Symon | 13/09/2017 15:36:03 |
19 forum posts | This is a bit cheeky considering none of you know me yet...but...I need a 7/8" 20tpi die (BSB?) to repair the thread on a shaft of my mill restoration. Tracy Tools have the taps and dies but I can't really afford to buy them for just one quick job. Would any of you guys have one I could borrow? Sorry about the sheer nerve...but I'm a wee bit desperate. |
Chris Evans 6 | 13/09/2017 16:25:06 |
![]() 2057 forum posts | I will look in my workshop tomorrow, I do have a selection of odd ball stuff. Will PM if I find one. |
Symon | 13/09/2017 16:28:08 |
19 forum posts | That's greatly appreciated, Chris |
not done it yet | 13/09/2017 16:39:15 |
6809 forum posts 20 photos | Do you really need a die or would a thread chaser be sufficient? A location might help, too. There might be someone local. |
John Rudd | 13/09/2017 16:45:48 |
1450 forum posts 12 photos | Posted by not done it yet on 13/09/2017 16:39:15:
Do you really need a die or would a thread chaser be sufficient? A location might help, too. There might be someone local. His intro thread gives his location as Newcastle/Durham......oop north then.... |
Symon | 13/09/2017 16:47:37 |
19 forum posts | Ordinarily a thread chaser would probably do. But there's a part on the thread where an old pin is and that's stuck tight. So it'll need cut through. Also it's on the machine already which means no more bashing to get the pin out. I'm in the North East between Durham and Newcastle. |
Symon | 13/09/2017 17:04:23 |
19 forum posts | OP should be read BSC (British Standard Cycle). |
David Standing 1 | 13/09/2017 18:33:39 |
1297 forum posts 50 photos | Posted by Symon on 13/09/2017 17:04:23:
OP should be read BSC (British Standard Cycle). Are you sure? I work on old cycles with BSC threads a lot, and 7/8" should be 24 tpi. 7/8 x 20 is however a UNEF size.
Edited By David Standing 1 on 13/09/2017 18:36:47 |
Clive Brown 1 | 13/09/2017 18:46:37 |
826 forum posts 41 photos | Tracey Tools refer to 7/8" x 20 as cycle thread, presumably where the OP is coming from. if the pin area is the only problem, I wonder whether a small triangular file could be used to dress out the remains of the pin. The thread angle seems likely to be 60 deg. |
Symon | 13/09/2017 18:55:21 |
19 forum posts | Yeh, TT calls it BSC: **LINK**
The threads measure 20tpi on my cheapo gauge, which I don't really trust...but it is.
The threads are just rounded a bit, not crossed, and I'll likely flatten the pin area to accept a grub screw instead of the original pin.
Symon | 13/09/2017 19:00:06 |
19 forum posts | Would it not be weird to have a unf/unef thread on a late 50s UK machine which uses Whitworth for the most part? |
David Standing 1 | 13/09/2017 19:02:08 |
1297 forum posts 50 photos | Posted by Clive Brown 1 on 13/09/2017 18:46:37:
Yes, that's odd - Tracy Tools show two BSC pitches, 20 tpi and 26 tpi. All the cycles I have worked on are 26 tpi, 20 tpi is a new one on me! |
David Standing 1 | 13/09/2017 19:03:26 |
1297 forum posts 50 photos | Posted by Symon on 13/09/2017 19:00:06:
If it is a British machine, yes! |
Symon | 13/09/2017 19:26:10 |
19 forum posts | Exactly. This thing has some weird threads, though. The pipework uses 26 tpi BSC which I had a friend tap an oil part as like now...I really didn't want to buy a use once part |
John Stevenson | 13/09/2017 19:27:39 |
![]() Moderator 5068 forum posts 3 photos | Posted by David Standing 1 on 13/09/2017 19:03:26:
If it is a British machine, yes! .
Once you get above a certain size you get an alternative of 20 from the normal 26. Pedal threads have always been 9/16" x 20 RH and LH Chances are that I do have one, I have a full set up to 1" in RH and LH threads but I can't check as I'm off work for a while. Can you use a thread file or at worst a small triangular file |
Symon | 13/09/2017 19:27:44 |
19 forum posts | Still, it's looking beautiful, so can't be mad with it. |
Symon | 13/09/2017 19:29:35 |
19 forum posts | No thread file atm. But I could always borrow one. Would rather clean it up with a die. |
JohnF | 14/09/2017 09:40:11 |
![]() 1152 forum posts 190 photos | Symon see your messages |
Symon | 14/09/2017 10:12:31 |
19 forum posts |
