Spurious Accuracy
Neil Wyatt03/11/2017 17:43:06
16970 forum posts
690 photos
76 articles
One of the things that regularly gets discussed is the accuracy that we should expect from our machines and that we should work to.
In practice, if you look at the specifications of various fits, it is extremely unusual to come across a requirement to work to better than 0.01mm or about half a thousandth of an inch (from here forward I will just use metric).
Even when testing tools, Schelsinger's limits don't rely on better measurement than 0.01mm, with precision being achieved my measuring deviations over an extended length of a bar, for example.
But lots of folk still chase 'tenths of a thou' so let's put the dimensions we work to into a context:
1mm = Typical size of a grain of sand, half a pinhead. About as small an object as you can handle without tweezers.
0.1mm = The thickness of a piece of paper.
0.75mm = roughly the smallest size difference you can see with the naked eye at a distance of about 300mm, normal reading distance. Diameter of a coarse hair.
0.02mm = diameter of a very fine hair.
0.01mm = diameter of a fungal hypha, length of a human chromosome.
0.005mm = diameter of spider silk.
0.005mm = about the size of a red blood cell.
0.001mm = the diameter of an E. coli bacteria, smallest eukaryote cells
0.0006mm = 600nm = wavelength of red light
200nm = smallest free living bacteria.
100nm = resolution of top-end Mitutoyo micrometer (accuracy 500nm)
180nm = deviation from round of the roundest man-made object
50nm = deviation of a top quality telescope mirror from perfect*.
13nm = the finest pattern you can feel with your fingertips.
1nm = how much your fingernail grows in a second.
0.1nm = size of a phosphorus atom.
*presumably this is better than the roundest object because it's relatively easy to measure and correct a mirror's accuracy by optical means.
Brian H03/11/2017 17:49:01
1349 forum posts
100 photos
Absolutely correct Neil, and that's from an ex aerospace Quality Manager!
Rainbows03/11/2017 17:49:07
640 forum posts
182 photos
I recently purchased an Etalon micrometer that measures in 0.00005" or 0.00127mm as part of a job lot. Anyone got some bacteria cultures they want measuring?
Michael Gilligan03/11/2017 17:57:43
14648 forum posts
634 photos
Just out of curiosity, Neil ... Why did you choose to jump straight from 'milli' to 'nano' ?
'micro' is a perfectly respectable, and convenient, SI prefix.
Neil Wyatt03/11/2017 18:02:52
16970 forum posts
690 photos
76 articles
Posted by Michael Gilligan on 03/11/2017 17:57:43:
Because I wanted to use the units we use in our workshop, micrometers, calipers and machine dials give readings in decimal parts of a millimetre. Using micrometres would partly defeat my object of relating the sizes to everyday workshop experience.
jimmy b03/11/2017 18:07:55
562 forum posts
37 photos
I mostly work to units of "that'll do"......
Jim
Alan Vos03/11/2017 18:22:54
141 forum posts
7 photos
Posted by Neil Wyatt on 03/11/2017 17:43:06:
<snip>
More like orange/yellow. Another comparison. For those who can afford them, the difference between a 1.001 and 1.0005mm gauge block (500nm), is one wavelength of green light.
Steve Withnell03/11/2017 18:30:13
796 forum posts
215 photos
Oh well, I'd better ditch my '10ths' clock then...
Tony Pratt 103/11/2017 18:31:52
966 forum posts
Posted by Rainbows on 03/11/2017 17:49:07:
How does it achieve that? Measuring in .0001" is problematic at the best of times [from a Toolmaker who walked the walk not talked the talk]
Tony
larry Phelan03/11/2017 18:59:48
544 forum posts
17 photos
How about 12"=1 foot
3ft=1 yard
51/2 yards= 1 perch [or something ]
Am I getting warm?
Martin Connelly03/11/2017 19:00:54
909 forum posts
112 photos
And who amongst us has a workshop with temperature controlled to the same standard as a calibration lab and can leave everything for three days to achieve the correct temperature for accurate measurements.
Martin C
jimmy b03/11/2017 19:04:49
562 forum posts
37 photos
I can leave stuff for weeks....still measures wrong.......
Jim
colin hawes03/11/2017 19:05:43
502 forum posts
18 photos
Absolute machine accuracy is unnecessary for hobby work: about the only things that matter are relative tightness between components and any old worn machine or micrometer can achieve that with care. Tolerances are usually only of interest for interchangeability of spare parts. Colin
HOWARDT03/11/2017 19:08:26
489 forum posts
14 photos
But how many get there measuring kit calibrated and work in a temperature controlled 20C space.
Andrew Johnston03/11/2017 19:27:25
5087 forum posts
585 photos
It's amazing the precision you can achieve in an armchair. wink 2
duncan webster03/11/2017 19:43:44
2296 forum posts
33 photos
Once had a panic call from a contractor who had machined a stainless steel forging which cost many thousands and the inspector had failed it beacuse it was about 0.001" too small on a dimension of over 3 feet. Told them to measure it again and keep on measuring it until it passed. When it warmed up a bit in the afternoon it was OK. as far as I know the machine it was part of is still going strong after at least 30 years operation.
Alan Vos03/11/2017 19:44:49
141 forum posts
7 photos
Micro is the only SI prefix which uses a greek rather than roman letter. Correct rendering of greek letters is less reliable than roman. Substition with roman 'u' can cause offence.
vintagengineer03/11/2017 20:20:20
468 forum posts
6 photos
Having worked in Africa laying large size spun iron water pipes, we used to have the opposite problem with the heat when were connecting two ends together!
Posted by duncan webster on 03/11/2017 19:43:44:
ChrisH03/11/2017 20:59:53
834 forum posts
19 photos
"I mostly work to units of "that'll do"......"
Sounds much like mine - "she'll be right"......
Edited By ChrisH on 03/11/2017 21:00:21
Michael Gilligan03/11/2017 21:24:17
14648 forum posts
634 photos
Posted by Neil Wyatt on 03/11/2017 18:02:52:
I will leave you to make your point then, Neil ... and will try to avoid further comment.
Except to say thay my everyday experience of small measurements is mainly microscope-related, and I therefore feel comfortable with instruments that have focus mechanisms scaled with one micrometre divisions.
mid gard rail Jan 2020
