Off to the races!
Dean da Silva26/08/2017 22:51:06
221 forum posts
I knew in time that I would have to start putting my money where my mouth is- so here is the start of the first locomotive in my undertaking, the Rose. Not the best rendering, it's only a mock up- but this one shouldn't take too long to complete!
RRMBK26/08/2017 23:03:52
132 forum posts
18 photos
Hi Dean.
Really nice to see you are doing this lovely little engine
I have built Rose and one of the real problems came with setting the valve events for the slip eccentric with the cylinder and valve chest mounted in the frame. The only way I was able to do it was to cut an oval slot in the frame adjacent to the valve chest and view the valve events through there. Also as I built the coal fired boiler. the smoke box mounting details and getting a good smoke box seal proved very difficult. Otherwise it is a great little engine but let down by the lack of an axle driven pump.
The 21/2 gauge association hold castings for most of the main parts on Rose if anybody decides to build based on your rework of the design.
Well done in your efforts and the first posting looks great.
If you want any more detail private message me
Kind regards
Brian K.
Dean da Silva26/08/2017 23:12:37
221 forum posts
Posted by RRMBK on 26/08/2017 23:03:52:
Hi Dean.
Kind regards
Brian K.
Brian,
I actually planned on donating the CAD files for all the 2 1/2" gauge locomotives I draft to the association. I did the best I could on the wheels, I understood that they were similar to the ones that are on the Petrolea. I think that I might build this little gem, it's a beautiful little locomotive, I like the way that Curly designed it and my machining abilities are... still in the learning phase. Thankfully I have clients that have built plenty of locomotives who are more than eager to help me out.
I'm glad you like it sir, it's nice to hear from someone that has built this little locomotive!
-Dean
Dean da Silva27/08/2017 08:06:55
221 forum posts
Thank God there are parts of this model that are more... straightforward- I hope.
The instructions for the steam chest were lovely, and I think I did a great job impersonating the look of castings thus far (not sure how people feel about the wheels) but so far everything seemed to be going smooth.
THEN I REACHED THE CYLINDERS. The holes don't line up. The instructions about the porting are as clear as pond water.
You win tonight Curly, you old rascal.
I'll move onto another section, and address this one later.
JasonB27/08/2017 08:11:07
17315 forum posts
1865 photos
Dean are you making any allowances for currently available materials over what Curly has on the drawings? For example in the UK and mainland Europe you can no longer buy sheet steel for the side frames in wire gauge thicknesses, you have to use the nearest metric and adjust the buffer beams and stretchers to suit.
I don't see anything out of the ordinary with the porting and passages, this was one reason I asked if you had any experience of making engines as it is the same basic method used on 90% of engines. There is a risk of assuming one thing if you are not sure what is in the text or on the drawing when Curly is actually doing something else
Edited By JasonB on 27/08/2017 08:21:51
RRMBK27/08/2017 10:21:03
132 forum posts
18 photos
Hi Dean & Jason
from memory I think Dean is right,the holes don't line up. And there are a lot of inaccuracies in this design /drawings. I remember having quite a faff about with my port settings as per my first post. I think some of the problem stems partly form the fact that Curly designed it originally as a spirit fired loco and added the coal firing as an afterthought. Also reading Hollingsworths book I have a feeling that this design is not one that LBSC actually made himself.
I think Jasons point is a good one as I had to make quite a few allowances for different material sizes when I built mine some years ago.
Dean da Silva27/08/2017 19:06:22
221 forum posts
Posted by JasonB on 27/08/2017 08:11:07:
As far as the wire gauge sheet steel is concerned, no. I am not, I'm going off of the nearest imperial size. Part of the reason with this project I have found myself keeping a lot of notes is this exact reason- I would rather hold off on something unless I am absolutely sure I have the correct I have the correct impression about the way the part is to be modeled.
For example the frame holes lining up with the cylinders- I think it would be safe to assume that they could be made to align with the pattern for the cylinder, but that doesn't mean I wont make a note of it for later.
I know enough about machining to avoid making the impossible to mill/turn parts- but my experience with building models is lacking. Mostly because of finance.
Dean da Silva27/08/2017 21:15:26
221 forum posts
Posted by RRMBK on 27/08/2017 10:21:03:
Hi Dean & Jason
I have decided to stick to commonly found imperial sizes- no wire thickness sheet metal will be found in any of my designs. Regarding threads, I'll be sure to have a nice, standardized list of threads I've used in lieu of the ones Curly used.
The second portion of this model (the one that concerns the valve/cylinder) falls into this ugly "I had to wing it" category. The inner frames do too, but I think that I did at least an acceptable job of relocating the holes to align with the cylinder.
Dean da Silva27/08/2017 22:13:19
221 forum posts
From what I could gather thus far:
The front two whole for the cylinders on the frame were located correctly, the rear holes were not. The cylinders attach to the frame using the holes in the corner, and the three holes in the centre are more or less there to help hold the whole assembly together sans the frame.
As I've mentioned, this second part of the build series has been sort of fired from the hip, eye balled, etc.
Dean da Silva28/08/2017 04:47:01
221 forum posts
Well... everything seemed to be going okay until I put it all together and tried to make it move.
Then it went from "I don't know" to "***************************" (bad words)
The good news is that while its wrong, wrong, wrong, (partially by my doing) at least it's doing something.
Dean da Silva01/09/2017 07:25:55
221 forum posts
I have never had a boiler cause me as much of a headache as this one, the dimensions make zero sense, the article was about as helpful as an American government employee, I'm about 98% sure its wrong, or the drawings are wrong, or I am a complete and utter dunce.
RRMBK01/09/2017 17:16:17
132 forum posts
18 photos
Kind regards
Brian K. .What sort of problems are you having? Apart from no crown stays it looks a lot like the boiler I built.
Dean da Silva02/09/2017 05:38:20
221 forum posts
For now, I am going to just leave the boiler in the same sort of situation I usually leave my sister- alone.
(I don't actually have a sister.)
The tender is coming along nicely though!
JasonB02/09/2017 07:28:07
17315 forum posts
1865 photos
It may be worth pointing out that if you right click any of Dean's images and then select "copy image address" then paste that into your browser you will get a full screen image which looks even more impressive. Mac/Ipad users may need to do something different.
Michael Gilligan02/09/2017 07:39:38
15024 forum posts
645 photos
Posted by JasonB on 02/09/2017 07:28:07:
On iPad ... press and hold on the image until a pop-up appears, offering
| Save Image | Copy |
Select Copy, and then paste that address into a new browser tab.
Edited By Michael Gilligan on 02/09/2017 07:41:49
NJH02/09/2017 10:23:07
2314 forum posts
139 photos
.... or indeed, on the iPad, just use two fingers on the image and " Stretch" it to fill the screen.
Norman
Michael Gilligan02/09/2017 14:06:39
15024 forum posts
645 photos
Posted by NJH on 02/09/2017 10:23:07:
Norman
Correct me if I'm wrong, please Norman, but: Doesn't that just result in 'empty magnification' ?
Edit: [answering my own question] ... in the case of these images, which are only small anyway, there is no difference.
Edit: I had misinterpreted Jason's post blush and initally thought there was a hidden link to a higher resolution image.
Edited By Michael Gilligan on 02/09/2017 14:27:53
Dean da Silva02/09/2017 21:04:03
221 forum posts
Alright, little update here.
For the sake of retaining the few last pieces of sanity I have rolling around upstairs (and for practical reasons too) I have decided on the following:
1. The boilers as I draw them will not have internals, they will just be the outside shells. Reason being is the boiler standards have changed as I have been informed, and it I think it would be a bit silly to draw the whole thing just to have it altered. I'll leave that to the good folks I am sending these designs to.
2. Water pumps, valves etc. on the back heads of boilers really can be of any design that is compatible with the design. I'm more interested in the locomotive itself, it's design rather than little plumbing oddments.
3.The outlines of some of the parts such as the frame sides are kind of approximated. The drawings are not the best that i am going off of. I can try, but I can't guarantee that it is spot on when there is a lot of undimensioned radii.
4. I'll get as close as I can with the cast parts as well, but there is only so much I can do reasonably with them.
5. I DID check into Curly's stance on rivets. There is a reason they are all countersunk, he thought that they made locomotives look as though they had pimples.
Over all I would say the Rose is coming along well, I am looking forward to a locomotive called the "Bass" and the "Zoe" quite a bit. Now if I could find the 1800s era article on the original Ajax 2-2-0 that would be something really interesting- it was Curly's first locomotive after all.
Dean da Silva02/09/2017 21:57:34
221 forum posts
Since I am at it, just to give everyone an idea of what I am up against and why I will be omitting some parts.
Here are the locomotives I will be drawing for sure:
0 Gauge
-Cracker
-Diesel Outline
-Minnehaha
-Miss Therm
-Mollyette
-Myrtle
-Bass
-Economette
-Netta
1 Gauge
-Miss Economy
-Bass
-Speedyette
-St. Hildas
-WD Stanier
-Amy
-Chingford Express
-Daisy Drummond
-Dyakette
-Ford Pacific
-Little Jack Horner
-Netta
-Zoe
-Mona
2.5" Gauge
-Economary
-Eva May (tender and tank)
-Bass
-Mabel Hall
-Nippy
-Sterling Single
-Victoria
-Ajax
-Annie Bodie
-Belle Stroudley
-Canadian Switcher
-Dairymaid
-FIRS 245 (Six Year Old's 4F)
-Judy
-Kingette
-Lady Kitty
-Mary Ann
-Netta (surprise surprise)
-Pansyette
-Pixie
-Simple Sally (there are FOUR versions of this one, thankfully it won't be hard)
-Talula
3.5" Gauge
-Dairy Maid
-Duchess of Swindon
-Ivy Hall
-Sister Dora
-Zoe
-Netta
5" Gauge
-Minx
-Netta
Now then, we come to the "special cases"
0 Gauge
-Bayer Garretts I&II: I really hope that there is enough to work on with these two! But they might have just been doodles that were published rather than full designs.
2.5" Gauge
-Lucy Anna: Published in Modelmaker in the US, in the 1920s. I really don't think that I will be able to track this one down, I pray that seeing other American locomotives of this variety I find a lot of commonality between them and can work from that. This one could actually TRULY be lost. Which I hope isn't the case.
-Liberation, LBSCR: I haven't the slightest idea about these two. I can't find really anything on them. Then again I haven't looked very hard.
-Cleopatra, Hollywood Annie: They might just be doodles, I hope that there is enough to work on.
Other
The earliest drawing I can find that Curly made was for a little tank engine, the Lylia. It's in 2" gauge, and honestly might end up becoming one of those "colour in the lines" projects where the outside is viable and the rest needs to be designed. It would probably end up being in 2.5" gauge when it was done.
Oh, and the reason behind all five Nettas?
Coolest group rendering ever. smile d
Edited By Dean da Silva on 02/09/2017 22:03:41
RRMBK02/09/2017 23:20:40
132 forum posts
18 photos
I do remember reading an article on the O gauge Beyer Garrett but it wasn't very much detail. I will try and find it.
Seems like you are setting out a whole lifetime of work for yourself here!! but I'm sure there are many people who would benefit from the results of of your undoubted computer skills. I have tried to get into CAD but its completely beyond me and also I suspect many others of my generation. I hope that we all can give you support from this side of the pond in researching old articles etc.
Kind regards
Brian K.
