to cover the area with bits of masking tape. Any ideas?
Ian McVickers07/04/2018 19:31:01
174 forum posts
84 photos
Photo of MK1
Edited By Neil Wyatt on 08/04/2018 18:15:17
mark smith 2007/04/2018 19:42:36
671 forum posts
331 photos
You can get liquid latex masking from artist  suppliers which can be brushed on with a artists brush.Then paint the letters and when dry peel the latex mask off. The result will depend on how neatly you put the mask around the lettering.
Edited By mark smith 20 on 07/04/2018 19:45:47
Michael Gilligan07/04/2018 19:43:58
15450 forum posts
668 photos
Would a paint-roller do the trick, I wonder ?
daveb07/04/2018 21:26:56
621 forum posts
10 photos
If the background paint is dry the job can be done by hand with an artists brush, any overpainting can be cleaned off immediately with a cotton bud moistened with white spirit. You need a steady hand for this, a hand rest can help, signwriters use them, just a stick with some padding on the end.
Nice paint job!
Edited By daveb on 07/04/2018 21:27:54
Ian McVickers08/04/2018 17:25:20
174 forum posts
84 photos
Thanks guys. Went for the roller idea. Masked off the area around the name and used a cut down gloss foam roller. Turned out pretty good. A bit of cleaning and a few touch ups and its done. Managed to get the table cleaned up and refitted today as well.
Edited By Neil Wyatt on 08/04/2018 18:16:13
Michael Gilligan08/04/2018 17:57:58
15450 forum posts
668 photos
Lovely job, Ian yes
Vic08/04/2018 18:06:08
2489 forum posts
14 photos
Yes indeed, nice job! yes
Watford08/04/2018 18:28:31
126 forum posts
11 photos
With signwriting like that you should be able to depose Foggy Dewhurst in Last of the Summer Wine.disgust
Ian McVickers08/04/2018 19:18:09
174 forum posts
84 photos
Thanks guys. Neil thanks for fixing the photos. They were the right way up when I uploaded them and don't know why they got rotated.
Ian McVickers21/05/2018 20:55:58
174 forum posts
84 photos
I thought I would add an update to this as the machine is more or less finished. It's now powered via a vfd with stop/start, EStop and reset controls. A worklight is also fitted. All that's left to do is to make a blanking plate to cover the hole left from the old starter unit, some new tee slot bolts and a captive nut for the universal holder. It's been a nice little project.clarkson mk1 1.jpg
Hopper22/05/2018 00:20:59
4379 forum posts
92 photos
Very nice job indeed. And a very handy machine for the home shop.
I found our local hardware store sells tiny little "cutting in" paint rollers for getting into corners etc when painting. About 50mm long and 25mm diameter roller. One worked perfectly for the raised lettering on our Myford.
