What did you do Today 2018
Neil Wyatt26/10/2018 21:32:45
17686 forum posts
697 photos
77 articles
It's the same principle, I'm sure.
The PCB has three pads, I may wire up three croc clips to them for things like big power transistors.
Do you know if they work on things like FETs or IGBTs?
Ian P26/10/2018 22:04:46
2352 forum posts
98 photos
Good question but I've never tried anything that I did not already know what it was. I bought it because it looked to be an indispensable tool, in practice however I have only used it about four times mostly just to identify the pinouts of a transistors when I could not be bothered to look at a data sheet!
Ian P
Iain Downs26/10/2018 23:08:46
611 forum posts
520 photos
After a vain attempt (Started last year) to build my own QCTP to my own design, I gave in and bought one from ARC., The standard mini lathe toolpost is difficult. The nasty aluminium cheap one is nasty and cheap - and I NEVER managed a decent parting off.
This one (the model 000) is reassuringly heavy, nicely ground and works very nicely. I expect several old boys to pitch in with 'buy cheap buy twice' and their right. I should have spent the dosh in the first place.
This one has parted some 20mm steel with no drama at all and sunk through an ally bar like butter.
sigh.
Iain
SillyOldDuffer27/10/2018 11:17:34
5593 forum posts
1145 photos
Posted by Neil Wyatt on 26/10/2018 21:32:45:
I'm using mine a lot at the moment to sort out my muddled collection of components. While I was sorting transistors into NPN and PNP it successfully spotted a 2N3819 was a JFET.
The various adverts on ebay suggest there are a few variants about. I think the original LCR, NPN & PNP, & Diode unit has been extended and/or the software upgraded. If buying one, may be worth checking the detailed spec to see if you can pick out the most up-to-date model available.
In operation, the unit is a little erratic, and it is sensitive to dirty leads. Mostly I'm impressed.
I use mine without a box and what with the battery flopping about and all, it's not a good idea. Making a box with my limited sheet metal / plastic instrument box technology is bothersome because of the need to provide access to the display and especially the DIL socket. A 3D printer would solve that easily - I want one!
Andrew Johnston27/10/2018 11:36:22
5383 forum posts
617 photos
Posted by Iain Downs on 26/10/2018 23:08:46:
While I'm old enough to be a member of the grumpy old git club I'm not old enough to be a member of the told you so club; so I won't mention it if you don't. smile
Neil Wyatt30/10/2018 18:59:10
17686 forum posts
697 photos
77 articles
Hooray for 3D printing!
Last night my steplad asked if I could do an adaptor to join two small pipes. Took two tries to get it right (hard to measure flexible pipe accurately and one needed a taper), and my reward is a bottle of King Goblin
Please drink responsibly beer
bricky30/10/2018 19:26:13
418 forum posts
48 photos
Just finished the oil pot for my rockerblock ic engine not a simple job .I finished the water jacket yesterday this was difficult as I couldn't source the O rings.I ended up stretching a pair daily on a stepped mandrel but I still couldn't get the cylinder through without forcing the ring out.I had to deepen the groove in stages and add a slight taper to the end of the cylinder.When it did go through I wasn't sure that I hadn't dislodged the rings .I filled the jacket and was relieved to have no leaks, a result at last.Not much left to do now but the biggest job will be making the carburetor.
Frank
Mick Henshall30/10/2018 19:34:44
530 forum posts
31 photos
Managed to thin the sides of my coupling rod for Rob Roy so it ended up 1/8" thick instead of 3/16", should have checked the drawing !!! Luckily it was the first one so can do the others correctly and make a replacement 😠
Mick
Neil Wyatt30/10/2018 19:37:10
17686 forum posts
697 photos
77 articles
Posted by Mick Henshall on 30/10/2018 19:34:44:
Mick
At least it wasn't for a 7 1/4" King!
Mick Henshall30/10/2018 20:00:18
530 forum posts
31 photos
Thank you Neil for those words of comfort
Mick
Bazyle31/10/2018 01:36:24
5125 forum posts
199 photos
Overtook a 2-6-4 tank engine. It was doing 45mph backwards on the M4 around Slough at 20:15 last night. Think it was no 800078 but google doesn't find that.
Jan B31/10/2018 06:46:38
25 forum posts
10 photos
Brazyle it´s a zero to much. Google 80078 and you will find it.
Jan
Trevor Crossman 131/10/2018 22:14:44
131 forum posts
17 photos
but before doing that, I should have done this...……………………..
My concentration was centered on the cutter but as soon as the machine ran I noticed the vibration and hit the red button and immediately gave myself a good earful of abuse and considered myself lucky that I didn't get injured by the handle flinging itself into me nor damaged anything in the shop !embarrassedembarrassed. Just might fit an extra safety micro-switch to be tripped when the handle is fitted.
Trevor.
Mark Rand01/11/2018 01:50:32
873 forum posts
3 photos
Which shaper is that?
Oddly enough, on my 10" Royal shaper there is less guarding, but there is a round knob/handle to turn the mechanism for positioning the ram. That's far safer than a cranked handle, even it it's removable! blush.
thaiguzzi01/11/2018 02:59:42
686 forum posts
131 photos
Posted by Trevor Crossman 1 on 31/10/2018 22:14:44:
Trevor.
You are not the first and you will not be the last.
Join the club.
Though it's nowhere near as bad as the old "leave a lathe chuck key in the chuck" chestnut.........
thaiguzzi01/11/2018 03:02:42
686 forum posts
131 photos
Posted by Mark Rand on 01/11/2018 01:50:32:
Looks like a Boxford to me.
The removable cranked handle should do the cross feed and the vise too. Another sq key tool and that's it on a Boxford for EVERY adjustment.
mechman4801/11/2018 18:04:18
2626 forum posts
407 photos
Spent an hr in the cave today & made one of these for my daughters wedding dress, buttoning it up might prove a little difficult for the mother of the bride, Stainless steel & wood dowel...
George.
Sam Longley 101/11/2018 18:24:59
742 forum posts
26 photos
My first thought was that it was a key for unlocking a chastity beltyes
How much tension are you expecting to put on that dress??
Are you selling her? does the poor bloke know what he is buying?
Have you made a tool for safely letting it all out or will they press a button & it all goes with a massive twang!!!!?crook
Edited By Sam Longley 1 on 01/11/2018 18:31:11
mechman4801/11/2018 18:31:26
2626 forum posts
407 photos
Mother of bride has arthritis in fingers... just to help manipulating buttons … if need be thinking
Geo.
Alan Waddington 201/11/2018 18:56:57
492 forum posts
87 photos
Cleaned out the surface grinder oil tank........dont know Reckon it might have been just a tad overdue!
This thread is closed.
Ausee.com.au
