DC motor controler ?
C T20/03/2018 17:59:45
38 forum posts
I have a DC motor
http://www.arceurotrade.co.uk/Catalogue/Machine-Spares/C1-Lathe-Spares/C1-19-Motor
I would like to control the spindle speed could anyone advise if this product would fit the bill?
https://uk.rs-online.com/web/p/dc-motor-controllers/1034042/?searchTerm=103-4042&relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D626572266C753D656E266D6D3D6D61746368616C6C26706D3D5E285C647B362C377D5B4161426250705D297C285C647B337D5B5C732D2F255C2E2C5D5C647B332C347D5B4161426250705D3F292426706F3D3126736E3D592673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D3130332D34303432267374613D3130333430343226
Muzzer20/03/2018 18:06:59
2904 forum posts
448 photos
Seems to be a controller for a single phase induction (AC) motor. Not unusual for the pen pushers at RS to describe something they don't have a clue about and get it completely wrong.
Short answer - no.
Murray
And all the DKM motors listed on the RS site are described as "reversible AC induction motor" and are truly piddle power. You'd struggle to even turn a machine with them, so presumably the controller is also miniscule. Not the most informative datasheet.
Edited By Muzzer on 20/03/2018 18:09:45
C T20/03/2018 18:26:22
38 forum posts
Posted by Muzzer on 20/03/2018 18:06:59:
Short answer - no.
Murray
Thank you for the reply Muzzer I was confused RS called it a DC controller but DKM said it was AC.
Will keep looking
norman royds 220/03/2018 18:50:08
45 forum posts
The one I am using is cheetah SME 2HP input 110 /220 240 ac 16 AMPS 50/60hz output ;0.90/0.180v dc 11AMPS so it give somewhere to start carl hope this some help regards norm
C T20/03/2018 19:24:15
38 forum posts
Posted by norman royds 2 on 20/03/2018 18:50:08:
Thank you Norman for the information.
oldvelo20/03/2018 19:45:41
193 forum posts
48 photos
Hi
More info on the end use would be useful. Assumption is mother of all misunderstanding
X1 Mill ?
No connection with KB Electronics on my part just satisfied user
Start looking here
Expensive but very reliable
More here using one from this source using one on a band saw.
John Haine20/03/2018 20:02:27
3013 forum posts
160 photos
I also use a KB Electronics one on my Novamill spindle.  It works very well, have never had anything blow except a fuse when the mill decided to execute a "G0" rather than "G1" feed into the material, stakllked the motor and broke the cutter.
Edited By John Haine on 20/03/2018 20:04:06
C T20/03/2018 20:16:50
38 forum posts
Posted by oldvelo on 20/03/2018 19:45:41:
Hi
X1 Mill ?
The motor was fitted to a Sieg C1 lathe now to be used on a milling attachment on a Clark C1 lathe with the lathe head stock missing so the controller is not present. So I have the lathe bed with the cross slide milling attachment fitted but no controller.
Is anything that RS components sell useful to me?
I wish I knew what I was doing.
Edited By carl timmins on 20/03/2018 20:20:47
Edited By carl timmins on 20/03/2018 20:21:29
oldvelo22/03/2018 02:30:34
193 forum posts
48 photos
Hi Carl
Here is another link to a unit that may be useful. RS are way off with there description it is NOT AC to DC at all is is for a low power AC motor ( Extractor Fan)??? perhaps
Set up seems to be straight forward enough with the controller to match the motor.
Eric
Edited By oldvelo on 22/03/2018 02:35:32
C T24/03/2018 15:58:51
38 forum posts
Thank you for your help EricPosted by oldvelo on 22/03/2018 02:30:34:
Hi Carl
Eric, thank you for your help but the one listed is for 110Volts I need 250Volts. I did not think that obtaining a speed controller would be so much trouble. It was my trying to get a small milling machine for little money but I am now going to purchase a machine to get me started. I have a vertical slide for my lathe but it sure has its limitations with my skills and ancillary tooling.
Michael Cox 124/03/2018 16:41:25
529 forum posts
27 photos
Hi Carl,
Here is a motor/ controller combination similar to the one posted by oldvelo. This one is rated for 240 volts and available in the UK.
https://www.aimtools.co.uk/collections/spare-parts/products/katsu-550w-power-head-attachment-for-mini-lathe-machine-165013-and-165012
John Rudd24/03/2018 17:01:07
1368 forum posts
66 photos
Carl,
As the motor came from a Sieg mill, why not use the intended controller..? The XMT2315/230V.
Available from a Sieg dealer near you....Arceurotrade....
That way it minimises any setup issues with min/max speed settings and any overload/over current issues.
Edited By John Rudd on 24/03/2018 17:01:24
C T24/03/2018 17:35:44
38 forum posts
Posted by Michael Cox 1 on 24/03/2018 16:41:25:
Hi Carl,
Mike, That looks interesting Thank you.
Carl
C T24/03/2018 17:43:50
38 forum posts
Posted by John Rudd on 24/03/2018 17:01:07:
Carl,
John, I have looked at purchasing from Arceurotrade but as far as I can see I would have to purchase each individual part of the controller get a case to fit them in and wire it all up. I do feel useless in having to say this but I am sure that is beyond me, take three wire from a controller unit to the motor and three wires from my socket outlet to the controller unit is probably the best I will be able to do.
C T24/03/2018 18:17:42
38 forum posts
Carl,
I have had a second look at purchasing the parts from Arceurotrade and the total price for all the parts minus the case, internal wire and suitable connectors will be around £120.00 I have also found a wiring schematic attached it is for the Clark CL250m lathe but I am told it will be the same.
How difficult would it be the assemble and wire a controller remembering I have very little electrical knowledge.
John Rudd24/03/2018 20:08:46
1368 forum posts
66 photos
I'm sure we can get you up and running...even if we have to do a point to point, step by step method of wiring up....
But I stress the choice is yours......!
C T28/03/2018 17:38:01
38 forum posts
Posted by John Rudd on 24/03/2018 20:08:46:
John, Thank you for the offer of assistance but I have had good look around and will be purchasing a complete machine the Sieg X2.7 looks favorite.
