Stevenson End Mill Fixture
How to set up?
Brian H01/01/2018 16:05:46
1637 forum posts
108 photos
Can anyone suggest how to set up endmills and slot drills so that the cutting edges are square to the grinding wheel?
I suppose it could be done by eye but there must be a better way.
ASF01/01/2018 16:14:56
130 forum posts
12 photos
Use a height gauge to find height then half the diameter down. Put edge of cutter on that height. Also look at
Neil Wyatt01/01/2018 16:39:57
17878 forum posts
705 photos
77 articles
"is someone out there implying that us hobbyists are cheap bas..."
John Haine01/01/2018 16:46:51
3080 forum posts
162 photos
From what I could work out on how he set the cutter perpendicular to one of the long edges, you could use the little optical aid that I made a while back, here shown in use setting a cutter in an "Acute" tool holder.
It's basically a rectangle or perspex bolted to the face of a short length of key steel, after having lines scribed on it at right angles to each other at appropriate places. You hold it against the end face of the cutter and align the edges of the latter to the appropriate lines. The eye is very sensitive to alignment of lines so it can be very accurate, using a magnifier if necessary.
Brian H01/01/2018 16:51:59
1637 forum posts
108 photos
Posted by Neil Wyatt on 01/01/2018 16:39:57:
Surely he's right Neil, at least about some of us!
Anyway, very grateful for the suggestions, all I need to do now is try it; my Union T&C grinder is all set up with my Stevenson fixture complete with one of the ER32 collets that Santa brought, now to have a grind.
Robbo01/01/2018 20:46:57
1504 forum posts
142 photos
All those I've met are as tight as a duck's wotsitcheeky
Nick Hulme01/01/2018 21:59:07
743 forum posts
37 photos
Well maybe, but not the ones who work at 12" to the foot though
Brian H02/01/2018 16:56:55
1637 forum posts
108 photos
The video was quite good but confused by the use of a high helix 3 flute cutter. It would have been much more helpful if he had stuck with the 2 flute conventional slot drill.
Even so, I've managed to sharpen a 2 flute slot drill satisfactorily, not bad for the first time.
Howard Lewis05/01/2018 17:22:28
3264 forum posts
"Not tight;
just careful, y'ken"
