UK or chinese source for ER20 collet nut "hook/c" spanner
SteveI28/08/2017 17:32:42
246 forum posts
17 photos
Hi,
I would be most grateful if someone could identify a source for a C/ hook ER20 collet nut spanner similar to these but ER20 size:
I have found one via ebay.com in the usa but the postage is prohibitive so need a UK/European or Chinese Free shipping source.
Thanks,
Steve
David Standing 128/08/2017 17:45:37
1289 forum posts
48 photos
Arthur Sixsmith28/08/2017 17:49:04
17 forum posts
Hi I have a collet nut spanner marked 28/32 .this is much to small for my ER32 collets.If its any good to you send me your address and I will post it of to you tomorrow Regards Arthur
Mike Poole28/08/2017 17:51:34
2693 forum posts
64 photos
C spanners are often marked with the diameter of the curve, so measure your nut and search for C spanner of that size, they will often cover a small range of diameters. Hinged types are available with a wider range but I think these would be a nuisance on a regularly used tool.
Martin Connelly28/08/2017 18:10:42
1419 forum posts
165 photos
Search for ER20 collet wrench.
Martin C
David Standing 128/08/2017 20:11:08
1289 forum posts
48 photos
Posted by Martin Connelly on 28/08/2017 18:10:42:
Martin C
See post #2 wink 2
Brian Sweeting28/08/2017 20:36:36
437 forum posts
I thought ER20 chucks were spanner flats not notched.
JasonB28/08/2017 20:45:09
18621 forum posts
2047 photos
ER20 Mini nuts need the C type spanner, standard ones are hex
SteveI28/08/2017 20:57:46
246 forum posts
17 photos
Hi,
Thanks all.
The application is for the spindle nut, and nut on a quick step mill. For the nut it requires the C type spanner or one of the spanners that engages multiple places,
Like these:
but on the spindle part I need the C type spanner as I can't get the other type in and away with the nut on. It would have been nice if it had spanner flats but there you go.
I'll see how I get on with it and in the longer run may get an ER20 ball bearing nut from Arc.
Thanks,
Steve
MadMike28/08/2017 23:17:23
208 forum posts
4 photos
Steve it is interesting that you have used ArcEuro to show the type of spanner you want.
If you refer to their on line catalogue you will find that they do sell ER20 Collets etc. They are classified as Mini-collets and have their own spanner to use when tightening. I would suggest a call to Arc Euro will hopefully solve your problem
If not then try a Google search for a C Spanner, or if all else fails simply make one.
Iain Downs29/08/2017 07:44:10
678 forum posts
612 photos
I got one from eBay which is adjustable - granted for a ER32 collet, but a smaller adjustable one should work. (that is there is a hinge of sorts allowing a range of diameters.
I also made my own which just requires a decent piece of bar and some basic skills.
Iain
Martin Connelly29/08/2017 09:33:48
1419 forum posts
165 photos
AMF are one supplier of hook wrenches that go down to 12mm,. Half way down on this page there is a list of the sizes they do.
Other people probably have them as well but if there is one of the size you want then it is just a case of searching for that size and picking your preferred supplier.
Martin C
SteveI29/08/2017 12:56:49
246 forum posts
17 photos
Posted by Iain Downs on 29/08/2017 07:44:10:
Iain
You forgot the other requirement, the one which is my major constraint; time. I have limited workshop time and I prefer to spend it doing something interesting. Making a spanner which I can get delivered for less than £6 is not high up my projects list. My order is placed.
Edited By SteveI on 29/08/2017 12:57:19
Arthur Sixsmith29/08/2017 16:18:22
17 forum posts
I have offered you one for nowt? Arthur
SteveI29/08/2017 22:27:22
246 forum posts
17 photos
Arthur,
Thanks for the offer. Perhaps someone else is more deserving.
Steve
EngineDIY
