Alan Marshall 1 | 09/09/2017 16:30:29 |
8 forum posts | I am surprised there is little posted on the new range of 5" loco's by Kingscale. The 14xx has been out for a while now and deliveries are happening on the Jubilee. |
Chuffer | 12/09/2017 20:26:31 |
21 forum posts | I don't have a Kingscale locomotive or one on order, but if my memory serves me correctly when Winson and then Modelworks bought out their self assembly locomotive kits forums were soon set up. So, like Alan, I'm surprised that one hasn't been setup to swap information and tips on setting up and running these loco's. It's rare for a loco' to run 'straight out of the box' so sharing via a dedicated forum is a good idea. Chuffer |
Neil Wyatt | 12/09/2017 21:26:09 |
![]() Moderator 18558 forum posts 723 photos 78 articles | I suspect more will happen when people have had a chance to steam them. Neil |
Simon Collier | 12/09/2017 22:30:46 |
![]() 400 forum posts 58 photos | A friend had a 14xx shipped from the UK. It arrived with the roof damaged, but the packing was excellent so it must have happened before packing. The engine was steamed but a leaking whistle valve to turret fitting stopped proceedings. Investigation showed that there was zero thread engagement of the M6x.5 thread. A member, the boiler inspector, took the engine home to silver solder on standard 1/4 x 40 fittings (the owner was unwell and had lost his confidence). We steamed it again and I took it round the track. There was no weight on the leading drivers which floated off the rails causing, unsurprisingly, derailments. I found a bit of steel angle to hang on the buffers as ballast and we had a few laps. It looked good, steamed OK and went OK. The regulator projected far into the cab and was in the way of everything, which was annoying, especially firing. The hand pump was useless, perhaps because of small capacity. The axle pump worked OK. No injector is fitted. The eccentric straps were a rattling fit on the eccentrics, at least up and down. The factory paint job is very nice, but fake pressed "rivets" on a 5" gauge engine are disappointing. The owner has since died, and the new owner, another member, is running it often. He is not a model engineer however, so yet another member is currently fitting an injector. These engines are built to a price so you need to be prepared to fix a few things up. But that is the case with pretty much any engine you acquire. |
Dave Cutts | 04/04/2019 11:37:46 |
![]() 2 forum posts | I have had my 5" Standard 4 for a few weeks now, and have had 2 very successfull outings with it. It is a great model to look at and runs well "out of the box". However it is not perfect as it is built to a price, but I still think it is great value for money. As a model engineer I have picked up on several things, particularly in the motion work that I will be sorting to my satisfaction. For example the crossheads are a sloppy fit on the slide bars and the pins in the valve gear are a poor fit. Nothing that a few shims and new bushes and pins won't fix. A nice project for the winter. Checking the tightness of the linkage pins is a good idea, I found after the first run that the little end pin in the crosshead was loose... If I was to build something like this it would take 7-10 years and a shed load of cash on materials. When I have done the mods that I think are necessary it will truely be "mine"!! The other important things like the axle pump, injector, regulator and boiler, function very well and the boiler inspector at my club commented on how well the boiler was made, they must have a cheap source of silver solder!! Hope this helps anybody looking at a Kingscale model. |
ray r | 11/05/2019 14:08:23 |
6 forum posts | Hi,i may have the opportunity to buy one of these Cl.4 tank locos.I have heard conflicting reports about these.I have built & driven a Simplex many years ago but i wondered what other folk thought of them.
Ray. |
Old Elan | 11/05/2019 14:27:01 |
![]() 92 forum posts 34 photos | Some comments here... https://modeleng.proboards.com/thread/12329/chinese-locos?page=1 |
Dave Cutts | 11/05/2019 16:00:28 |
![]() 2 forum posts | Hi Ray R, as I said above, the Kingscale Std 4 is a great looking model, mine has had about 5 outings now and it is getting better as I get used to driving it and I make more modifications. Don't get me wrong as it worked straight "out of the box" but as a long term model engineer I could see where improvements could be had. As I said above the main area is sloppyness in the valve gear and motion work but this doensn't stop it working. The boiler is a fantastic piece of work and the detailing is better than I ever achieved on any of the 3 locos I built. They are great value for money and I am happy with the quality/price ratio. Better quality always equates to more money and it feels great to be able to improve it. Take a visit to their showroom, very impressive.. If you are ever are around the Ipswich area come and see it running.... Hope this helps... Dave |
Boiler Bri | 11/05/2019 16:13:25 |
![]() 839 forum posts 199 photos | A club member has a standard 4. 2nd outing the axle pump gave trouble i think broke. The engine is now waiting for new parts and a design change to happen by the Chinese designers 🤔 I think when they have been out a while we will hear of other things happening
i have say though that the Engine is very nice
B
ray r | 11/05/2019 16:32:37 |
6 forum posts | Thanks for the info,i must admit that they are a great looking loco.
Ray. |
ray r | 11/05/2019 16:47:06 |
6 forum posts | Posted by Dave Cutts on 11/05/2019 16:00:28: Hi Ray R, as I said above, the Kingscale Std 4 is a great looking model, mine has had about 5 outings now and it is getting better as I get used to driving it and I make more modifications. Don't get me wrong as it worked straight "out of the box" but as a long term model engineer I could see where improvements could be had. As I said above the main area is sloppyness in the valve gear and motion work but this doensn't stop it working. The boiler is a fantastic piece of work and the detailing is better than I ever achieved on any of the 3 locos I built. They are great value for money and I am happy with the quality/price ratio. Better quality always equates to more money and it feels great to be able to improve it. Take a visit to their showroom, very impressive.. If you are ever are around the Ipswich area come and see it running.... Hope this helps... Dave
Thanks Dave,i live in Northampton not far from Braunston but i don`t think they have any left.I may be able to get one from another source. Cheers,Ray.
Tony Falloon | 18/08/2019 20:47:04 |
![]() 16 forum posts 4 photos | I have just taken delivery of their 9F, which they referred to as 'Pilot 1' I have been led to believe it was the first pre-production model delivered from the Chinese builder, there is also a 'Pilot 2' which they are using at various venues. The production build is due for import in September 2019, 50 models? My model came very well packed in two packing cases, I've removed all the packing material but removing the loco from the box is a two man lift, if you can find some where to grip the model, needless to say it’s still in the box waiting for my mate to call around to give me a hand to lift it out and onto my work bench. The paperwork is of three A4 sheets, a 12 month warranty, a certificate of conformity and a Boiler Shell test certificate. I will require a further boiler hydraulic test and steam test at my club before I can run the model. I can give a progress report as it happens if anyone would be interested? Tony.
Edited By Tony Falloon on 18/08/2019 20:56:42 Edited By Tony Falloon on 18/08/2019 21:00:22 |
julian atkins | 18/08/2019 23:32:20 |
![]() 1238 forum posts 353 photos | Nice bit of grained wood on the right hand side of the box - I could make a ukulele out of that! Cheers, Julian |
ray r | 19/08/2019 03:18:45 |
6 forum posts | Yes please. Ray. |
Bazyle | 19/08/2019 08:36:58 |
![]() 5834 forum posts 217 photos | I'm sure lots of people would like to see it in action. Which club are you a member of? Still time to do a summer tour of some other clubs, providing August decides to be a bit more summery. |
JasonB | 19/08/2019 08:42:14 |
![]() Moderator 20289 forum posts 2218 photos 1 articles | I assume these engines need a steam test before you can go an run them anywhere just like any other newly built loco? |
Tony Falloon | 19/08/2019 10:12:05 |
![]() 16 forum posts 4 photos | Yes Jason, mine has only got the Shell Test Certificate. |
Tony Falloon | 19/08/2019 10:14:16 |
![]() 16 forum posts 4 photos | Posted by Bazyle on 19/08/2019 08:36:58:
Which club are you a member of? I’m a member of TSMEE in Newcastle
Neil Wyatt | 19/08/2019 10:53:20 |
![]() Moderator 18558 forum posts 723 photos 78 articles | Posted by julian atkins on 18/08/2019 23:32:20:
Neil Wyatt | 19/08/2019 10:55:49 |
![]() Moderator 18558 forum posts 723 photos 78 articles | Very interested to see what people make of these locos. I'm surprised there isn't more interest in bare boilers from the far east, as the cost of a boiler seems to be a barrier for some people. Neil |
