Taper Reamer and Classifieds
Phil Steele03/02/2018 23:43:28
2 forum posts
I am looking for suggestions on making a taper reamer for woodworking.
The reamer needs to go up to 35mm with a 6deg taper.
Any advice on the best way to achieve this would be appreciated.
I also want to qualify to use the classifieds
Phil
Emgee03/02/2018 23:53:11
1492 forum posts
217 photos
Hi Phil, what size is the small end, or what length flutes do you need ?
Emgee
JasonB04/02/2018 07:46:46
18127 forum posts
1996 photos
Simple method would be to turn your taper on a piece of silver steel and then mill away half the diameter and then harden & temper. This method is often used for cutting tapers in steam fittings though you will get some tearing in wood depending on grain direction. Could be cleaned up with abrasive paper wrapped around a similar tapered plug.
ega04/02/2018 10:09:52
1713 forum posts
150 photos
Is the reamer wanted for making a musical instrument? I am fairly sure that process has been covered in The Woodworker magazine.
John Reese05/02/2018 20:47:37
842 forum posts
A chairmaker's reamer can be pretty simple to make as shown here:
Simon Collier05/02/2018 22:17:48
352 forum posts
56 photos
Great photo, Jason.
