End mills for alluminium
petro1head22/12/2017 13:00:37
742 forum posts
143 photos
I currently use Arc Titan coated 3 flute end mills - http://www.arceurotrade.co.uk/Catalogue/Cutting-Tools/Milling-Cutters/ARC-Premium-HSS-AL-End-Mills/3-Flute-HSS-AL-End-Mill-Standard-Length-TiAlN-Coated
However they quite often get clogged meaning I have stop and scrape the alloy off the end of the tool.
Any suggestions of what would be better. Ie 2 flute or split else
JasonB22/12/2017 13:05:19
19568 forum posts
2142 photos
ARC's uncoated ones that are specifically made for aluminium work well for me though the 6mm can chatter a bit due to them being long series in which case I use nncoated FC-3 cutters. Or he does have standard length in carbide specifically for ali.
Edited By JasonB on 22/12/2017 13:18:24
Mike22/12/2017 13:05:39
713 forum posts
6 photos
I think your problem may be that you are milling the aluminium either dry or far too dry. If so, lubricate with lots of paraffin or WD40. I've never known the number of flutes to make any difference.
JasonB22/12/2017 13:10:32
19568 forum posts
2142 photos
The coating does not help as it is textured if you magnify it enough so the ali tends to stick to the rougher surface, that video only had a dab of paraffin before the cut wa sstarted.
Andrew Johnston22/12/2017 13:26:32
5828 forum posts
662 photos
There's no advantage in using coated cutters for aluminium. In particular the TiAlN coating needs to run hot (>800°C) to work effectively. So it'll never work properly when machining alumimium.
There are polished cutters specifically for alumimium that will run dry. However, for manual milling an occasional squirt of WD40 works fine for me. On the CNC mill I use flood coolant, partly to prevent sticking but also to wash away the swarf and prevent re-cutting.
If one is using sensible feeds and speeds then the number of flutes definitely matters. I only use 2 and 3 flute cutters for alumimium. More than 3 flutes greatly increases the probability of clogging the flutes. Like this embarrassed:
MW22/12/2017 13:40:41
2051 forum posts
51 photos
Cutters with polished flutes and high helix tend to work best for alu.
SillyOldDuffer22/12/2017 13:41:49
6681 forum posts
1501 photos
Aluminium has a low melting point and will glue itself hard to HSS if it overheats.
Few suggestions in addition to Mike & Jason:
  • May be due to swarf not clearing and being continually re-cut under the tool:
    • 2 flutes are better at lifting out swarf, always use them for slots.
    • the tool rpm and feed-rate aren't adjusted to lift swarf out; experiment.
    • Use a brush to remove swarf continually.
  • The tool is rubbing because it is blunt due to:
    • wear
    • over gentle cutting by the operator in the past.
    • a thin layer of aluminium is still stuck on the edge even after the tip's been cleaned. Check with an eye-piece. A solution of Caustic Soda or Washing Soda can be used to dissolve Aluminium.
    • over enthusiastic removal of stuck aluminium with an abrasive
  • the Aluminium Alloy you have isn't meant to be machined. (Some alloys are gooey sticky stuff, horrible to work with.)
  • The professionals use flood cooling or a continuous jet of compressed air to aggressively remove swarf while keeping the tool and work cool.
I have a love-hate relationship with Aluminium. It's beginner friendly until it bites back!
Edited By SillyOldDuffer on 22/12/2017 13:43:06
Jon22/12/2017 14:22:19
997 forum posts
49 photos
Depends on the aluminium grade your using, some are a right pain.
In short aluminium wont clog unless heats generated!
Not keen on the high helix as cant generate fast enough spindle speeds, just lead to chaffing and ribbing.
Would be nice to see a finishing cut put on Jason, bet the cutter veered off and why i only use carbide often TiALN it lasts hell of a lot longer.
Did have to use a mister for this, heat still built up 2 1/4" square 6082 T6 x 2ft long.
Down to 7/8" height on left x 1 3/4" width
Certainly for manual machining operators should learn to get a feel for whats happening.
JasonB22/12/2017 14:37:36
19568 forum posts
2142 photos
Not got a finished shot of that part but was not aiming for anything special as there was a lot more metal to come off and then destined for paint, its the crankcase on this engine, mounting lugs were at the end of the cutter sides now rounded
Tell a lie, this was the cut but as I said not aiming for a finish just removing material
Edited By JasonB on 22/12/2017 14:41:16
colin vercoe22/12/2017 14:56:14
49 forum posts
try using uncoated cutters the coating process forms a small radius on cutting edge so coated cutters are not as sharp as uncoated ones, they probably require higher spindle speeds as well, This also applies to carbide turning and milling inserts as well
petro1head22/12/2017 15:06:13
742 forum posts
143 photos
Yet again fab quick responces.
From what I have gleaned:
1) Try not to use coated cutters
2) 2 or 3 flute but 2 seem to be an idea but the long ones can cause chatter
3) Lubricant like WD40 will help
Sillyoldduffer made an interesting comment "over gentle cutting by the operator in the past." I am guilty of this always concerned I may be being too reserved with the amount I take off. A couple of mm at a time seems a lot but maybe I am wrong?
The problem mostly happens when I am plunge cutting
David Jupp22/12/2017 16:27:31
759 forum posts
17 photos
Possibly even consider single flute cutters.
Andrew Johnston22/12/2017 16:41:27
5828 forum posts
662 photos
I think the pussyfooting cuts referenced by SoD might refer to feedrate rather than width or depth of cut? Depth of cut only determines which part of the cutting edge wears. To a first approximation width of cut doesn't have much effect on wear; it's a balance between each tooth staying in the cut longer versus few passes.
What really wears the cutting edges more quickly than normal is too slow a feedrate. If the feedrate is too low as the cutting edge meets the work (assuming conventional milling) then instead of cutting it rubs and the cutter deflects. As the work moves eventually the forces due to a deflecting cutter overcome the material strength and the cutter starts cutting, and so on as the next cutting edge appears. This also means the cutting process is prone to chatter. A higher feedrate doesn't eliminate the rubbing but greatly reduces it, and thus reduces the wear. The extent to which the cutting edge rubs also depends strongly upon it's radius, although there's a trade off between edge sharpness and strength.
For carbide cutters there is also a trade off on cost. Remember that carbide cutters are not homogeneous but consist of small particles of tungsten carbide in a carrier matrix, often cobalt, formed by sintering. The smaller the particles the more tungsten carbide is present, and the cutting edges can be sharper, but the more expensive the materials and hence the cutter.
I thought my professional grade carbide milling cutters were sharp, until I bought a premium cutter. I managed to slice open my finger just getting it out the packaging. embarrassed
Muzzer22/12/2017 16:48:21
2904 forum posts
448 photos
Not seen any evidence either way but I wouldn't be surprised if climb milling is less susceptible to swarf sticking on the cutting edge. That would be consistent with your point about too low a feed rate.
I had a couple of breakages recently - these were the result of swarf not clearing from the work area and ending up being recut and subsequently stuck to the tool. For manual milling I'd say WD40 is essential along with uncoated, polished cutters. For CNC and decent removal rates, flood coolant is essential. I'm currently making a full enclosure for my machine, as I have concluded that the only way to clear swarf effectively is to use compressed air (or high pressure coolant which isn't going to happen here). With compressed air and flood coolant, things get very messy very quickly.
Murray
Andrew Johnston22/12/2017 17:01:36
5828 forum posts
662 photos
Posted by Muzzer on 22/12/2017 16:48:21:
That would be my intuitive understanding too. And, in general, for aluminium on the manual mill I get a much better finish climb milling. But I deliberately didn't mention climbing milling in case I got excoriated.
Muzzer22/12/2017 17:55:51
2904 forum posts
448 photos
Here's an example of swarf buildup that requires air to keep the tool safe. There are several occasions here where the tool movement and coolant flow simply aren't enough to clear the swarf. The last minute or so shows the final finishing pass, where large quantities of swarf are generated and without the air blast, much of it would have been recut, with a fair risk of tool breakage.
Warning - not suitable for the likes of Seasick Neil, due to excessive camera movement! I had to keep dancing about ahead of the tool to blow the swarf clear with the airline. I already have a couple of videos of tool breakages, so that angle has already been covered...
Murray
Andrew Johnston22/12/2017 19:43:48
5828 forum posts
662 photos
Posted by Muzzer on 22/12/2017 17:55:51:
Hmmmm, man size cuts and swarf, but that coolant "flow" would put a small dog to shame. I don't expect much pressure from my coolant systems, but I certainly expect a decent flow rate. My CNC coolant can have trouble clearing a deep pocket, but it should cope with the situation shown. How big is the coolant pump?
Muzzer22/12/2017 20:01:21
2904 forum posts
448 photos
It's not the pump that's the problem - it's the size of the sump. I forget the capacity but it's brim full but still not enough. I can get a fine flow rate initially ("elephantine" perhaps) but it takes a fair time to percolate back down into the sump by which time the sump level is pretty low and the flow rate is seriously diminished.
One solution would be high pressure, low flow rate (would require a new, different type of pump) or alternatively use the existing pump as a lift pump and fit an additional (larger) reservoir tank. That would involve a fair bit of buggerage and effort. And there would be a flooding issue if the lift pump didn't bother working.
This machine wasn't expected to be using modern high speed toolpaths, although it is clearly capable of cutting the mustard so to speak - I suspect that when new (in the 1980s) the spindle motor would typically only achieve rated power when chomping through a large ingot. Most of the time it would have been mincing about, barely getting into a sweat. The problems I am having are the result of recent advances in toolpath generation and are exposing some of the differences between modern machines and older ones like mine.
Murray
JasonB22/12/2017 20:08:19
19568 forum posts
2142 photos
Would a smaller nozzle help to up the velocity without needing to increase flow, you could only go so far depending on whether the pump has the guts.
Jon22/12/2017 20:22:51
997 forum posts
49 photos
I could make use of that Murray its what i was inferring above.
For the unwise notice the steam that means heat and it has to go some where and aluminium holds heat. WD40 or spot coolant you would have to keep stopping every 2 seconds the job and tool would be hot more susceptable aluminium bonding to cutter .
A mister i rarely use that would have to be run at full chat just shy of becoming airborne to do 50% of that, no way in hell would it cope with full depth unless job and cutter was cool and a cleanup cut.
The whole part would physically come off hot to the touch using the mister with feed rates slowed down.
I do have a similar problem with lathe using a cheap small tank and pump but not the English originals about 4 times the capacity. Coolant builds up in height, drains and filters through mean while tanks almost empty. Larger tank.
EngineDIY
