Ian Parkin | 23/02/2018 08:40:15 |
![]() 1016 forum posts 236 photos | I've never seen these used before what are they? the components in beige with a centrally positioned black line mainly unmarked on the board |
Frances IoM | 23/02/2018 08:46:10 |
1247 forum posts 28 photos | 2 are marked as being resistors on board - possibly being what appears to be a single sided board they are cross links or removable test links |
Ian Parkin | 23/02/2018 08:51:43 |
![]() 1016 forum posts 236 photos | Yes i did say they were links what are they called and why in a resistor type package |
Bodger Brian | 23/02/2018 08:52:37 |
![]() 187 forum posts 40 photos | Posted by Ian Parkin on 23/02/2018 08:40:15:
I've never seen these used before what are they? the components in beige with a centrally positioned black line mainly unmarked on the board they are links but why in the resistor type package? Basically they're 0R resistors, used in this instance as links. The black band 'follows 'the standard resistor band coding, black signifying zero. The resistor type package is probably used so that it can be auto-inserted by machine. A simple wire link couldn't be handled that way and would need hand insertion. Brian |
Dave Daniels | 23/02/2018 08:53:06 |
83 forum posts | Zero Ohm Links http://www.wikiwand.com/en/Zero-ohm_link
Ian Parkin | 23/02/2018 09:04:57 |
![]() 1016 forum posts 236 photos | well i'll be blowed i.ve never seen those before on any item of equipment i've repaired thanks |
Bodger Brian | 23/02/2018 09:06:49 |
![]() 187 forum posts 40 photos | Posted by Ian Parkin on 23/02/2018 09:04:57:
well i'll be blowed i.ve never seen those before on any item of equipment i've repaired thanks Very commonly used... Brian |
Martin Kyte | 23/02/2018 09:33:06 |
![]() 2721 forum posts 48 photos | You also get them in Surface Mount. regards Martin |
Neil Wyatt | 23/02/2018 10:42:38 |
![]() Moderator 18990 forum posts 734 photos 80 articles | I've never seen ones like that before, 0R SMT resistors yes, but not ceramic package. Presumably it simplified manual assembly. Much more interesting is what it comes from Neil |
John Rudd | 23/02/2018 11:23:10 |
1452 forum posts 10 photos | |
Ian Parkin | 23/02/2018 11:51:03 |
![]() 1016 forum posts 236 photos | Yes neil it comes from that I try to play but better with banjo
Ian |
Ian Parkin | 23/02/2018 11:52:07 |
![]() 1016 forum posts 236 photos | I have just ordered some for my stock £1.25 for 50 delivered !! |
Neil Wyatt | 23/02/2018 17:36:03 |
![]() Moderator 18990 forum posts 734 photos 80 articles | I have an ancient Laney Pro-Bass head with two 2x12 cabs and a tweeter box (because they were easier to carry up fire escapes than a 1x15 bigger than and heavy as a washing machine). Last year I got an orange Crush 20 practice amp, which is nice Neil |
