Forum sponsored by Allendale Nov 29
BR1 Tender tunnel
Boiler Bri30/01/2018 19:32:31
729 forum posts
277 photos
I have now turned my attention to stripping and painting the tender for my 5" Class 7 loco.
There is no tool tunnel fitted and i would like to add one.
I searched out the series by Doug Hewson, and found the article.
Using his template and dimensions i have cut and folded the parts, but they do not look correct.
It all looks bit over size and the front end looks different when folded to the picture in the article.
Can anyone help please.
Boiler Bri31/01/2018 06:35:37
729 forum posts
277 photos
Bump
Weary31/01/2018 09:20:36
275 forum posts
PM in your inbox.
Phil
Boiler Bri22/07/2018 19:43:46
729 forum posts
277 photos
Finally finished the tender rebuild and its now ready for some transfers and lining.
I thought i might have a bash at lining myself. A club friend lent me some lining pens and i had some humbrol left from a 00 model paint job. So this is what i want to paint>>>>>>>>
Brit tender
And this is my over confident practice on an old loco roof. LOL. cheeky
Old Loco roof
Now i know it dont look good, and i need to practice.
so this is my plan:-
1. the pen does not hold a lot of paint. Need a better application tool.
2. the paint was a bit thin. Buy some more.
3. you have to start very carefully or you get flooding. This one is practice.
4. its not put me off trying again. when i dont know, daughter comes tomorrow form NZ for three weeks with children. wink
If all else fails i might try Fox transfers!!!
Don't all laugh too loudly, i don't want to hear you all in Huddersfield.
JasonB22/07/2018 20:01:30
15171 forum posts
1548 photos
You need a Border pen if you want to hold more paint, they are a lot wider.
Michael Gilligan22/07/2018 20:04:43
12924 forum posts
555 photos
You have my sympathy, Brian ... and my respect for trying !!
I remember [decades ago] watching the chap in BSA, lining a petrol tank.
Tank supported on his left hand, and a fully loaded dagger brush in his right
The classic D shaped line was produced in a matter of seconds; then he flipped the tank around on his hand and did one to match on the other side [these are of course, mirror images!].
roy entwistle22/07/2018 20:17:38
946 forum posts
The draughting pen would normally use ink which I suspect would be a lot thinner than paint. Also you appear to have done the job freehand. I would recommend using a straight edge even if you use a border pen as suggested by JasonB
Roy
Jon Lawes22/07/2018 20:38:40
295 forum posts
Can I just say what a fantastic job you have made on that tender. I'll be attempting a 3.5 BR1D soon and if I can come close to the finish and fit of the one you have made I would be very happy. Nice work.
Boiler Bri22/07/2018 21:35:05
729 forum posts
277 photos
I did use a ruler on a small part and then really just played around.
I will have a look at the border pen than you.
Bri
Boiler Bri22/07/2018 21:37:04
729 forum posts
277 photos
Ah, i have one of those in the pens i was given, i thought it was too large! I will have to give it a go.
Bri
pgk pgk22/07/2018 21:46:55
1278 forum posts
278 photos
Would low-tack pinstriping tape help?
It might be awkward for the curves so perhaps this
I've not tried the latter. When i did some lining on my RC heli canopies I used the thin blue 3m tape and eyballed two parallel linesarond the curves
pgk
Paul Lousick22/07/2018 22:57:17
1043 forum posts
473 photos
Drafting pens are not suitable for applying paint. They are used with thin ink.
Pin striping is best done with a special pen with a roller at the end like a Beugler (rollers are available in different widths and combinations for painting double lines) or special  brushes with very long and thin bristles.
http://beuglereurope.com/english/index.html
Lots of videos on Youtube showing the application of pin striping.
You should also use a thicker paint, used by sign writers which contains more pigment than ordinary paint which is applied in one application only. Second layer difficult to apply.
Paul.
Edited By Paul Lousick on 22/07/2018 23:06:22
Nick Clarke 323/07/2018 07:45:43
214 forum posts
Posted by Michael Gilligan on 22/07/2018 20:04:43:
In a previous life I sold lining tape, both the type where a centre section was torn out leaving a strip either side and also the type that left a line of colour when you pulled a carrier tape away - Perhaps if the first type is still available it might help? - mind you I also remember a TV documentary about Van den Plas where they showed a strip being applied the full length of a BMC 1300 in one go with a long brush loaded with paint, like Michael saw on the tank. No guide or anything - just a steady hand and years of experience. I am deeply envious of course!
Boiler Bri04/08/2018 21:10:03
729 forum posts
277 photos
Succumbed and bought some transfers from Fox, and now i need to sit down and work out how to replace the amount of dosh they cost me crying
I will probably cover them with Humbrol clear gloss, has anyone used the stuff? I have a new unopened bottle. Does it level out good or will i end up having to paint the whole job?
Boiler Bri04/08/2018 21:21:08
729 forum posts
277 photos
I have answered my own questions:
https://www.youtube.com/watch?v=ByMhacC5vAE
Got to give this a try. Hope i get the same results cheeky
Ian Hewson04/08/2018 21:25:55
256 forum posts
19 photos
Like Michael g, I too have memories of the BSA painter doing the tank, fabulous skill.
On a visit with the electricity board students association, first time most of us had seen a melon for lunch, guessing how to tackle it without looking a fool.
Different world going from Leeds to Brum as a 16 year old apprentice.
Boiler Bri06/04/2019 20:08:42
729 forum posts
277 photos
5" Britannia
Does anyone have an automatic cylinder drain design for 5" loco's. Just watched a video on YouTube of the Sale area model engineers running day. A 9f looked to have auto drains. Mine are worked by a push pull rod from the cab and do not always work very well.
Simon Collier07/04/2019 10:53:32
283 forum posts
51 photos
Brian, you'd do better on the MECH Forum for stuff about actual models. This is really a workshop forum and questions about locos usually result in the digital equivalent of blank stares. You stay logged on over there as well. I don't post here often because of the pain of logging in. There are Brit threads on MECH.
victor mcconville07/04/2019 11:28:38
17 forum posts
Hi Brian,
I have a Beugler Pin Striping Kit , This Kit is brand new ,never been used, an impulse buy I am afraid.
Looking at their website the kit I have would seem to be a Professional Kit priced are you sitting down? £219
How ever there is no way I would have paid that amount (I have a reputation to uphold, i am Scottish and very mean.)
Joking aside this kit is of no use to me, if you are interested drop me a PM and tell me what it would worth to you if anything.
Victor J
RMA07/04/2019 17:23:09
97 forum posts
Getting back to the tunnel on the tender, from my drawings the tunnel is parallel along it's length. Yours seem to expand into a cone shape. The cross section is a strange shape because it fits within the coal chute. I'm building a 3.5 inch Brit and the tender is a laser kit which doesn't have the chute, although he's cut a hole in the bulkhead. I am trying to make the complete tunnel, which looks much better.
Looking at your photos, there seems to be a front bulkhead missing.
Allendale May 19
TRANSWAVE Converters
