Stuart 501 boiler
Maurice22/11/2017 18:54:02
455 forum posts
50 photos
I recently acquired a Stuart 501 Boiler. It still had the asbestos boards on the inside of the side plates. This has been safely disposed of. Can anyone suggest a replacement material, and where to get it please?
Maurice
JasonB22/11/2017 19:00:03
17294 forum posts
1862 photos
You could pop into a good builders merchants or roofing suppliers and by an "undercloaks board". These a fibre cement boards about 4ft long and 6" wide so enough for your boiler, cost about a quid each
Neil Wyatt22/11/2017 19:04:10
17344 forum posts
690 photos
77 articles
Kaowool is OK if it is supported. If it needs to be self-supporting try a Skamolex (vermiculite) board, OK up to red heat - you can cut it into thinner sheets with a saw (use some sort of guide).
Maurice22/11/2017 19:04:37
455 forum posts
50 photos
Thanks Jason, that sounds promising. I'll try that.
CuP Alloys 123/11/2017 09:47:31
226 forum posts
Available ex stock from CuP Alloys.Keith
