on the Drum of our Miele Washing Machine ...
Michael Gilligan | 27/09/2017 14:13:04 |
![]() 20289 forum posts 1064 photos | The washing machine recently started making "interesting" noises, with a periodicity of once per revolution of the drum. Watching through the glass door today, I realised that there is about 5mm eccentricity [i.e. 10mm peak-to-peak displacement] of the drum !! The drum is still circular; the bearing feels good; and there is no obvious looseness; ... so I can only assume that the drum has shifted on its attachment. Miele spares are 'not inexpensive' and the workshop manuals are probably classified Secret, so any guidance would be appreciated. Has anyone seen this problem ? Should I just buy a new one, and salvage any potentially useful components ? MichaelG. . P.S. ... Sorry, I don't have the model number to hand. But it looks very much like this one: https://m.youtube.com/watch?v=VmY9PvT1ylM
Edited By Michael Gilligan on 27/09/2017 14:24:41 |
JasonB | 27/09/2017 14:26:24 |
![]() Moderator 23076 forum posts 2771 photos 1 articles | A build up of missing socks can throw the balance off How old is it? |
Michael Gilligan | 27/09/2017 14:40:17 |
![]() 20289 forum posts 1064 photos | Posted by JasonB on 27/09/2017 14:26:24:
How old is it? . Not sure ... but definitely more than 5years ['cos the warranty has expired] If [as I suspect] the spider has failed ... and it's the four legged one like this: https://www.amazon.co.uk/Miele-Washing-Machine-Bearing-6090932/dp/B00HN3VFPQ Then the almost inevitable decision is: Buy a new machine MichaelG.
roy entwistle | 27/09/2017 14:47:37 |
1552 forum posts | MichealG Haynes Manuals used to do a manual for washing machines which even explained which parts were interchangeable and where to get parts from. Used to be a firm in Stockport as I remember Roy |
Michael Gilligan | 27/09/2017 14:55:05 |
![]() 20289 forum posts 1064 photos | Posted by roy entwistle on 27/09/2017 14:47:37:
MichealG Haynes Manuals used to do a manual for washing machines which even explained which parts were interchangeable and where to get parts from. Used to be a firm in Stockport as I remember Roy . Thanks Roy We do live near Stockport, but to be honest I think a new one with 5 year warranty is the way to go. MichaelG. |
Brian Sweeting | 27/09/2017 15:10:25 |
453 forum posts 1 photos | In that case can I recommend LG inverter machines. They're not cheap but was told about them by a friend who runs his own white goods repair business. He has installed them in old peoples homes where heavy use is likely and, to date he hasn't had any breakdown calls to them. The wife is very happy with ours, and that's the important part. |
Mick B1 | 27/09/2017 15:12:02 |
2226 forum posts 125 photos | Just ignore the noises. Our Beko's sounded like a bucketful of bricks in a cement mixer for about 2 years now, but still delivers a decent wash, properly spun. Mind you, we had to put it outside in the conservatory in order to preserver normal conversation... |
Jon Gibbs | 27/09/2017 15:43:36 |
745 forum posts | I must admit I thought that washing machine drums were supposed to rotate off-axis when there's an uneven load? I think it ought to effectively rotate around the centre of gravity of the drum if everything is working well. Jon |
Nick_G | 27/09/2017 16:47:22 |
![]() 1808 forum posts 744 photos | Posted by Michael Gilligan on 27/09/2017 14:40:17:
. How much.????? Looks to be made of an alloy. - Is there not a member that is handy with a Tig welder in your area.? Does not need to be pretty as it will never be seen. Just functional.! Install a new bearing for good measure while it's in pieces. Nick |
martin perman | 27/09/2017 17:09:54 |
![]() 2057 forum posts 86 photos | MichaelG, check the drum suspension system to see if one of the springs is not broken or loose.
Martin P |
Phil Whitley | 27/09/2017 17:29:13 |
![]() 1450 forum posts 147 photos | That looks like the spider with the bearings in it, which fits to the outside of the outer tub, and if your bearings are ok, it is not needed. I am not familiar with Miele machines, but usually the inner rotating tub has an aluminium cast spider, usually with three long bolts through the vanes inside the inner tub , and the shaft which goes through the bearings cast into it like this. https://www.huoltopalvelu.com/LG-washing-machine-spider-MHW62021601 If you open the machine door, and grasp the tub top and bottom and try to lift it up and down, you can usually feel the movement if the spider has failed, try turning 1/3 of a turn and try again.the spider legs are where the vanes are inside the tub. Also when the spider has failed, they usually make quite a din, especially when spinning, and sometimes self destruct almost instantly. If there is no play detectable, and no noise, it may be that the machine has been overloaded at sometime, or run with a blocked pump screen, and gone into spin with a wet unbalanced load and got slightly bent. If there is no detectable play, and no noise or heavy vibration, and the inner tub is not catching on the door gasket I would carry on using it. It is a Miele after all! |
Chris Evans 6 | 27/09/2017 17:33:23 |
![]() 2068 forum posts | I think new Miele machines come with 10 or more years warranty. |
Michael Gilligan | 27/09/2017 17:58:40 |
![]() 20289 forum posts 1064 photos | Posted by Chris Evans 6 on 27/09/2017 17:33:23:
I think new Miele machines come with 10 or more years warranty. . Chris, If you can find me the extra 5years, I would be grateful https://www.miele.co.uk/domestic/product-selection-of-washing-machines-and-washer-dryers-1565.htm MichaelG. .
Michael Gilligan | 27/09/2017 18:04:20 |
![]() 20289 forum posts 1064 photos | Posted by Brian Sweeting on 27/09/2017 15:10:25:
In that case can I recommend LG inverter machines. They're not cheap but was told about them by a friend who runs his own white goods repair business. He has installed them in old peoples homes where heavy use is likely and, to date he hasn't had any breakdown calls to them. The wife is very happy with ours, and that's the important part. . Thanks for the recommendation, Brian We will have a look at LG before making a decision [ probably irrelevant, but; the 4K TV is remarkably good, for the money ] MichaelG. |
Nick_G | 27/09/2017 18:16:53 |
![]() 1808 forum posts 744 photos | Posted by Michael Gilligan on 27/09/2017 18:04:20:
MichaelG. . Find out what make this guy recommends for washing and spinning. Nick Edited By Nick_G on 27/09/2017 18:17:07 |
Michael Gilligan | 27/09/2017 18:58:04 |
![]() 20289 forum posts 1064 photos | Posted by Phil Whitley on 27/09/2017 17:29:13:
... If you open the machine door, and grasp the tub top and bottom and try to lift it up and down, you can usually feel the movement if the spider has failed, try turning 1/3 of a turn and try again.the spider legs are where the vanes are inside the tub. Also when the spider has failed, they usually make quite a din, especially when spinning, and sometimes self destruct almost instantly. If there is no play detectable, and no noise, it may be that the machine has been overloaded at sometime, or run with a blocked pump screen, and gone into spin with a wet unbalanced load and got slightly bent. If there is no detectable play, and no noise or heavy vibration, and the inner tub is not catching on the door gasket I would carry on using it. It is a Miele after all! . Useful description, thanks Phil However; As I said in the opening post ... there is no evidence of bearing failure, or of looseness. It is conceiveable that the shaft is bent; but it is not evident ... the drum appears simply to have been displaced radially. The noise and vibration are apalling; and yes, the drum is intermittently contacting the door gasket. I don't really understand what has happened, but I'm pretty sure something significant is amiss !! [ forensic inspection to follow in due course ] MichaelG. |
Michael Gilligan | 27/09/2017 19:04:02 |
![]() 20289 forum posts 1064 photos | Posted by Nick_G on 27/09/2017 18:16:53:
Find out what make this guy recommends for washing and spinning . ... but isn't an enrichment centrifuge over-doing it a little ? MichaelG. |
Nick_G | 27/09/2017 19:18:00 |
![]() 1808 forum posts 744 photos | Posted by Michael Gilligan on 27/09/2017 19:04:02:
. ... but isn't an enrichment centrifuge over-doing it a little ? MichaelG. . Hahahahahaha. Nick |
larry Phelan | 27/09/2017 19:25:42 |
![]() 544 forum posts 17 photos | Five years from a Miele would not impress me very much. My Whirlpool is 15 years young and I still get annoyed when it makes noises. It did act up a while ago but I gave it a few thumps and it settled down again. I expect at least another 10 years from it. |
George Clarihew | 27/09/2017 20:27:40 |
80 forum posts | Look closely inside the drum for a crack developing and study it closely for anything sticking through a hole which could be catching on the heater element. Drums are notorious for not being precisionly (technical term) round and the user usually does not notice such things till something happens. Always look for something simple before dismantling and performing major surgery, 26 years says look for simple things first. Edited By George Clarihew on 27/09/2017 20:28:16 |
