Martin Faulkner | 09/02/2018 21:42:45 |
85 forum posts 32 photos | I have just acquired a box of lathe tools from a retired engineer. I am unable to ask the chap so was wondering if anyone can shed some light on this? Polishing maybe? [URL=http://s44.photobucket.com/user/Newtoboxford/media/IMG_20180209_213843_zpsfoko8wj3.jpg.html][IMG]http://i44.photobucket.com/albums/f10/Newtoboxford/IMG_20180209_213843_zpsfoko8wj3.jpg[/IMG][/URL] |
Martin Faulkner | 09/02/2018 22:16:48 |
85 forum posts 32 photos | |
vintagengineer | 09/02/2018 22:36:25 |
![]() 468 forum posts 6 photos | It could be either a primer powder for firearms or ceramic material.
Nick Hulme | 09/02/2018 23:37:48 |
750 forum posts 37 photos | Propellants are bought as powders, but not primers, unless you're talking makeup |
peak4 | 10/02/2018 01:50:17 |
![]() 1714 forum posts 183 photos | I assume a lump of Sintox ceramic, rather than anything to do with ammunition. Did they make model IC engines? Material for spark plugs or magnetos etc?? |
I.M. OUTAHERE | 10/02/2018 04:59:44 |
1468 forum posts 3 photos | I googled sintox and found that it has something to do with either lasers ( reflector or diffuser ) or bullet proof body armour . The material looks to be of similar composition to the stuff tig gas nozzles are made of . The images i found of the body armour looked very similar to the one you have shown . Have you tried measuring it ? I wonder how accurately made it is . |
SillyOldDuffer | 10/02/2018 09:48:48 |
Moderator 8695 forum posts 1967 photos | I reckon it's a manufacturer's sample. peak4's link takes you to the website of Morgan Advanced Materials. They sell exotics. I rather like the idea using them. How about a Model Engineer project requiring parts to be made of Pyrolytic Boron Nitride and coated with Diamond Like Carbon. Steel, Brass and Aluminium are so prêt-à-porter . ME fashionista's should never use such dreadful tat in quality workshop Haute Couture... Dave
Edited By SillyOldDuffer on 10/02/2018 09:49:45 |
peak4 | 10/02/2018 11:54:07 |
![]() 1714 forum posts 183 photos | Have a look HERE, there are a number of grades of Sintox, besides lasers and body armour. hence my query about the original owners engineering interests.
Bill |
Martin Faulkner | 10/02/2018 12:13:20 |
85 forum posts 32 photos | Hi everyone. I did do a search and more or less found these answers. I am unable to find out what the chap did as he passed some years ago and I acquired it from someone who got his house so I don't have a way of finding out. I do find it interesting look if through old tools and try and piece together the history hence this post. I have found a lot of bearings both roller and thrust. Ba and bsw taps from small to large along with thread chasers and a small 2 inch 4jaw. There are also lots of reamers. I did read somewhere that it can be used for polishing metals but not sure how true that is. |
Martin Faulkner | 10/02/2018 12:17:08 |
85 forum posts 32 photos | Just to add another note, I live in the area of bae systems, airport and what was tvr. There are also a few small engineering places around the Blackpool area. |
Martin Faulkner | 10/02/2018 20:30:21 |
Martin Faulkner | 10/02/2018 20:32:14 |
85 forum posts 32 photos | This is more unknown items, I know one is a reamer but not sure on the use if it with the extra on the end. And one is a knurling tool, but what it fits, can anyone help? |
JOHN MOSLEY 1 | 10/02/2018 21:00:59 |
10 forum posts | The serrated disc are out of a grinding wheel dressing tool. ??
Martin Faulkner | 10/02/2018 21:14:18 |
85 forum posts 32 photos | Posted by JOHN MOSLEY 1 on 10/02/2018 21:00:59:
Come to mention it, yes there are a lot of grinding wheels in the box so would make sense. I have only ever seen them attached to handle. |
Martin Faulkner | 10/02/2018 21:14:19 |
Sam Longley 1 | 10/02/2018 22:04:32 |
942 forum posts 34 photos | The item on the top left looks like a blank that goes in a 4 jaw cutter block for a woodwork spindle moulder or moulding machine . I had several. The knives were serrated backed. If I only put 2 knives in the cutter block there would be nothing to put in the 2 spare spaces so the clamps would fall out. therefore, one would put a piece of serrated steel in the space & clamp it tight. For a 65 wide * 100 diam block it would be ( from memory) about 25mm * 65mm * 8 mm Th the ends & edge that goes into the block would be square. The edge that goes flush with the block would be slightly rounded. Sometimes the piece would be shaped rather like the cutter form but set back a bit. This was to stop the cutter digging into the wood too deep & causing an accident. On a moulding machine we did not bother but on a spindle moulder we would use them Edited By Sam Longley 1 on 10/02/2018 22:08:08 |
Waggonerman | 10/02/2018 22:27:50 |
12 forum posts 5 photos | The item on the right looks like a broken Tap Remover, probably a three flute. |
Grindstone Cowboy | 10/02/2018 22:30:52 |
858 forum posts 64 photos | The reamer could possibly be the special tool for reaming rear radius arm bushes on a Mini - the 'extra' bit on the end would locate in the needle-roller bearing. This is just a wild guess, by the way |
norman royds 2 | 10/02/2018 22:44:40 |
48 forum posts | the item on the right is a broken tap remover they do three and four the one under star dresser is old dye block has the reamer split in it and two look like part off roller box capstan or ward lathe regards norm |
D.A.Godley | 10/02/2018 22:45:22 |
120 forum posts 39 photos | Top left looks to me like a tangential thread cutting piece from a Landis head ,top right tap removal tool , centre next to reamer appears to be a knurling tool . Pass on other items . |
