Governors
duncan webster26/10/2017 11:18:49
2437 forum posts
39 photos
There was a bit of discussion a bit back about governors. Going through a pile of ME's to scan the good bits prior to giving them away I've come across Tubal Cain's articles. If anyone wants a copy send me a pm with your e-mail address
Howard Lewis26/10/2017 18:17:38
2927 forum posts
Many early steam engines, (and I C engines) were controlled by Watt or Pickering governors, operating a throttle valve.
Some of the early I C engines had governors which were pretty crude. (The simplest was just a weight in the linkage which operated a wedge to either hold open a valve, or to prevent it opening.
The slightly more sophisticated carried weights within the Flywheel which did much the same thing, or disabled the ignition system.
It was the advent of higher speed engines which brought a requirement for more sophisticated and accurate mechanisms to control speed, leading to governors capable of providing isochronous control.
The ultimate are the electronic governors which will now control speed to within a few tenths of an RPM.
Again, a monument to the skill of Engineers
Thor27/10/2017 05:26:21
1175 forum posts
35 photos
Thanks Duncan for your kind offer.
Thor
