Canon Printer in Aldi
robjon4409/09/2017 08:37:32
123 forum posts
Hi all, dropped in local Aldi yesterday (Friday), stumbled on a stack of Canon Pixma MG2550S 3 way printers, I am not a fan of inkjets myself having had bad experiences in the past but I think you will agree that an A4 printer, copier, scanner of good pedigree for £23 has to be a bargain. Scurried off home, all set up in 15 minutes, knocked out a couple of black & single colour notices as a test, also a 6 x 4 photo on plain paper, will try gloss photo paper when I find it in this madhouse, so goes like a train. To illustrate how tight I am I do my black & white printing on a Brother mono laser that was an end of line at PC World for the princely sum of £25, these do not seize up if unused for long periods like inkjets, later
Robjon 44
Anthony Knights09/09/2017 08:55:37
395 forum posts
174 photos
I also bought one to replace a dodgey printer of a different make which I have. It's a good price, but the problem is, a set of ink cartridges cost more than the printer.
Clive Hartland09/09/2017 09:02:26
2561 forum posts
40 photos
I too bought a canon printer and within a month dumped it, it was not able to print A4 colour prints the size it would print was 100 mm x 150 mm. Also very noisy too. This also had a copy function but awkward to set up. My advice even at that price leave it alone. Epson are far better.
Neil Wyatt09/09/2017 09:16:46
17876 forum posts
705 photos
77 articles
I have a prehistoric but rock solid HP1022 laser for B&W and an Epson Ecotank for colour, cheap as chips to run.
Clive Hartland09/09/2017 10:37:38
2561 forum posts
40 photos
Agree on the Epson Eco tank printer- Epson ET-2500 Copier included.
larry Phelan09/09/2017 11:47:11
544 forum posts
17 photos
I bought a Canon printer two years ago which worked for a while then began to have problems taking in the paper.It became a pain-in-the-butt,was not worth the cost of repair and the ink costs more than the printer itself.
Looked it up on GOOGLE to see if anyone else had similar problems. Do they Hell ! It seems that Cannon printers are well known for this [look it up,check it out ]
Not much point in bringing these things back to a chain store,they know nothing about them and will just fob you off onto someone else. Next time I think about buying a printer,I will go to a proper outlet,with some kind of backup and service.
Paul Lousick11/09/2018 23:12:20
1405 forum posts
540 photos
It is important with inkjet printers to use them regularly to stop the ink drying in the nozzles.
There are also re-fillable ink cartridges available which cut down on running costs.
not done it yet12/09/2018 08:50:02
4630 forum posts
16 photos
Laser monochrome printers are so much cheaper to run and the print does not ‘run’ if the copy gets wet. More expensive to buy, yes, and the drum can be ruined by numpties - but that was my choice when we were doing ~10k copies per year.
These days ink jet printers are virtually loss-leaders, to get the revenue from the running costs of over-expensive ink cartridges.
My wife has had at least six and likely more than ten ink jet printers in rather less than twenty years, for one reason or another. Admittedly they now colour print, but are not cheap to run, especially if mixing colours to provide black print. I would buy another laser printer, but she wants something more easily portable...
Douglas Johnston12/09/2018 09:10:13
688 forum posts
32 photos
I went to buy a replacement toner cartridge for my Samsung mono laser printer and found the shop were selling off older model non wifi laser printers for £30,while the replacement cartridge was nearly double that price . I now have two laser printers!
I know that new printers come with a reduced capacity cartridge but I don't do much printing and expect to get at least a couple of years out of the new machine before I will have to buy a replacement cartridge or yet another bargain machine.The whole thing is silly
Doug
Vic12/09/2018 09:40:08
2500 forum posts
14 photos
We’ve had a Canon PIXMA 6600 (released 2006) for many years. We’ve never had any paper feed problems with it. On at least one occasion the printer was left unused for well over a year but worked perfectly when it was used.
Rik Shaw12/09/2018 09:57:23
1325 forum posts
361 photos
"I have a prehistoric but rock solid HP1022 laser for B&W and an Epson Ecotank for colour, cheap as chips to run."
Same here, only difference is ours is an HP P2055d. The Epson Ecotank ET 2500 can sit for a month or so without being used but always prints on demand without any problems. Ink cartridges are now just a bad memory.
Rik
roy entwistle12/09/2018 10:00:35
1172 forum posts
I have a canon Pixma MG5750 I can get a set of other manufacturers cartridges ( 5 ) for the price of one Canon. It gets left unused for several weeks at a time and has never given any trouble, either blocked nozzles or paper feed.
Roy
larry phelan 112/09/2018 10:12:38
716 forum posts
14 photos
Still say Cannon printers have a problem feeding paper. Check it out on Google.
When they start selling these things for £23,you can read between the lines [no pun intended ]
Trying to get them repaired? you must be joking !
Look at them leave them !
Muzzer12/09/2018 10:34:23
2904 forum posts
448 photos
At one point they were literally giving ink jet printers away with reams of paper. Presumably you would get it set up, start using it - and then the "demo" cartridges would run out. I acquired one like this and finally "recycled" it without even opening the box once I saw the costs and the penny dropped. Would have been better to have simply left it in the store.
Recently threw out an inkjet printer / scanner device at work. Usual problem - heads blocked because it hadn't been used for about 6 months. Apparently some people manage to fix them by washing out the heads in warm soapy water but you can imagine how this might go wrong! Some of the "professional" inkjets had replaceable heads as well as in cartridges but in my experience there was still a lot of buggerage uncertainty and expense unless they were used regularly.
I now just go for B/W or colour laser printers. Quick, clean, consistent and fairly quiet.
Murray
Edited By Muzzer on 12/09/2018 10:34:59
Neil Wyatt12/09/2018 10:57:00
17876 forum posts
705 photos
77 articles
How strange. This thread seems to be attracting a gentle flow of spammers trying to seed links to printer support sites.
Easy to stop, but I'm curious as to why they are doing this!
Chris Jones 312/09/2018 11:15:45
24 forum posts
75 photos
I have used Canon printers for probably 10 years or more and have never had a problem with paper feeds, in fact they seem to be remarkably reliable.
I would not buy the cheapest on offer of any manufacturer because has someone has already remarked you end up paying more for a set of the cartridges than the cost of the original printer.
When I wore out my IP7250 I upgraded to a 3 in 1 (MX925) machine that used the same sets of 5 cartridges because I had a couple on the shelf. It is an excellent machine. The cartridges cost less than £5 a set if you stock up with 4 sets from Prink. The cartiridges are high capacity and last a good while.
I print 6x4 photos with this machine and people think they have been professionally done.
Some people are silly enough to pay around £25 for a single HP cartridge that does'nt have anything like the capacity of the Prink ones.
You pays your money .........
Chris.
Simon Cook12/09/2018 11:21:30
14 forum posts
The thing is, £23 is good value in mind.
Not only do you get to use the printer until the demo ink runs out, but then you've got a whole host of brand new parts which can be harvested from it.
Straight off the bat, there will be two motors. Then there will be some half decent steel shafts, not to mention some (plastic) cogs and pulleys and maybe one or two toothed belts. Additionally if you want to keep them, other little bits like springs etc which can all be useful.
My printer cycle tends to be:-
Buy wife new cheep printer -> wait for ink to run out -> harvest printer for parts -> buy wife new cheep printer
I go though that cycle every 18/24 months.
David Colwill12/09/2018 12:31:11
633 forum posts
34 photos
I bought an Epsom XP412 because I had seen that the computer shop near me did the knock off cartridges for £2.00 for a black or £8.00 for a set of 3 colours and a black. It gets used pretty much every day (mainly printing delivery notes / invoices etc) and has given no trouble in the 3 years I have owned it. I still have the original Epsom cartridges as It didn't seem worthwhile fitting them.
David.
pgk pgk12/09/2018 13:06:42
1779 forum posts
287 photos
For an extreme example of being tight on buying cartridges.. one used to buy 500ml bottles of ink, drill a hole into the epson cartidge to inject a new alliquot of ink and then seal with a self-tapper prior to next refill. I was printing flyers and cards by the many hundreds and all went well until the day I knocked the red ink stock bottle over....
pgk
Vic12/09/2018 13:38:33
2500 forum posts
14 photos
I used to provide tech support in one of my jobs (300+ Employees) and many HP inkjets and small mono lasers ended up in the skip due to paper feed problems. Epson and Canon inkjets and the larger HP mono lasers (workgroup) were never a problem. One consistent problem was operator error, it’s really surprising the number of people that can’t follow simple instructions when loading paper.
