Forum sponsored by Allendale Nov 29
Parting off blade
sean logie19/02/2018 08:06:50
584 forum posts
86 photos
Just curious to what people use , I saw an article somewhere what a guy cut a section out of a carbide tipped wood cutting rip blade . Curiosity got the better of me so I tried it , works like a charm up to 40mm material, aliminium, steel and stainless. I've had a few scares whilst using a normal parting blade but with the carbide tipped saw blade I am growing in confidence. Curious if anyone else has tried this .
Sean
Geoff Theasby19/02/2018 09:26:48
567 forum posts
14 photos
I think it was in 'Instructables'.
Geoff
Douglas Johnston19/02/2018 09:33:27
528 forum posts
24 photos
It is not only parting blades that can be made this way, I have in the past used this technique to make various special cutting tools. I picked up some bargain blades a number of years ago and have been nibbling away at them for ages to make lathe cutters. It is a very cheap way of getting carbide cutting tools.
Doug
JasonB19/02/2018 10:04:46
14313 forum posts
1380 photos
Latest MEW has an article on using cut up saw blades
larry Phelan19/02/2018 12:41:08
544 forum posts
17 photos
I used something like this only recently,when I needed to cut narrow groves to take cir clips. Having nothing else to hand,I used a short length of broken hacksaw blade fitted to a holder held in the tool post. The holder was simply a piece of scrap 5/8" square with a slot cut in it and two small screws to clamp the blade. I t worked a charm,and replacements are cheap.
Neil Wyatt19/02/2018 12:49:09
15207 forum posts
641 photos
72 articles
Posted by JasonB on 19/02/2018 10:04:46:
HSS slitting saws, but the principles are the same.
Colin LLoyd12/06/2018 15:26:49
191 forum posts
17 photos
Perhaps being a novice, I find "parting-off" to be the most imprecise, "fingers-crossed and hope" operation on the lathe. I've given up with it. I now just cut a V-groove where I want to part off - to a depth that provides a guide slot for a hacksaw blade to run in, and then just gently run the hacksaw back and forth while the lathe is turning. It works - and I know it will work every time - and the finish is good enough to only need a light facing-off if necessary. Because the V-groove operation works so well - I'm thinking of grinding a V-point onto the front edge of a parting tool to see if that makes the classical method work better for me.
roy entwistle12/06/2018 15:35:41
901 forum posts
I find that a V groove in the front of a parting tool can help. Don't be frightened get stuck in.
Roy
Neil Wyatt12/06/2018 16:01:33
15207 forum posts
641 photos
72 articles
As Roy's post suggests, most parting problems are caused by lack of confidence. Few of us would worry about taking a normal cut the same depth as the width of our parting tool. I think most problems come from two things:
Chips jamming in the cut, lubrication or a shaped tool tip help here.
Lack of positive feed, so the tool alternately rubs then grabs. When it grabs all the factors that upside down toolposts, rear toolposts and 101 other 'solutions' come into play.
Confident feed is the route to success for most of us. This is on my mini lathe:
I've discovered high speed parting off under power feed with carbide works brilliantly - but on aluminium a constant supply of lubricant is essential top stop it welding to the tip. 500rpm for 50mm 6082 is easily achievable but <300 rpm reduces the tendency to weld.
KWIL12/06/2018 16:09:25
3039 forum posts
55 photos
This is PB parted, 4" diameter, surface finish OK Standard blade insert.Bk 5 Dome Blank
mechman4812/06/2018 17:59:33
2197 forum posts
370 photos
Have you tried a rear tool post holder set up ?
George.
Vic12/06/2018 18:09:11
1871 forum posts
10 photos
I’ve tried the old style HSS blades and carbide inserts but find the T shape HSS blades with chipbreaker to be the best.
On a small lathe without coolant carbide inserts can work out expensive.
jimmy b12/06/2018 18:55:08
422 forum posts
27 photos
I'm a rear tool post man on both my lathes.
Parting off and grooving is no longer feared!
JIm
Andrew Johnston12/06/2018 19:33:27
4309 forum posts
511 photos
On the manual lathe parting off is done with 3mm carbide inserts. Dry on cast iron and brass, flood coolant for everything else. To avoid chatter and other nasties minimum powered feedrate is 4 thou per rev, I normally use 6 thou per rev. There's no problem going deep:
Parting Front Wheel Hub
For grooving on the manual lathe I use HSS, the carbide inserts chatter if you try and creep up on an important dimension.
On the repetition lathe I use HSS blades. I don't drop the speed for parting off, so normally done at 1000rpm. Feed is by hand, but the swarf is around 8-10 thou thick.
I haven't bothered with a rear toolpost, never felt the need. Ok, so the parting tool on the repetition lathe is at the back, but it's the right way up and the normal running direction of the lathe spindle is backwards. So it doesn't count. smile
Edited By Andrew Johnston on 12/06/2018 19:34:08
Howard Lewis12/06/2018 21:35:59
1597 forum posts
I have used a secondhand HSS parting off blade in the rear toolpost for fifteen years. Dig ins are almost unknown.
Used a shop made rear toolpost on the Myford for several years before that.
The last time that I used an inserted tip parting tool in the front toolpost, (last week!) it dug in twice and broke the tip each time. This was an expensive prelude to using the hacksaw and then facing. (The normal, four way indexing, back toolpost had been removed to display at an exhibition!)
There are various theories advanced as to why the rear toolpost method is superior, but valid or not, in practice it works better for me!
A steady infeed is important, don't be heavy handed, but don't be frightened.
Hopper14/06/2018 02:52:08
3074 forum posts
50 photos
I'm sure I saw the carbide saw blade cut up for parting tool idea in an ancient back issue of MEW some years back. Have had an old blade sitting under my lathe since then waiting to be chopped up. But my standard HSS 1/2" x 3/32" mounted upside down in the rear tool post will cut up to 2" diameter steel without dramas so have not bothered. I usually dribble a little cutting oil/water mix on it as I go. Run the lathe one speed slower than I would for turning, so about 100 rpm for 2" steel bar. Steady infeed is indeed important too, as Howard says, although I like to briefly withdraw the tool from the groove every now and then, let it cool off and the chips clear and the cutting oil get in there..
Edited By Hopper on 14/06/2018 02:53:41
Edited By Hopper on 14/06/2018 02:58:21
thaiguzzi14/06/2018 05:59:24
481 forum posts
104 photos
Hopper,
that is one beautiful rear toolpost. Love it.
Hopper14/06/2018 06:50:27
3074 forum posts
50 photos
Posted by thaiguzzi on 14/06/2018 05:59:24:
Hopper,
It came with my old M Type Drummond when my old man bought it many years ago. Presumably made by a previous owner as I've never seen another like it. It's a beauty. Solid as.
Edited By Hopper on 14/06/2018 06:51:02
Clive Foster14/06/2018 09:25:50
1532 forum posts
42 photos
One evil, but easily overlooked, gotcha when parting off with tools held in QC or 4 way tool posts where the cut axis is significantly offset to the tool post fixing is the significant twisting force on the whole assembly. I've lost a couple of parting blades and an insert holder that way when the QC post shifted slightly under the temporary extra loading of a chip hanging up. Both times in difficult materials.
Fairly sure that the root cause in my case was using synthetic cutting oil. Rocol Ultracut at book dilution to be specific. The stuff eventually gets everywhere, is seriously slippery and a right pain to clean off fully.
Finally twigged to that problem after wondering for several years why my Pratt Burnerd 180 mm precision 3 jaw chuck, bought new and not abused, didn't seem too be holding as well as it used to. Full strip & rebuild didn't fix the problem so I showed the gripping faces to a fine rotary wire brush. After some fairly aggressive attention the faces looked good and subjectively had a proper "plain metal" feel. Instant fix. Grip back to what it always was.
A more common reason for tool posts being prone to twist is top slide distortion. Its important that the post sits down on the outer parts of its base rather than close to the centre. Clearly the further out from the centre the main contact points are the more leverage it has against twisting. Most tool posts have the centre relieved to help ensure that. However the relieved centre provides no support to the topside around the stud so after many years the top can distort slightly significantly reducing full pressure contact area. This is quite likely with Tee slotted top slides when used with a short Tee nut. Especially so if the nut is shorter than the relieved centre portion of the tool post base. Much better to use a long Tee nut extending the whole width of the slide. The top slide on my big Pratt & Whitney had suffered badly in this fashion. Had to re-work the whole Tee slot, both top and bottom, for a secure hold and plenty of contact area. Previous owners just used a bigger spanner which eventually proved counter productive.
A thin card or alloy "gasket" under the tool post often helps as being able to deform slightly to take up small errors.
Clive.
Edited By Clive Foster on 14/06/2018 09:26:08
mark costello 114/06/2018 14:09:54
470 forum posts
10 photos
As a bit of bits and braces double security parting off tool. I bought one of the new style parting tools with the carbide insert, and since I needed a holder any way I mounted it upside down, getting the best of both worlds.Can't be too careful parting off.
méridienne Nov 18
TRANSWAVE Converters
Shapiro
