Elidir - 3 inch scale Hunslet
stephen goodbody08/01/2018 14:43:21
56 forum posts
40 photos
Hi all,
Thought I'd add some pictures of my 3 inch scale Hunslet (Reeves "Elidir" ), under construction now for over 30 years and finally nearing completion. The loco has been built using a George Adams round-bed lathe circa 1905 vintage, a pillar drill, and hand tools - no milling machine.
The pictures of the spark arrestor may be of interest to some - it's held in place with a single knurled nut at the base of the petticoat pipe and can be quickly removed for cleaning.
The injectors are essentially to the DAG Brown design but mounted in a modified body.
Best regards to all,
Steve
Edited By stephen goodbody on 08/01/2018 14:44:05
Edited By stephen goodbody on 08/01/2018 14:44:21
John Alexander Stewart08/01/2018 14:57:13
779 forum posts
52 photos
Very impressive!
Question: What else is happening in the smokebox, with the cast valve, and the superheaters?
Clive Brown 108/01/2018 15:17:17
538 forum posts
18 photos
Yes, really good. Proves that a workshop full of the latest technology isn't essential.
If I can be allowed just one question, among many that spring to mind; how did you get the bespoke vacuum gauge?
Brian Sweeting08/01/2018 15:45:55
448 forum posts
Excellent, you should be very proud of that.
ega08/01/2018 16:03:36
1858 forum posts
157 photos
stephen goodbody:
I was about to ask for pictures of your lathe but it seems it is already documented on lathes.co.uk.
SillyOldDuffer08/01/2018 16:16:21
6465 forum posts
1422 photos
Gorgeous!
stephen goodbody08/01/2018 16:23:04
56 forum posts
40 photos
John and Clive - in quick answer to your questions:
John, I configured the smokebox piping to bring the main steampipe in front of the blast pipe (the original design has it the other way around). This allowed me to install this hidden (but easily accessible) commercial ball valve for the purposes of pressure testing, avoiding the need to rely on the regulator as the primary shutoff during testing.
Clive, the duplex vacuum gauge is home-made. I used the two smallest commercial vacuum gauges I could find, stripped them down and mounted them back-to-back and offset to left and right, extended a spindle forwards from the rear gauge, and mounted the assembly in a case. The gauge face is a transparent water-slide transfer on a white-painted bronze disc.
EGA - that's correct, Tony asked me to provide pictures of the lathe a few years ago, the pictures and info are at http://lathes.co.uk/georgeadamsroundbed/
Best regards
Steve
Edited By stephen goodbody on 08/01/2018 16:40:25
stephen goodbody05/10/2020 19:24:46
56 forum posts
40 photos
Hi all,
This weekend saw the engine fully back together having spent the past ten months in painting and reassembly. Here are a few pictures before the paintwork gets dirty!
Best regards,
Steve
Jeff Dayman05/10/2020 21:05:55
1918 forum posts
45 photos
Looks fantastic Steve! Look forward to lots of steaming videos! Well done.
Baz05/10/2020 22:00:18
489 forum posts
That is gorgeous!
Paul Kemp06/10/2020 00:38:55
580 forum posts
18 photos
Steve,
Lovely work, you should be rightly proud of that. Is that a combination brake set up you have there (steam on the loco and vacuum for the train)? I started a 5" gauge version a few years back but got distracted by a 4" and now a 6" scale TE! As soon as the big one is done I want to get back to the Hunslet! I love the look of these loco's ever since seeing one in Wales as a child!
well done, cracking job.
Paul.
stephen goodbody06/10/2020 14:25:00
56 forum posts
40 photos
Many thanks all.
Paul - the loco has both steam and vacuum brake cylinders on-board, with the vacuum brake system also extending to the train. I look forward to seeing pictures of your engines also!
Best regards
Steve
Paul Kemp06/10/2020 20:44:05
580 forum posts
18 photos
Steve,
Thanks for that, neat idea to have a vacuum cylinder on the loco too, saves a combination valve! Not seen anyone make one of those in small scale successfully - hence the question.
Many pictures of my engines on the other site you frequent .
Paul.
stephen goodbody06/10/2020 21:18:07
56 forum posts
40 photos
Oh my goodness, I've just put two and two together!
I've been thoroughly enjoying your 6" Savage build for a long time Paul - thanks for helping me connect the dots!
Best regards
Steve
stephen goodbody30/10/2020 15:56:06
56 forum posts
40 photos
Hi all,
I ran the engine last Friday and things went pretty well. Nothing major to fix - a leaking regulator being the most significant, but hopefully fairly straightforward to resolve.
To memorialize the event I've made a video! This is my first attempt at a video and my first attempt with YouTube, so, if you should watch it, please accept my up-front apologies for anything tedious or unclear!
The video should be viewable in high-definition, all being well.....
Best regards
Steve
Paul Kemp30/10/2020 19:55:45
580 forum posts
18 photos
Steve,
Very nice, all you need now is a rake of slate wagons behind! Be great to see it on the track.
All the best,
Paul.
Simon Collier30/10/2020 20:06:35
376 forum posts
56 photos
Steve, you are more than a loco builder, you are a true craftsman. Also a masochist for not having a mill. I also modified D. Brown's injector bodies as I found them too problematic to make.
stephen goodbody17/11/2020 21:36:27
56 forum posts
40 photos
Many thanks Simon. I'm not sure about your first statement, but I definitely agree with the masochist part! However that's the challenge I set myself when I was 17 and I'm glad i saw it through.
As an update to those that may have watched the video, the niggles have been taken care of and everything's hopefully ready to run at a track next year. As suspected, a bit of boiler muck had somehow worked its way into the regulator during the pre-steaming washout and then become trapped between the disc and port-face when the regulator was first opened under steam, causing it to leak. Fortunately the seat hadn't been scored and the offending muck could be seen and removed without major disassembly. I took the opportunity to install a more powerful spring to hold the disc to the port-face when there's no boiler pressure and the regulator's now leak-free once again. Hopefully this will prevent any future recurrence of the problem.
Next step is to build a few wagons to go behind it. I'm aiming for one bogie wagon as a driving truck and two bogie vans for passenger transport, all being based on Lynton and Barnstable Railway prototypes which seem to scale nicely for the tasks in hand. Wish me luck!
Best regards
Steve
EngineDIY
