HMS Queen Elizabeth: Leak found on new aircraft carrier
Jon Gibbs19/12/2017 08:53:56
739 forum posts
I read this and thought it must be a huge leak.
...but then it boils down to it we're talking a litre of water every 15-20 seconds through a prop shaft seal.
If that's the worst they can find then the new HMS QE must be bloomin' great!
Jon
Brian Wood19/12/2017 09:01:16
2186 forum posts
37 photos
I would have thought that was what you might expect on shafts and seals of that size and most certainly within the capacity of bilge pumps to shift it without even noticing.
Do we have another example of media hype and hysteria here?
Ady119/12/2017 09:10:03
3687 forum posts
514 photos
The UK's new aircraft carrier, HMS Queen Elizabeth, is leaking because of a faulty seal.
The Royal Navy's future flagship, which was commissioned by the Queen earlier this month in Portsmouth, has a problem with one of its propeller shafts.
The fault on the £3.1bn carrier was first identified during sea trials.
A Royal Navy spokesman said the ship is scheduled for repair and the fault does not prevent it from sailing again early in the new year.
According to the Sun newspaper, HMS Queen Elizabeth has been taking on up to 200 litres of sea water every hour because of the fault.
Brian H19/12/2017 09:21:20
1637 forum posts
108 photos
Maybe they'll manage to fix it by the time we have some aircraft for it.
V8Eng19/12/2017 09:23:38
1432 forum posts
28 photos
I thought Sea Trials were partly to make sure everything worked and find any unexpected problems?
Edited for spelling.
Edited By V8Eng on 19/12/2017 09:33:27
Joules19/12/2017 09:26:37
45 forum posts
Can't they drill a hole to let the water out !!!
Brian Wood19/12/2017 09:27:02
2186 forum posts
37 photos
My old boss at Rolls-Royce used to say " Never believe what you are told, and only half what you see"
A rather jaundiced view of things perhaps, but if the Sun reports a leak of that size through a prop shaft seal, who are we to argue with the might of our well informed press? Who indeed!!
See my earlier post. If true, the leak is still only 40 gallons an hour, about as much as a fast dripping tap. The press needs to get a sense of perspective.
Jon Gibbs19/12/2017 09:29:40
739 forum posts
At 70,600 tonnes she'd take 40 years to sink at that rate if they left it
Edited By Jon Gibbs on 19/12/2017 09:31:22
V8Eng19/12/2017 09:31:04
1432 forum posts
28 photos
Unfortunately trial by media in many things seems to be all too prevalent lately.
Tony Pratt 119/12/2017 09:32:50
1124 forum posts
5 photos
The media never let the truth get in the way of a good story.sad
Tony
Jon Gibbs19/12/2017 09:33:38
739 forum posts
To be fair, it's not just the Sun, it's being almost universally reported today.
V8Eng19/12/2017 09:38:54
1432 forum posts
28 photos
I first saw the story on BBC Breakfast at about 6.30 this morning.
Edited By V8Eng on 19/12/2017 09:48:45
Martin Kyte19/12/2017 09:53:49
1842 forum posts
33 photos
Engineering wise, I would not be worried about the leak but rather about the cause for the leak. Something isn't right because it's not functioning as it should.
regards Martin
Mike19/12/2017 09:59:28
713 forum posts
6 photos
The press had a field day with this story this morning. By picking on a tiny fault they are holding the Royal Navy and Britain up to international ridicule. Have they no pride in their own nation? As a (mostly retired) journalist I am disgusted by the antics of the media these days. Shame on them!
Ady119/12/2017 10:03:03
3687 forum posts
514 photos
An old Navy guy would just give it a few taps with a Coventry spanner on the night watch
The modern navy guys will probbly spend a couple of million sorting it out
Edited By Ady1 on 19/12/2017 10:07:46
not done it yet19/12/2017 10:11:09
4639 forum posts
16 photos
Question to ask is how much water might be taken in if the (faulty) seal actually failed completely. A dripping tap of the historical brass seat type would soon drip much faster due to the brass being cut away by the initial tiny water jet under pressure.
But, yes, it is a relatively trivial problem to get sorted, I would think. Probably need extra greasy packing, or for the gland nut to be tightened half a turn!
Circlip19/12/2017 10:12:04
1101 forum posts
All gone to pot (?) since the advent of inside toilets and soft toilet paper.sarcastic
Regards Ian.
David Colwill19/12/2017 10:23:10
634 forum posts
34 photos
Posted by Circlip on 19/12/2017 10:12:04:
Regards Ian.
Outside toilets on ships are not such a good idea smile p
Brian H19/12/2017 10:27:27
1637 forum posts
108 photos
Ships in Nelsons time had outside toilets, they were called heads.
Ady119/12/2017 10:27:53
3687 forum posts
514 photos
Fortunately for the Navy no one in the media has noticed that their aircraft carrier has no aircraft yet
