can i silver solder cast iron
Brett Hurt27/02/2018 22:56:17
23 forum posts
5 photos
I work on old phonograps those old things you crank up. And on working on this one I broke a part and need too know if I can silver solder it back. And what do I need for this, I have never silver soldered?.
Neil Wyatt27/02/2018 23:06:41
17716 forum posts
697 photos
77 articles
Yes. Even I can do it
One approach is to heat bit red hot and let it gcool, this burns off surface carbon. Then flux, reheat and silver solder as normal.
Keith Hale's book goes into some detail on teh subject.
Alan Charleston28/02/2018 06:21:21
83 forum posts
20 photos
Hi Brett,
If you have a nice crisp break with the two bits fitting snugly together you might like to try gluing it together with an epoxy glue such as araldite. This can give a high strength joint which may be OK for your application.
Alan
Tractor man28/02/2018 06:30:59
426 forum posts
Brett.
If the part is under strain such as part of the clockwork mechanism I thunk silver solder would be best. But if it's not load bearing I would agree that gluing the break would be far easier.
I use JB weld which is available on line but apparently Halfords do a similar type metal epoxy that is just as good. Worth a try before the problem of silver soldering if you've never done it before.
Best regards Mick
Speedy Builder528/02/2018 07:10:32
1984 forum posts
139 photos
As Neil says, but after the first heat up to dull red, let it cool and wire brush the joint to remove the 'burnt off' carbon, then re-heat to silver solder or braze.
BobH
Stewart Hart28/02/2018 07:11:15
627 forum posts
334 photos
Posted by Neil Wyatt on 27/02/2018 23:06:41:
As Neil said but give the parts a good wire brushing to get rid of the ash/crud after it cools, I've used this method and it worked for me.
Stew
speelwerk28/02/2018 09:48:24
361 forum posts
The few times I have done it I sandblasted the parts first. Niko.
Brett Hurt28/02/2018 13:24:51
23 forum posts
5 photos
thanks for the info
