Howell Twin Four Stroke - completed item
A video of my completed Howell Twin 4 stroke model engine
CorRad28/03/2018 02:19:29
19 forum posts
I have completed building the Howell Twin 4 stroke. The link below takes you to a video of the completed engine:
Edited By Neil Wyatt on 28/03/2018 10:42:25
Michael Gilligan28/03/2018 08:36:17
14749 forum posts
635 photos
Presumably because YouTube 'knows' that I am using an iPad ...
using your URL takes me to
https://m.youtube.com/watch?feature=youtu.be&v=F44qslr_AEA
... and that displays a black window with white text, stating:
This video is unavailable
sad perhaps I am not worthy
Edited By Michael Gilligan on 28/03/2018 08:37:54
Perko728/03/2018 08:43:15
291 forum posts
23 photos
Found it at this address:
https://www.youtube.com/watch?v=F44qsIr_AEA
Michael Gilligan28/03/2018 09:36:39
14749 forum posts
635 photos
Posted by Perko7 on 28/03/2018 08:43:15:
Thanks yes
That one works
Edited By Michael Gilligan on 28/03/2018 09:37:34
Joseph Noci 128/03/2018 09:41:07
559 forum posts
843 photos
Hello Corad.
Brilliant Engine! Runs great and looks fantastic. Very well done, and certainly done in a short time!
While looking at the video, I saw this one...Amazing how inventive folk are!
Joe
https://www.youtube.com/watch?v=eKY-UNYdDHE
Edited By Joseph Noci 1 on 28/03/2018 09:41:54
CorRad28/03/2018 10:37:00
19 forum posts
Apology for the problem with the link. I typed the address in stead of copying the link as a hyperlink. The link below works. Thank you Joe I enjoyed the building. The engine made from car scrap is certainly very innovative.
https://youtu.be/F44qsIr_AEA
Neil Wyatt28/03/2018 10:42:55
17044 forum posts
690 photos
76 articles
Embedded it.
Nice work Conrad!
not done it yet28/03/2018 10:54:27
3897 forum posts
15 photos
Is it fuelled by metanol in order to run cooler? I note there is no forced air cooling.
I think the advantages of a shorter, stiffer crank is better in the V formation, rather than a 360 degree crank in an in-line configuration.
Nice work and runs well.
Trevor Crossman 128/03/2018 11:18:46
125 forum posts
22 photos
Congratulations CorRad, your result of six months labour looks and sounds very good indeed.
Trevor.
CorRad28/03/2018 11:30:20
19 forum posts
Methanol is used primarily because the emissions are much cleaner. There are two 50mm diameter computer style cooling fans on the front of the engine aimed at the heads. The drawings actually calls for a sheath over these fans that result in much more effective cooling. However, the look of the engine without these sheaths appeals more to me. The longest time that I have run the engine continuously was for 10 minutes. The heads certainly did get relatively hot but not to the extend that it was considered a problem. Should I want to run this engine for long periods, I will certainly have to add these sheaths. I agree with your remark regarding the short crank.
daveb28/03/2018 17:24:52
621 forum posts
10 photos
CorRad, very nice indeed!
Daveb
John Rudd28/03/2018 20:27:48
1367 forum posts
58 photos
Does the starter motor remain engaged while the engine runs?
CorRad28/03/2018 21:05:58
19 forum posts
Good question. When I had to make decisions about the starter motor, this did worry me. Yes, the starter motor remain engaged after the motor has started. The life time of the starter motor bushes is therefore in question. However, this allows the starter motor to be used as a dynamo to charge the battery.
John Rudd28/03/2018 21:41:16
1367 forum posts
58 photos
Posted by CorRad on 28/03/2018 21:05:58:
Just be careful that the engine does not over rev the starter motor....there is a risk of bursting the windings on the armature....I know...I have done it on a car! The starter got jammed with the flywheel gear...
CorRad28/03/2018 22:11:50
19 forum posts
Thanks for that information.
Ian S C29/03/2018 10:34:46
7466 forum posts
230 photos
A car starter motor is usually between 15:1 and 20:1, where as the starter on CorRad's motor is nearer to 4:1.
Ian S C
CorRad29/03/2018 11:46:57
19 forum posts
Correct Ian S C. Initially, this caused a problem in that the starter motor does not have enough torque to turn the engine when it is one of its compression strokes. In order to start the engine using the mopet starter motor, I have to manually turn the flywheel in the opposite direction that it normally runs, until a compression stroke is reached. When the starter motor is energised it can then build some momentum before a compression stroke is reached. This works fine and the engine is easily started as can be seen on the video.
thaiguzzi29/03/2018 15:35:20
618 forum posts
131 photos
Impressive, pretty, like it.
Ian S C30/03/2018 10:33:23
7466 forum posts
230 photos
Starter motors are usually series wound, so not ideal as a battery charger, but a modern starter may have permanent magnet fields. A generator for battery charging with wound fields needs to be shunt wound.
Ian S C
CorRad04/04/2018 02:58:07
19 forum posts
I have uploaded two videos of my other completed engines. The links are below: https://youtu.be/_PH-iE7YmdY​ https://youtu.be/bZX-ajNffrY
Edited By JasonB on 04/04/2018 07:20:50
Edited By JasonB on 04/04/2018 07:43:11
