PCB CNC
In the dark!
Colin Osborne02/08/2017 21:54:12
50 forum posts
35 photos
Hi all,
I'm guessing this is the right place for this topic. As a Radio Amateur I get the relevant publications and in one of the recent ones, Practical Wireless, there was an article for using a CNC router to cut PCB's. The author did not give the make of the one he bought and assembled, but it looked to be quite a useful piece of kit. But, although I build, repair and generally swear at computers, I am in the dark on this black art.
Has anyone used one of these types? Obviously they are small but that suits me just fine as my tiny workshop already has a lathe, a bench pillar drill and a large grinder. So if I decided to buy one of these routers it would go in my 'play room' upstairs. Apart from the PCB side of things what are the other uses I could put it to? In other words, what would be its limitations? I'm not after making a full sized model of 'The Flying Scotsman', I can do that later with a hacksaw and a filelaugh.
I have had a quick look on the web and can see, like all things, there are varying prices and you only get what you pay for, but if anyone has got one, or used one, and can give an opinion on them I would be most grateful.
Cheers, Colin.
Neil Wyatt02/08/2017 22:24:28
19032 forum posts
734 photos
80 articles
Strikes me that if you had a 3D printer, you could print a dremel holder to replace the print head.
If you can level a 3D printer properly, then it's level enough to engrave PCBs.
Joseph Noci 102/08/2017 22:59:22
1081 forum posts
1309 photos
Hi Colin,
I built my own 'mini-router' specifically for isolation engraving of PCB's. The kind of PCB's you want to do will determine the characteristics of the machine.
For very fine tracks ( I do down to 0.4mm tracks with 0.4mm spacing between tracks..):
The machine should be as rigid as possible with 'no' backlash in the leadscrews.
The spindle should be as high speed as possible ( 20000RPM is good, 30000RPM is great), The cuuter tip is very fine - maybe around 0.15 to 0.2mm at the cutting edge, and speed is needed.
The cutter geometry is critical - D-type engraving tips made from fine-grain carbide are needed, esp if working with FR4 - a fiber-glass PCB substrate. Cutter penetration is a scant 20um to 35um, so only the very tips does the work, and if that tip grind , relief, etc, is incorrect, all you get are ragged burrs and poor engraving!
And last, but very necessary, a floating spindle makes for a good engraving! Since the engraving tip is conical, the deeper you go, the wider the groove, and the more you cut away of the copper track sides. So maintaining depth is critical. Trying to get the router table perfectly flat is not easy - the frame of the router is flexible enough that if the machine is on a table top, just the flex in the table top makes for many 10's of um twist in the router table, which mucks with your depth. And then the PCB material is not perfectly uniform in thickness either, and it is almost impossible to keep the PCB flat on the router table either - some folk superglue it down, etc, but flat is never is. So, use a floating spindle , running on a teflon foot on the pcb, and depth is fully controlled.
If you get a handle on these elements, then the process works, is totally repeatable, and makes great PCB's - I have made hundreds this way!
Here are some pics of my engraver and an example PCB for a very fine pitch surface mount IC..
The machine table is about 400mm long by 300mm wide - small but very rigid.
Mini-Router/Engraver
CNC Engraver Floating Head
PCB Being Engraved
I use the same engraver to pick and place the IC on the engraved PCB using a vacuum plunger..
The tracks and pads on this IC are 0.5mm apart..
Small IC placed on engraved PCB
I sharpen my own engraving tips on a diamond wheel on the small T&C grinder I made.
Joe
John Stevenson03/08/2017 07:24:46
5068 forum posts
Have a look up at the one sold by Banggood and demonstrated by Myford Boy. On you tube
Not as class as Joseph's but quicker to obtain and a damn sight cheaper
Colin Osborne03/08/2017 08:51:16
50 forum posts
35 photos
No 3D printer yet, Neil, but it's on my list!
Wow! Joseph, that is some router, well done. I don't think that I need to go that far though, I don't do that many PCB's but I did used to etch them using Ferric Chloride, that is messy and it stains! Although the results are good. I have been using a Dremel type drill with a dentists bit. It works but is not ideal!
This is why I wondered what else it would be useful for, so I could justify getting one. I have to admit, to me it is one of those pieces of equipment that I would love to have so will find an excuse to use it!...... Aw, c'mon, I can't be the only one who thinks like that! ..... Am I? (the same goes for the 3D printer, Neil!)
John, thanks for that, I'll take a look. Much appreciated!
Cheers, Colin.
Douglas Johnston03/08/2017 09:39:43
767 forum posts
34 photos
That is a super machine you have there Joseph. Did you use ball screws for the X-Y-Z motions? I was also intrigued with the use of the model helicopter type motor for the spindle, was that easy to power?
Doug
Andrew Johnston03/08/2017 10:59:24
6601 forum posts
701 photos
Posted by Douglas Johnston on 03/08/2017 09:39:43:
Indeed it is, very professional, I'm impressed.
But (there's always a but) I suspect the usefulness depends on circumstances. I'd make a guess that PCB manufacturers are not ten a penny in Namibia? So for Joseph it is essential. However, in the UK there are several companies that will take CAD data and manufacture small quantities of simple double-sided and multi-layer PCBs at reasonable prices. Certainly much cheaper than a PCB router. We had a PCB router at the last company I worked for, very expensive as I recall, but simply didn't get used. It couldn't cope with the standard track and gap widths used and was too slow.
Ah, I remember 'drawing' tracks on PCBs and using ferric chloride as a kid, but almost no surface mount in those days! Got banned in the end as I left too many stains around the house, and ruined too many clothes. Generally I no longer do electronics as a hobby, but if I was I'd get PCBs made outside. That's what I'll be doing when I get around to completing the design for my traction engines lamps, using LEDs but driven to simulate the instability of a naked flame.
Colin Osborne03/08/2017 13:46:13
50 forum posts
35 photos
Andrew, I'm glad that I am not the only one to be leaving those stains around the house! As you so rightly point out, these machines are expensive for what their output is, certainly in my case. I think I will stick to using the dremel like tool I have and put the money towards a 3D machine. Maybe that suggestion of Neil's could be investigated! Come on Neil, it was your suggestion, how would you go about it? A nice MEW article project for you!
There was one thing I did find out from looking at web pages, and that was how the cutters used to make the 'tracks' were shaped. I have been using some dentists drills I managed to scrounge years ago, freehand, it doesn't take much to make a mistake! If I can get hold of some cutters that will fit into the 'dremel' and make a stand with a scissor like action on a swivel arm that would keep the 'dremel' upright and firm it could be all I need. Or at least better than what I am doing at the moment. I'll have a think.......zzzzzzz!
Cheers, Colin.
Brian G03/08/2017 13:57:19
840 forum posts
37 photos
This looks like a useful alternative to engraving the PCB by hand.
Colin Osborne03/08/2017 15:01:10
50 forum posts
35 photos
Ha! That is basically what I had in mind, apart from the bit that does the tracing. Just guiding the cutter by hand. Not sure about the 'painting' though!
If I do have a go at it, I think I would rather make the pantograph from Alumimiun than from wood.
Many thanks, Brian! At least I now know it wasn't such a scatterbrained idea after all. And that there is nothing new in this world!!
Cheers, Colin.
Brian Corrie09/12/2017 18:23:51
7 forum posts
Posted by Joseph Noci 1 on 02/08/2017 22:59:22:
Hi Colin,
PCB Being Engraved
Joe
Hi Joe, could you give some more details of your floating spindle design? I have a Chinese CNC which is sort of OK for pcbs but this looks like it would be a good retrofit
Cheers
Joseph Noci 109/12/2017 20:13:16
1081 forum posts
1309 photos
Hi Brian,
The floating spindle is fairly simple - the spindle ( itself just an RC brushless motor the main shaft of which removed and fitted with an 8mm long body ER8 collet chuck) - sits on the horizontal cross member in the photo below. That member has two 10mm vertical shafts that slide in the two aluminium blocks ( left and right) which are fixed to the Z axis. The nose of the spindle has a fine thread screw-in cone, fitted with a PTFE 'shoe' that rides on the PCB, with the engraving tool set to protrude below the shoe by the depth of the copper on the PCB - about 40um or so.
Some pics that may assist:
Spindle bussines end-
The floating 'foot'
The 'grooves' in the PTFE foot are so air can be sucked in via the vacuum attachment - see later pic down the line.
Floating Head in down position
And here in 'raised, position - as it would be when the foot touches the pcb and lifts the head.
The black elbow pipe in the pic above is a Vacuum attachment point - sucks up the debris through the nose cone and foot, keeping the PCB clean and clear of shavings - else the foot rides high and the engraving tip does not penetrate properly.
These tracks have a 0.12mm isolation cut ( the light shining through the groove) and the pads in the center for the IC are 0.5mm wide.
Hope that helps - ask if your want more detail. Important that the slide that the spindle rides up and down on on the Z axis ( not the z Driven axis..) is a close fit - no slop, since this will translate to poor track definition and resolution.
regards
Joe
Doubletop09/12/2017 21:19:19
439 forum posts
4 photos
I realise that this is something you may want to do in persute of your hobby, but if its just a PCB you are requiring then you may want to try this approach.
Design your board using the free Eagle Light PCB design software, generate the necesary gerber files and place an order with PCBCart. The limits of Eagle in free mode are 100mm x 80mm. I've just got PCBCart to quote for a double sided, through plated, silk screened board of that size and they are quoting US$36 for 5 boards, of prototype standard, shipped with 5 days turn around. As they say, here's one I did earlier...
I've binned my own PCB making capability. It just isn't worth the effort these days.
Pete
Edited By Doubletop on 09/12/2017 21:26:26
Joseph Noci 110/12/2017 06:21:53
1081 forum posts
1309 photos
Pete, I used to think like that as well..It does take a little longer for me to get boards made your way - Shipping from UK/China/wherever to Namibia takes long and costs a LOT more than $36..
But that is not the point. The router, if built decently and sturdily, is not just a PCB engraver. It does a sterling job of front panels for projects - easily do the lettering and control definition, route out the holes to fit controls, etc. And then route the enclosure panels out - I use single sided FR4, 1.6mm PCB, and then simply solder up the enclosure by solder tacking all inner corners lightly.
Colin mentioned the intent being as a tool to supplement his Radio Ham hobby - As a fellow Ham, I use this tool almost daily. I do a circuit design and PCB layout after Dinner, Engrave the PCB the next morning in a half hour - assembled by lunch, discover the major snafu before dinner, and do a new layout after dinner. By the next afternoon the board is assembled and tested and I start the enclosure and front panel layout. The next day the enclosure is together and the project done and dusted...and it cost maybe $2 in PCB material...While you are still waiting for your boards to arrive, and to discover your Snafu...
Here is a Wildlife Collar Tracking Receiver I made - enclosure all PCB, front Panel routed and engraved likewise.
And here are the 'modular' PCB's for the various electronic gubbins that make the receiver.
Try making commercial boards for that, and carrying the cost of repeats while you experiment..
Here are some neat Antenna I make for our UAV's - all PCB material, and routed on the engraver.
And a Fuel level sensor I made for my Off-Roader - A BIG DIESEL!!!! Long Live DIESEL!!
The old, failed, encapsulated sensor shown bottom right...
So, Don't knock it till you have tried it - I would not trade it for ANY PCB service!
Joe
Joseph Noci 110/12/2017 06:44:09
1081 forum posts
1309 photos
Another 1 or 2 front panels made in the same way -
This the control panel for my NC Shaper:
And the completed panel:
The Control panel for my Maximat V10P ELS system - all in FR4 PCB.
.......Joe
MW10/12/2017 07:17:59
2051 forum posts
51 photos
Looking good Joe,
Michael W
Michael Gilligan10/12/2017 09:20:25
20182 forum posts
1053 photos
Posted by Joseph Noci 1 on 10/12/2017 06:21:53:
Joe
star That's the most effective "pitch" I've seen [for anything] in many years, Joe.
KWIL10/12/2017 11:30:17
3554 forum posts
70 photos
+1 Enthralling description, could sit here and watch/read for a long time. Thank you Joe.
Joseph Noci 110/12/2017 12:04:26
1081 forum posts
1309 photos
Thanks Chaps - glad to know it interests more folk and not just me!
I have a strong (!!) dislike for some/many of the techno-terms that pop up with today's rate of technology discovery and advancement - one of my pet hates is the term 'enabling' as in 'an enabling app' (oh, also the term 'app'...) , but the little engraver for my part deserves to be called an enabling technology! Without it many of my projects would simply not be..
Joe
Dave Martin10/12/2017 12:11:17
101 forum posts
11 photos
Bravo Joe - great kit and well explained. Can I just ask - do you ever do double-sided boards on this engraver, and if so, how do you register them and what registration accuracy do you get?
Rapid RC
Dreweatts
