Myford chuck 'oiling point'
JimmieS24/01/2018 20:52:22
290 forum posts
Have just come across a 'lost' Myford branded 4" three jaw chuck (Toolmex made in Poland) which I had totally forgotten about. There is what would appear to be an oiling point - recess with ball in centre on the front face. Am I correct and if so what grade/ type of oil should be used?
Any one able to give a price guide as, after doing without I probably do not need it. It is complete with key, seem to have had little use and is undamaged save for some very light surface rust acquired in 'storage'. The jaws move smoothly.
David Standing 124/01/2018 20:54:01
1297 forum posts
50 photos
Price guide? A photograph would help.
JimmieS24/01/2018 21:23:58
290 forum posts
True. Will try tomorrow night.
Jim
Neil Wyatt24/01/2018 22:06:02
18990 forum posts
734 photos
80 articles
Same as you use for the slideways will be fine.
JohnF24/01/2018 23:41:53
1146 forum posts
189 photos
JimmieS you might find this interesting its a previous post on this forum, regarding oil I would use a thicker oil that will be retained better when the chuck is in use. I have some Shell Toner R -- no longer available in the same grade, it is very "sticky" as a matter of interest I have seen it suggested that chain saw chain oil is good for this application as well as change wheel lubrication - same reasons.
Ed Dinning 125/01/2018 02:40:54
29 forum posts
Hi Gents, I have with success used PTFE spray as it is non sticky so no swarf pick up and it leaves a very fine film.
Ed
roy entwistle25/01/2018 09:14:19
1504 forum posts
Ed How are you going to spray through an oiling point with ball bearing in the middle? ( see original post )
Roy thinking
Stub Mandrel25/01/2018 09:21:07
4315 forum posts
291 photos
The oil needs to be fluid enough to spread through the chuck from the oiling point.
Neil Wyatt25/01/2018 10:09:38
18990 forum posts
734 photos
80 articles
Oi! Mandrel, who rattled your cage?
N.
Bill Davies 225/01/2018 10:50:23
276 forum posts
11 photos
Out of hibernation?
Bill
Robbo25/01/2018 14:38:38
1504 forum posts
142 photos
When you've given the chuck a few squirts with the oil gun, put it n the lathe and give it a spin to throw out surplus oil.
Being prepared with a cloth held in front of the chuck will save your shirt front from unwanted lubrication.frown
David Standing 125/01/2018 15:06:48
1297 forum posts
50 photos
Posted by Neil Wyatt on 25/01/2018 10:09:38:
N.
The voices in your head are talking to each other in public!
Scary.......cheeky
NJH25/01/2018 16:20:15
2314 forum posts
139 photos
I fear these could be symptoms of D.I.D - I’ll leave it to you to look up. If this is not the case maybe there ARE two of you and both are contributing to ME discussion -either way maybe a case for a wage increase ?
Norman
Ed Dinning 126/01/2018 02:59:08
29 forum posts
Hi Gents, should have made it clearer, PTFE spray works best is chuck is stripped, but works pretty well if the jaws are simply wound out to expose the scroll.
Ed
JimmieS26/01/2018 12:59:04
290 forum posts
David Standing 126/01/2018 13:46:39
1297 forum posts
50 photos
It looks in nice unabused condition.
Doog has an almost identical one on eBay at the moment at £75.....but no bids and it finishes in two days.
Supply and demand - there's plenty of them around, so it's a buyers market.
Value probably in the £60-£80 range.
I would whip the jaws out and give it a good clean first, start at £80 and drop it £5 to £10 every time you have to relist it!
JimmieS26/01/2018 22:21:10
290 forum posts
David, many thanks for you advice. Much appreciated.
Jim
peak427/01/2018 00:20:23
1672 forum posts
175 photos
Posted by Robbo on 25/01/2018 14:38:38:
Hmm, I'm not a trained engineer, well not mechanical anyway, but I'd suggest a soft paper towel, rather than a cloth if it's going near any moving bits like spinning chucks.
Bill
Chris Trice27/01/2018 01:40:31
1375 forum posts
10 photos
I might be worth that if it has both sets of jaws.
Rapid RC
Dreweatts
