Pansy
Peter Maloney31/07/2017 21:40:12
30 forum posts
12 photos
Hi all
Just thought that I would add a few pics to my album showing progress on my first model. As you can see I have jumped about production depending on money, time and materials available.
You will see many temporary fixings in place. The holes in splashers are jig holes which need filling. Not too happy with square corners on bunker. Will probably remake when my panel beating skills improve.
Pete
Richard Dobson01/08/2017 15:24:38
27 forum posts
Hi Peter, I am also just starting a 5" Pansy. Still drilling out the chassis at the moment. Any recommendations would be appreciated. Hope the build go's well.
Richard.
Richard Dobson01/08/2017 15:34:52
27 forum posts
Can I also ask a maybe stupid question, or two really.
I have noticed that on some forum photos the pansy chassis has an increased quantity of holes in the chassis plates. This doesn't tally up with the supplied drawings. Am I missing something.
Also, I'm sure I read somewhere that the holes for the brake hangers should be relocated other than shown on the drawings. Have you done this and if so, would you mind sharing the wealth a little.
Peter Maloney01/08/2017 21:10:12
30 forum posts
12 photos
Hi Richard
Out of interest I have been working on my Pansy on and off for 4 Years (more off than on). Not all holes are shown on drawings - the reversing bracket for example. I was lucky enough to have a full set of ME mags detailing construction and I sifted through these to find details of all extra holes to include at main frame drilling stage. They can be put in later but may involve a strip down of chassis.
The brake hanger holes should be 2in from bottom of frame. I had already put the 'wrong ones' into my frames before I found out.
In my album pics you may have noticed a 'funny frame stretcher' behind crank axle This is just temporary. The grey spray paint is just to protect against rust during construction.
There are quite a lot of other errors also. If you do a search on 'Pansy Errors' on Google you will find them.
Have you read all the posts in ME for Pansy? I was totally confused over variations in valve gear dimensions but Julian Atkins came to the rescue with a suggested correct design which I am following.
I don't feel that I should give you these details direct without Julian's approval. Hopefully he will see this post and come to your rescue also.
Pete
Peter Maloney01/08/2017 21:19:04
30 forum posts
12 photos
Hi Richard
It's me again. Have you seen the discussion in the expansion link forum?
Pete
Richard Dobson01/08/2017 21:45:02
27 forum posts
That's OK Peter, Julian has very kindly passed on all his knowledge regarding the valve gear etc a few weeks back. It was very nice of him, so thanks Julian.
I have managed to find copies of ME that detail the pansy build. So far month by month I am slowly purchasing these old volumes, but it's been hard graft. I also hope to make a visit to look over a Pansy, although I am currently not awere of ones location.
Your build is looking great, fingers crossed if mine looks half as decent I'll be happy.
Richard Dobson01/08/2017 21:51:19
27 forum posts
Regarding the expansion link forum, that'll be a no not yet.
Richard Dobson01/08/2017 22:00:48
27 forum posts
So regarding the break hangers, you've dropped them 7/16?
Thanks again.
Peter Maloney05/08/2017 13:23:03
30 forum posts
12 photos
Richard
If my sums are correct I have dropped ctrs by 9/16. This I believe brings the brake block pivot point in line with running position of wheel ctrs.
Also be aware that some Pansy info is given in LBSC's ways and means ME vol 118 issue 2973, ME vol118 issue 2978.
On sht 9 of drawings I believe the 2 5/16 dimn from bottom of cab should be 3 5/16. I have drawn this out and 2 5/16 does not look right. Hopefully there will be a Pansy on display at the Bristol ME exhibition later this month.
Pete
Cornish Jack06/08/2017 13:04:04
1093 forum posts
154 photos
Peter and Richard - a bit late to the party but I have just found a Pansy-related PDF among my 'general interest' files. If it is of interest, I will pass details but with the caveat that I do not know whether there would be copyright issues.
rgds
Bill
alan ord 206/08/2017 16:59:25
77 forum posts
Hi Peter, can you clarify your comments above. I have just checked sht 9 and cannot locate dimension 2 5/16. There is a dimension 2 15/16 from the bottom of the cab side to the window. I am some way off getting my Pansy build to that point of the construction but would like to know what the correct dimension should be.
Thanks, Alan.
alan ord 206/08/2017 17:01:51
77 forum posts
Bill, would you be so kind and send me a copy of the PDF. I will send you a private message containing my e mail address.
Alan.
Peter Maloney06/08/2017 18:16:57
30 forum posts
12 photos
Sorry Guys - I should have typed 2 15/16 & 3 15/16.
If you draw out 2 15/16 dimn on sheet 9 (assuming your drawing is 1:1) it just does not look right to me. I have also looked at photos of full size locos for comparison.
Perhaps someone who has completed Pansy could advise.
Pete
alan ord 206/08/2017 19:03:07
77 forum posts
Pete, thanks for the update.
Alan.
Peter Maloney18/08/2017 20:18:35
30 forum posts
12 photos
Hi
Been to Bristol ME exhibition today and there were 4 models of Pansy on show. Without exception they all used the 3 15/16 dimn to the start of the cab cutout and it looked perfect. That is the dimn I will be using.
Also, none of the bunkers had sharp corners - the rounded corners looked great. Must brush up my panel beating skills.
Pete
alan ord 219/08/2017 18:05:36
77 forum posts
Pete, thanks for the clarification. I will amend my drawing to reflect the correct dimension.
Thanks again, Alan.
