Made something useful at last
sean logie05/11/2017 16:36:29
590 forum posts
90 photos
Made myself a wee vee block and I'm planning a couple more out of the same piece of material . I also learned how important setting up a work piece up before machining . Also used a carbide end mill for the first time today (very impressive ) . I cut the square channel on the side using a 4 flute ,is this good practice or should I have used a 2/3 flute . Overall I'm happy with the end result . The Centec2 keeps on impressing ,I was taking what I thought were big cuts for this small mill ,the only thing stopping taking bigger cuts was the operator .
Getting a tad impatient now to get the vertical up and running . wink 2
Don't know why my photos are always like this on here ....
Sean
Edited By Neil Wyatt on 07/11/2017 15:23:54
Trevor Drabble05/11/2017 16:44:27
206 forum posts
5 photos
Sean , Nice work . May I suggest you now put a nominal 3mm x 3mm slot along the full length of the bottom of the Vee in order to allow dirt and dwarf somewhere to go and also to allow any angular work to sit fully on the sides of the Vee , and so maintain an accurate register . Trevor
Russell Eberhardt05/11/2017 16:44:39
2573 forum posts
85 photos
Posted by sean logie on 05/11/2017 16:36:29:
See this thread.
Russell
John Haine05/11/2017 16:48:04
3009 forum posts
160 photos
Good stuff! When you make 2 more try machining as a pair so that they match - useful then for holding longer bars needing support at both ends.
sean logie05/11/2017 17:24:11
590 forum posts
90 photos
Posted by Trevor Drabble on 05/11/2017 16:44:27:
Thanks Trevor ,
That was my next move along with a slitting saw cut along the bottom of the vee .
Sean
sean logie05/11/2017 17:26:36
590 forum posts
90 photos
Posted by John Haine on 05/11/2017 16:48:04:
Hi John ,
I've enough material to make another two which as you suggested will be a pair .
Sean
David George 106/11/2017 19:48:12
1190 forum posts
406 photos
Hi Sean
I would also put a couple of taped holes in the base of the V block as it gives you the option to screw them to a plate or an angle plate and a taped hole in the end face so you can screw a plate to the end as an end stop for a pin or round part.
David
Rainbows06/11/2017 20:30:02
640 forum posts
182 photos
Speaking of pairs feel free to make two vertical heads and send me one
sean logie06/11/2017 21:25:58
590 forum posts
90 photos
Rainbows no probs .... laughwink 2
Sean
John Reese06/11/2017 22:40:56
836 forum posts
I believe the slot at the bottom of the V is to allow grinding withe the need for sidewheeling. Unless he intends to grind the blocks there is no advantage to the undercut.
not done it yet07/11/2017 07:35:18
4494 forum posts
16 photos
Unless wanting to mount a square item to machine on one corner...
Michael Gilligan07/11/2017 08:05:24
15457 forum posts
668 photos
Posted by not done it yet on 07/11/2017 07:35:18:
I was so tempted to get all pedantic ... but I shall refrain. angel
Yes; in practical terms that is a very fair point.
sean logie07/11/2017 08:07:42
590 forum posts
90 photos
Please don't refrain 😉
Sean
Martin King 207/11/2017 09:39:36
680 forum posts
257 photos
Posted by sean logie on 07/11/2017 08:07:42:
Sean
Seconded!
Pedantry from a master is so much fun! wink
Martin
Michael Gilligan07/11/2017 13:15:16
15457 forum posts
668 photos
Apologies for the delayed response, Sean [and Martin], I made that post just before heading to the Hospital for my pacemaker check. ... All is well, so here goes:
'ndiy' has not defined any terms, nor given any tolerances; so we are obliged to make some assumptions: Mine [which I hope are considered reasonable] would be ...
  1. A vee block has two internal faces which are flat, and arranged at 90° to each other, and are axially parallel. [More sophisticated definitions are surely possible, but I think that will suffice]
  2. In the context of the present discussion; 'a square item' might be assumed to be a length of material of constant section with four equal sides arranged at 90° increments.
  3. ... Alternatively the 'square item' might only have two of its adjacent faces arranged at 90° to each other; the emphasis being on 'squareness' as a description of perpendicularity.
  4. My case is valid for both version (2.) and (3.)
  5. In the absence of any tolerances being stated, we must in the ideal case assume 'perfection'.
Unfortunately, in this hypothetical 'defining case' ndiy's brief assertion falls down ... because the 'square corners' would match perfectly and the groove would therefore NOT be of any advantage.
^^^ This is, of course, merely gratuious pedantry !!
In the real world; ndiy's point is a good one ... because the 'male' square corner may have bruises [or imperfections in its linearity] sufficient to cause it not to seat properly in the 'perfect' female vee.
N.B. Many other imperfections are available ... devil
David Standing 107/11/2017 13:25:49
1288 forum posts
48 photos
Posted by Michael Gilligan on 07/11/2017 13:15:16:
You didn't disappoint wink 2
sean logie07/11/2017 14:16:04
590 forum posts
90 photos
Now that's a reply .... I wonder if there will be any response .... dam I wish I'd stuck in more at school ... you had me chuckling away to myself ....
Sean
Jim Cahill07/11/2017 14:43:22
14 forum posts
Hello Sean,
In one of his books, Geo. H. Thomas goes to some length to explain why he believes 4 flute cutters (Known as End Mills in the UK) are inclined to break as they emerge from cutting a channel.
sean logie07/11/2017 15:07:37
590 forum posts
90 photos
Makes sense Jim , coming out the end of the cut was when the end mill groaned a bit . Should I be using a 2/3 flute for cutting channels .
Sean
MW07/11/2017 16:29:45
2051 forum posts
51 photos
Very nice, do you think you'll polish them with emery cloth when you're finished or will you leave them to a machine finish?
Michael W
