Ian Parkin | 08/03/2018 17:28:21 |
![]() 1017 forum posts 236 photos | Has anyone any idea what this connector is called or where to buy from? Its on a fancy new battery charger i’d Like more ends to put on different vehicles Edited By Ian Parkin on 08/03/2018 17:28:49 |
V8Eng | 08/03/2018 17:36:05 |
1696 forum posts 1 photos | I think they are usually called bullet connectors, available from: RS, Maplin, Halfords and a host of other suppliers. Edited By V8Eng on 08/03/2018 17:38:58 |
Clive Brown 1 | 08/03/2018 17:36:16 |
807 forum posts 39 photos | Try googling twin bullet connector |
Mike Poole | 08/03/2018 17:52:13 |
![]() Moderator 3306 forum posts 73 photos | I think that may be a proprietary connector, have a look at the Vehicle Wiring Products website, they have a wide range of vehicle stuff and you may find an alternative that may mean changing all of the connectors. Check their DIN connectors. Mike |
I.M. OUTAHERE | 08/03/2018 18:09:31 |
1468 forum posts 3 photos | Its called an SAE connector . A twin bullet connector looks similar but is not the same . |
Dave Daniels | 08/03/2018 18:15:29 |
83 forum posts | Looks somewhat like what I once knew as a 'CES QD' connector. One ref. I found but you won't be interested ... www.amazon.co.uk/Disconnect-Harness-Connector-Bullet-Coast/dp/B00MYDR18A
D.
Mike E. | 08/03/2018 18:19:37 |
![]() 217 forum posts 24 photos | Its a common connector used in the USA used for 12 volt wiring, such as for splicing in temporary light connections into a vehicle wiring harness when renting utility trailers. |
Neil Wyatt | 08/03/2018 18:58:52 |
![]() Moderator 18992 forum posts 734 photos 80 articles | I've had a few of those on 12V equipment. Neil |
Andy Holdaway | 08/03/2018 19:01:15 |
![]() 167 forum posts 15 photos | Ian, plenty on Ebay if you search for SAE Connector like this. Andy |
peak4 | 08/03/2018 19:04:36 |
![]() 1675 forum posts 179 photos | This one is slightly more affordable, provided you don't mind waiting for delivery from China or a bit dearer from the UK On the other hand a pair of bullet connectors and some Aldi/Lidl epoxy putty to make the bodies. Shame Bardwells closed really. |
Ian Parkin | 09/03/2018 09:13:58 |
![]() 1017 forum posts 236 photos | Many thanks everyone ces ordered from amazon at a reasonable price |
