Making Tool holders for my Shaper
Used the shaper to make parts for Toolholders for itself..
Joseph Noci 101/09/2017 15:42:40
827 forum posts
1026 photos
Me again...
I used my Nice New ALBA NC shaper to make new jaws for its vice, and promptly decided that the next thing to make is a darn Chip guard! Wow, can that shaper toss chips about! As the only space I have left for it is in the Woodwork shop, chips don't go down well in there!
So, here are some pics of the guards - quickly fitted and removed by means of 4 thumbscrews, and 4 ex-hard-disc drive magnets siliconed to the guards:
Two right side thumbscrews
Two left underside magnets
Then I started making some toolholders for cutters made from 10mmx16mmx80mm HSS.
First doing the flat bars in the shaper:
One bar is 12mm thick, the upper bar in the pic below, the other is 16mm thick. The 12mm bar made horrid chips - all squashed and scrunched, torn out of the bar, while the lower bar chips curled off nicely. Both mild steel, with black scale, flame cut to sort of size - supplier could not tell me what grade/type of steel these were!
The lousy chips come from the upper bar in the pic below...Surface finish is strange! Same feed speed, DOC, ram speed and cutter as the lower bar. Upper bar cut first.
Cutter as ground as used - a HSS cutter 10mmx25mmx150mm
The open slot end of the tool holder - fitted with steel insert to be welded..
Castle tool holder clamped to bar, ready for welding
TIG Tacked...
All welded and cleaned up, ready to use.
Welding dome with TIG, at 200amps to get real deep penetration, and to put the weld where I wanted - not so easy with MIG..
richardandtracy01/09/2017 16:01:06
943 forum posts
10 photos
I suspect the upper bar was structural steel. Had the same finish on a bit of S275 (430 N/mm^2 ultimate, 275 N/mm^2 yield, weldable fine grain steel) from a channel section. Not nice finish. Retains grease well, if it's any consolation.
Looks pretty good otherwise.
Must use my Boxford more.
Richard
Andrew Tinsley01/09/2017 16:06:58
1262 forum posts
Blimey! The shaper looks brand new! I didn't think shapers were made any more, so it must be a really high grade restoration! CNC too, the mind boggles!
Seriously I suggest that you submit the rebuild (?) as an article in MEW, very little good shaper information about. It would make a change from "One man and his Lathe"
Andrew.
Neil Wyatt01/09/2017 16:47:08
18425 forum posts
718 photos
78 articles
It would be most welcome. I have mentioned this thread in the next issue.
IanT01/09/2017 18:01:02
1750 forum posts
164 photos
Damn Joseph, now I'm going to have to upgrade from the cardboard box I've been using too!
IanT
Clive Foster01/09/2017 22:04:33
2540 forum posts
83 photos
Another vote for wanting to see a write up on the restoration job and details of how the numerical control was done.
Vested interest in my case as a similar NC exercise for mine is on the "have a good look at it list" for, provisionally, 2020 - 21. Shop Gremlins permitting of course. Fairly sure Josephs work on the NC side will be better than what I'd do if starting from scratch. Special attention to gear cutting in y case as I'd like to do a full set of extra gears for my P&W B once the service, spruce up and re-paint planned for 2019 - 20 is done. Not that I need the gears but might as well do the job right.
Clive.
EngineDIY
