Help Needed.
Brian Abbott | 07/09/2017 22:42:53 |
![]() 477 forum posts 93 photos | Hello all, could anyone who has fitted one of these offer me any help. They have supplied a new end bearing plate ( on the right ) i thought i maybe have to replace the current plate ( one on the left ) with this one as this is the correct size to fit within the grey mounting plate, but there is no thrust bearing for the drive gear to pull up against, have they supplied the wrong plate ? Thanks for any help.
Edited By Brian Abbott on 07/09/2017 22:43:45 |
Brian Abbott | 08/09/2017 10:31:39 |
![]() 477 forum posts 93 photos | Morning. Spoken to Warco but there not able to offer me any assistance.. As it stands i can modify the existing plate ( Cut the ends off ) and it should work ok, interested if anyone else had the same problem. Thanks. |
mechman48 | 08/09/2017 10:58:34 |
![]() 2886 forum posts 449 photos | FWIW, I can only suggest that you are s'posed to use the existing bearings, or, looking at the housing size you may have to buy bearings to suit. I'm surprised that Warco didn't offer any assistance. I made my own power feed arrangement so retained the original end plate & bearing. |
Brian Abbott | 08/09/2017 11:05:59 |
![]() 477 forum posts 93 photos | Thanks for the reply.
Cheers.
Edited By Brian Abbott on 08/09/2017 11:08:05 |
not done it yet | 08/09/2017 14:40:12 |
5776 forum posts 20 photos |
They have said i can return the feed so might just do that.
At their cost, I would hope, if they have made modifications to their specific model and nobody from their end 'flagged it up' before sending you the wrong item. Question is:what are they (or you) going to replace it with? Power feed is a great improvement for most of us (I certainly cannot get the same finish by traversing manually).
Mark Dickinson | 08/09/2017 20:21:01 |
48 forum posts 4 photos | There is a video on you tube of that power feed fitted to a wm18 https://youtu.be/Ax-uZHJQNEI
mark |
Brian Abbott | 11/09/2017 21:43:26 |
![]() 477 forum posts 93 photos | Thanks both for your reply's I modified the end bearing plate ( 2 new dowels and cut about 10mm of each end ) and the feed fitted a treat, no problems. Cheers. |
Mark Dickinson | 12/09/2017 21:18:44 |
48 forum posts 4 photos | Brian, would you be prepared to post a picture or 2 of the power feed in place. I have an older mill too and I've been looking at buying that power feed . Thanks Mark |
Brian Abbott | 12/09/2017 22:26:14 |
![]() 477 forum posts 93 photos | Hello Mark, yes, no problem at all, i will try and do it tomorrow night. |
Brian Abbott | 17/09/2017 21:03:01 |
![]() 477 forum posts 93 photos | Hello Mark, sorry for the delay, no shed time recently... Couple of photos below. I had to alter the original bearing bracket, just drilled a couple of extra dowels then cut about 10mm of each end. One point to note, when i asked warco for some photos of the assembly they sent a photo of one in their showroom, this had a completly differant gear setup, not sure where this came from but if they had sent this type it would have been no use, i can post this photo if i can find it. Thanks. |
Brian Abbott | 17/09/2017 21:11:46 |
![]() 477 forum posts 93 photos | Photo supplied from Warco. Toothed gear, would not fit my machine and luckily not supplied in my kit ! |
Mark Dickinson | 18/09/2017 06:20:08 |
48 forum posts 4 photos | Thanks Brian. Think I'll start saving my pennies for that |
