The Workshop Progress thread 2018
Muzzer14/01/2018 20:28:53
2904 forum posts
448 photos
You didn't mention how you machined the internal teeth. The acrylic test doesn't give the game away. Did you use an end mill, a slotting attachment, file......?
We should be told!
Murray
JasonB14/01/2018 20:31:45
20635 forum posts
2296 photos
1 articles
Depends if Neil answers my e-mail asking if he wants it written up for the magwink 2
But if you know where to look it can be found on the net on one of the forums where people make things
jimmy b24/01/2018 17:37:20
724 forum posts
42 photos
I've just been cutting some 70mm x 20mm flat bar up, to make a new ball turner.
I had a quick check with a square that the bandsaw was set square. Cut the first bit off, went to the mill to clean up the sawn edge. It cleaned up within .008"!!!! I was well happy! Set the saw going on the next bit, thinking about gloating later on here about how good the bandsaw is!
Next 3 bits came out about 60 thou out of square.......
What's that saying about pride before a fall. though I'm sure there is a better suited saying.......
Jim
Neil Wyatt24/01/2018 22:22:47
18630 forum posts
726 photos
79 articles
Posted by JasonB on 14/01/2018 20:31:45:
I can't find your email... answer is probably yes
As for me, an extremely unusual setup to skim a 0.5mm cut off about seven inches of 2 1/4"c aluminium tube.
Nice finish with a single cut using a CCGT insert, very faint striations, but feels absolutely smooth.
Neil Wyatt25/01/2018 19:22:23
18630 forum posts
726 photos
79 articles
Bored out to 2" (actually 50.85mm) with a heavy duty HSS boring bar.
The long overhang (of the tube) was causing resonances so I finished with a long, slow shallow cut with my hand resting on the outside of the oily tube as a damper. Worked!
mechman4827/01/2018 22:46:50
2914 forum posts
454 photos
Progress made on my Vertical cross engine... made up the eccentric components for crankshaft...
George.
Mark Rand28/01/2018 00:13:07
1013 forum posts
11 photos
Posted by Neil Wyatt on 25/01/2018 19:22:23:
Ooh. 2 tenth's oversize. Gonna need to swage that down to fit. cheeky
It's wonderfully satisfying when something comes out so well, especially when working 'between units'.
JasonB28/01/2018 07:34:37
20635 forum posts
2296 photos
1 articles
That's his allowance for the anodisingsmile p
Brian H28/01/2018 07:48:16
2147 forum posts
113 photos
I've made a little more progress on the 1858 Burrell-Boydell. I wasn't happy with the original flywheel and a request on "Home Workshop" brought this casting from a few miles from where I live.
The crankshaft and eccentrics were a little tricky as the crankshaft had to be silver soldered whilst leaving the eccentrics free.
I still need to silver solder the cylinder assembly but need a good day to do it outside because of the low ceiling in my workshop.
Brian
Jim Nic28/01/2018 11:21:05
335 forum posts
197 photos
With Stew Hart's Popcorn engine finished -
it was time to make a start on Ray HasBrouck's No3 Rocking Valve engine. I purchased the book containing the drawings a while ago and yesterday I gathered the main materials to make a start (there may be a few bits left over at the end).
It is a small, fairly straightforward design and shouldn't pose any difficulty (famous last words!), I've even bought in a flywheel. I chose this engine because I dont have such a valve mechanism in my collection.
Today I've made a start on the cylinder block.
Jim
mechman4802/02/2018 13:32:11
2914 forum posts
454 photos
Started to make the swing arms for my vertical cross engine... one of those days were what should have been a easy job turned out bloody awkward & screwed them up,,, well at least one of them... packed in & went indoors, peed of with my self... face 19
George.
Jim Nic02/02/2018 14:11:12
335 forum posts
197 photos
Know just how you feel George. The cylinder block pictured in my last post is now in the scrap bin after I broke a 10BA tap in it. crying 2 All part of life's rich pattern
Jim
MatMan02/02/2018 14:45:09
4 forum posts
The quality and detail is impeccable on these things!
Neil Wyatt04/02/2018 14:01:50
18630 forum posts
726 photos
79 articles
Starting to make some progress on my telescope build:
Neil Wyatt05/02/2018 15:46:37
18630 forum posts
726 photos
79 articles
And fitted the bearings to the body of the Crayford focuser:
damian noble05/02/2018 15:53:58
161 forum posts
6 photos
Looks nice that Neil.
mechman4805/02/2018 22:50:26
2914 forum posts
454 photos
Looking smooth as Neil
Roderick Jenkins06/02/2018 17:08:45
2085 forum posts
557 photos
Nice to see that John Wall merited a significant obituary in The Times today.
Rod
Edited By Roderick Jenkins on 06/02/2018 17:11:57
Neil Wyatt06/02/2018 17:16:15
18630 forum posts
726 photos
79 articles
Do you have a link?
I gave a brief mention here and also putting a short obituary in Ed's Bench.
Roderick Jenkins06/02/2018 17:34:38
2085 forum posts
557 photos
Posted by Neil Wyatt on 06/02/2018 17:16:15:
Do you have a link?
It's behind a sign up wall **LINK**
I saw it in an old school paper copy.
This thread is closed.
JD Metals
